1 |
greg |
1.3 |
.\" RCSid "$Id$" |
2 |
greg |
1.1 |
.TH OBJ2RAD 1 6/14/94 RADIANCE |
3 |
.SH NAME |
4 |
obj2rad - convert Wavefront .obj file to RADIANCE description |
5 |
.SH SYNOPSIS |
6 |
.B obj2rad |
7 |
8 |
.B \-n |
9 |
10 |
.B \-f |
11 |
12 |
.B "\-m mapfile" |
13 |
14 |
.B "\-o objname" |
15 |
16 |
17 |
.B input |
18 |
19 |
.SH DESCRIPTION |
20 |
.I Obj2rad |
21 |
converts a Wavefront .obj file to a RADIANCE scene description. |
22 |
The material names for the surfaces will assigned based on the |
23 |
mapping rules file given in the |
24 |
.I \-m |
25 |
option. |
26 |
If no mapping file is given, the identifiers given by the "usemtl" |
27 |
statements will be used as the material names. |
28 |
If no "usemtl" statements are found, the group names (given by |
29 |
the "g" statement) will be used instead. |
30 |
Failing this, the default material "white" will be used. |
31 |
.PP |
32 |
A mapping file contains a list of materials followed by the conditions |
33 |
a surface must satisfy in order to have that material. |
34 |
For example, if we wanted all faces in the Group "thingy" with |
35 |
texture Map "pine" to use the material "wood", |
36 |
and all other surfaces to use the |
37 |
material "default", we would create the following mapping file: |
38 |
.nf |
39 |
40 |
default ; |
41 |
wood (Group "thingy") (Map "pine") ; |
42 |
43 |
.fi |
44 |
All faces would satisfy the first set of conditions (which is empty), |
45 |
but only the faces in the Group "thingy" |
46 |
with texture Map "pine" would satisfy the |
47 |
second set of conditions. |
48 |
.PP |
49 |
Each rule can have up to one condition per qualifier, and different |
50 |
translators use different qualifiers. |
51 |
In |
52 |
.I obj2rad, |
53 |
the valid qualifiers are |
54 |
.I "Material, Map, Group, Object" |
55 |
and |
56 |
.I Face. |
57 |
A condition is either a single value for a |
58 |
specific attribute, or an integer range of values. |
59 |
(Integer ranges are |
60 |
specified in brackets and separated by a colon, eg. [\-15:27], and are |
61 |
always inclusive.) A semicolon is used to indicate the end of a rule, |
62 |
which can extend over several lines if necessary. |
63 |
.PP |
64 |
The semantics of the rule are such that "and" is the implied conjunction |
65 |
between conditions. |
66 |
Thus, it makes no sense to have more than one |
67 |
condition in a rule for a given qualifier. |
68 |
If the user wants the same |
69 |
material to be used for surfaces that satisfy different conditions, |
70 |
they simply add more rules. |
71 |
For example, if the user also wanted faces between 50 and 175 in the |
72 |
Group "yohey" to use "wood", |
73 |
they would add the following rule to the end of the example above: |
74 |
.nf |
75 |
76 |
wood (Face [50:175]) (Group "yohey") ; |
77 |
78 |
.fi |
79 |
Note that the order of conditions in a rule is irrelevant. |
80 |
However, |
81 |
the order of rules is very important, since the last rule satisfied |
82 |
determines which material a surface is assigned. |
83 |
.PP |
84 |
By convention, the identifier "void" is used to delete unwanted |
85 |
surfaces. |
86 |
A surface is also deleted if it fails to match any rule. |
87 |
Void is used in a rule as any other material, but it has the |
88 |
effect of excluding all matching surfaces from the translator output. |
89 |
For example, the following mapping would delete all surfaces in the |
90 |
Object "junk" except those with the Group name "beige", to which it |
91 |
would assign the material "beige_cloth", and all other surfaces |
92 |
would be "tacky": |
93 |
.nf |
94 |
95 |
tacky ; |
96 |
void (Object "junk") ; |
97 |
beige_cloth (Object "junk") (Group "beige") ; |
98 |
99 |
.fi |
100 |
.PP |
101 |
The |
102 |
.I \-n |
103 |
option may be used to produce a list of qualifiers from which to construct |
104 |
a mapping for the given .obj file. |
105 |
This is also useful for determining which materials must be defined |
106 |
when no mapping is used. |
107 |
.PP |
108 |
The |
109 |
.I \-f |
110 |
