root/radiance/ray/doc/man/man1/obj2rad.1
Revision: 1.3
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 5 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Fixed RCSid specification
# User Rev Content
1 greg 1.3 .\" RCSid "$Id$"
2 greg 1.1 .TH OBJ2RAD 1 6/14/94 RADIANCE
3     .SH NAME
4     obj2rad - convert Wavefront .obj file to RADIANCE description
5     .SH SYNOPSIS
6     .B obj2rad
7     [
8     .B \-n
9     ][
10     .B \-f
11     ][
12     .B "\-m mapfile"
13     ][
14     .B "\-o objname"
15     ]
16     [
17     .B input
18     ]
19     .SH DESCRIPTION
20     .I Obj2rad
21     converts a Wavefront .obj file to a RADIANCE scene description.
22     The material names for the surfaces will assigned based on the
23     mapping rules file given in the
24     .I \-m
25     option.
26     If no mapping file is given, the identifiers given by the "usemtl"
27     statements will be used as the material names.
28     If no "usemtl" statements are found, the group names (given by
29     the "g" statement) will be used instead.
30     Failing this, the default material "white" will be used.
31     .PP
32     A mapping file contains a list of materials followed by the conditions
33     a surface must satisfy in order to have that material.
34     For example, if we wanted all faces in the Group "thingy" with
35     texture Map "pine" to use the material "wood",
36     and all other surfaces to use the
37     material "default", we would create the following mapping file:
38     .nf
39
40     default ;
41     wood (Group "thingy") (Map "pine") ;
42
43     .fi
44     All faces would satisfy the first set of conditions (which is empty),
45     but only the faces in the Group "thingy"
46     with texture Map "pine" would satisfy the
47     second set of conditions.
48     .PP
49     Each rule can have up to one condition per qualifier, and different
50     translators use different qualifiers.
51     In
52     .I obj2rad,
53     the valid qualifiers are
54     .I "Material, Map, Group, Object"
55     and
56     .I Face.
57     A condition is either a single value for a
58     specific attribute, or an integer range of values.
59     (Integer ranges are
60     specified in brackets and separated by a colon, eg. [\-15:27], and are
61     always inclusive.) A semicolon is used to indicate the end of a rule,
62     which can extend over several lines if necessary.
63     .PP
64     The semantics of the rule are such that "and" is the implied conjunction
65     between conditions.
66     Thus, it makes no sense to have more than one
67     condition in a rule for a given qualifier.
68     If the user wants the same
69     material to be used for surfaces that satisfy different conditions,
70     they simply add more rules.
71     For example, if the user also wanted faces between 50 and 175 in the
72     Group "yohey" to use "wood",
73     they would add the following rule to the end of the example above:
74     .nf
75
76     wood (Face [50:175]) (Group "yohey") ;
77
78     .fi
79     Note that the order of conditions in a rule is irrelevant.
80     However,
81     the order of rules is very important, since the last rule satisfied
82     determines which material a surface is assigned.
83     .PP
84     By convention, the identifier "void" is used to delete unwanted
85     surfaces.
86     A surface is also deleted if it fails to match any rule.
87     Void is used in a rule as any other material, but it has the
88     effect of excluding all matching surfaces from the translator output.
89     For example, the following mapping would delete all surfaces in the
90     Object "junk" except those with the Group name "beige", to which it
91     would assign the material "beige_cloth", and all other surfaces
92     would be "tacky":
93     .nf
94
95     tacky ;
96     void (Object "junk") ;
97     beige_cloth (Object "junk") (Group "beige") ;
98
99     .fi
100     .PP
101     The
102     .I \-n
103     option may be used to produce a list of qualifiers from which to construct
104     a mapping for the given .obj file.
105     This is also useful for determining which materials must be defined
106     when no mapping is used.
107     .PP
108     The
109     .I \-f
110     option is used to flatten all faces, effectively ignoring vertex
111     normal information.
112     This is sometimes desirable when a smaller model or more robust
113     rendering is desired, since interpolating vertex normals takes time
114     and is not always reliable.
115     .PP
116     The
117     .I \-o
118     option may be used to specify the name of this object, though it
119     will be overriden by any "o" statements in the input file.
120     If this option is absent, and there are no "o" statements,
121     .I obj2rad
122     will attempt to name surfaces based on their group associations.
123     .PP
124     If no input files are given, the standard input is read.
125     .SH DETAILS
126     The following Wavefront statements are understood and translated by
127     .I obj2rad.
128     .TP 10n
129     .BR #
130     A comment.
131     This statement is passed to the output verbatim.
132     It has no effect.
133     .TP
134     .BR f
135     A polygonal face.
136     If the vertices have associated surface normals, the face
137     will be broken into quadrilaterals and triangles with the
138     appropriate Radiance textures to interpolate them.
139     Likewise, if the face is non-planar, it will be broken
140     into triangles.
141     Each face in the input file is assigned a number, starting with 1,
142     and this number may be used in the material mapping rules.
143     .TP
144     .BR g
145     Group association.
146     The following faces are associated with the named group(s).
147     These may be used in the mapping rules, where a rule is matched
148     if there is an association with the named Group.
149     (I.e. since there may be multiple group associations, any match
150     is considered valid.)
151     If a mapping file is not used and no "usemtl" statement has been
152     encountered, the main group is used for the surface material
153     identifier.
154     .TP
155     .BR o
156     Object name.
157     This is used to name the following faces, and may be used
158     in the mapping rules.
159     .TP
160     .BR usemap
161     A texture map (i.e. Radiance pattern) name.
162     The name may be used in the material mapping rules, but
163     the indexing of Radiance patterns is not yet supported.
164     .TP
165     .BR usemtl
166     A material name.
167     The name may be used in mapping rules, or will be used
168     as the Radiance material identifier if no mapping is given.
169     .TP
170     .BR v
171     A vertex, given by its x, y and z coordinates.
172     .TP
173     .BR vn
174     A vertex normal, given by its x, y and z direction components.
175     This vector will be normalized by
176     .I obj2rad,
177     and an error will result if it has length zero.
178     .TP
179     .BR vt
180     A vertex texture coordinate.
181     Not currently used, but will be if we ever get around to
182     supporting Wavefront textures.
183     .PP
184     All other statement types will be ignored on the input.
185     A final comment at the end of the Radiance output file will give some
186     indication of how successful the translation was, since
187     it will mention the number of statements
188     .I obj2rad
189     did not recognize.
190     .SH EXAMPLE
191     To create a qualifier list for triceratops.obj:
192     .IP "" .2i
193     obj2rad -n triceratops.obj > triceratops.qual
194     .PP
195     To translate triceratops.obj into a RADIANCE file using the mapping
196     triceratops.map:
197     .IP "" .2i
198     obj2rad -m triceratops.map triceratops.obj > triceratops.rad
199     .SH NOTES
200     Many good and useful Wavefront object files are available by
201     anonymous ftp from "avalon.chinalake.navy.mil" in the
202     /pub/objects/obj directory.
203     .SH FILES
204     tmesh.cal - used for triangle normal interpolation
205     .br
206     surf.cal - used for quadrilateral normal interpolation
207     .SH AUTHOR
208     Greg Ward
209     .SH "SEE ALSO"
210 greg 1.2 arch2rad(1), ies2rad(1), obj2mesh(1), oconv(1), thf2rad(1), xform(1)