option is used to flatten all faces, effectively ignoring vertex |
111 |
normal information. |
112 |
This is sometimes desirable when a smaller model or more robust |
113 |
rendering is desired, since interpolating vertex normals takes time |
114 |
and is not always reliable. |
115 |
.PP |
116 |
The |
117 |
.I \-o |
118 |
option may be used to specify the name of this object, though it |
119 |
will be overriden by any "o" statements in the input file. |
120 |
If this option is absent, and there are no "o" statements, |
121 |
.I obj2rad |
122 |
will attempt to name surfaces based on their group associations. |
123 |
.PP |
124 |
If no input files are given, the standard input is read. |
125 |
.SH DETAILS |
126 |
The following Wavefront statements are understood and translated by |
127 |
.I obj2rad. |
128 |
.TP 10n |
129 |
.BR # |
130 |
A comment. |
131 |
This statement is passed to the output verbatim. |
132 |
It has no effect. |
133 |
.TP |
134 |
.BR f |
135 |
A polygonal face. |
136 |
If the vertices have associated surface normals, the face |
137 |
will be broken into quadrilaterals and triangles with the |
138 |
appropriate Radiance textures to interpolate them. |
139 |
Likewise, if the face is non-planar, it will be broken |
140 |
into triangles. |
141 |
Each face in the input file is assigned a number, starting with 1, |
142 |
and this number may be used in the material mapping rules. |
143 |
.TP |
144 |
.BR g |
145 |
Group association. |
146 |
The following faces are associated with the named group(s). |
147 |
These may be used in the mapping rules, where a rule is matched |
148 |
if there is an association with the named Group. |
149 |
(I.e. since there may be multiple group associations, any match |
150 |
is considered valid.) |
151 |
If a mapping file is not used and no "usemtl" statement has been |
152 |
encountered, the main group is used for the surface material |
153 |
identifier. |
154 |
.TP |
155 |
.BR o |
156 |
Object name. |
157 |
This is used to name the following faces, and may be used |
158 |
in the mapping rules. |
159 |
.TP |
160 |
.BR usemap |
161 |
A texture map (i.e. Radiance pattern) name. |
162 |
The name may be used in the material mapping rules, but |
163 |
the indexing of Radiance patterns is not yet supported. |
164 |
.TP |
165 |
.BR usemtl |
166 |
A material name. |
167 |
The name may be used in mapping rules, or will be used |
168 |
as the Radiance material identifier if no mapping is given. |
169 |
.TP |
170 |
.BR v |
171 |
A vertex, given by its x, y and z coordinates. |
172 |
.TP |
173 |
.BR vn |
174 |
A vertex normal, given by its x, y and z direction components. |
175 |
This vector will be normalized by |
176 |
.I obj2rad, |
177 |
and an error will result if it has length zero. |
178 |
.TP |
179 |
.BR vt |
180 |
A vertex texture coordinate. |
181 |
Not currently used, but will be if we ever get around to |
182 |
supporting Wavefront textures. |
183 |
.PP |
184 |
All other statement types will be ignored on the input. |
185 |
A final comment at the end of the Radiance output file will give some |
186 |
indication of how successful the translation was, since |
187 |
it will mention the number of statements |
188 |
.I obj2rad |
189 |
did not recognize. |
190 |
.SH EXAMPLE |
191 |
To create a qualifier list for triceratops.obj: |
192 |
.IP "" .2i |
193 |
obj2rad -n triceratops.obj > triceratops.qual |
194 |
.PP |
195 |
To translate triceratops.obj into a RADIANCE file using the mapping |
196 |
triceratops.map: |
197 |
.IP "" .2i |
198 |
obj2rad -m triceratops.map triceratops.obj > triceratops.rad |
199 |
.SH NOTES |
200 |
Many good and useful Wavefront object files are available by |
201 |
anonymous ftp from "avalon.chinalake.navy.mil" in the |
202 |
/pub/objects/obj directory. |
203 |
.SH FILES |
204 |
tmesh.cal - used for triangle normal interpolation |
205 |
.br |
206 |
surf.cal - used for quadrilateral normal interpolation |
207 |
.SH AUTHOR |
208 |
Greg Ward |
209 |
.SH "SEE ALSO" |
210 |
greg |
1.2 |
arch2rad(1), ies2rad(1), obj2mesh(1), oconv(1), thf2rad(1), xform(1) |
