root/radiance/ray/doc/man/man1/obj2mesh.1
Revision: 1.2
Committed: Wed Mar 12 17:26:58 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.1: +59 -6 lines
1 .\" RCSid "$Id"
2 .TH OBJ2MESH 1 03/11/03 RADIANCE
3 .SH NAME
4 obj2mesh - create a compiled RADIANCE mesh file from Wavefront .OBJ input
5 .SH SYNOPSIS
6 .B obj2mesh
7 [
8 .B "\-n objlim"
9 ][
10 .B "\-r maxres"
11 ][
12 .B \-w
13 ]
14 [
15 .B "input.obj"
16 [
17 .B "output.rtm"
18 ]
19 ]
20 .SH DESCRIPTION
21 .I Obj2mesh
22 reads a Wavefront .OBJ file from
23 .I input.obj
24 (or the standard input) and compiles it into a RADIANCE triangle mesh,
25 which is sent to
26 .I output.rtm
27 (or standard output).
28 This mesh may be included in a RADIANCE scene description via the
29 .I mesh
30 primitive, thus:
31 .IP "" .2i
32 mod mesh id
33 .br
34 1+ output.rtm [xform args]
35 .br
36 0
37 .br
38 0
39 .PP
40 The syntax and semantics are identical to the RADIANCE
41 .I instance
42 primitive, except that the mesh modifier may not be "void", since
43 materials are not included in a compiled mesh file.
44 .PP
45 The
46 .I \-n
47 option specifies the maximum surface set size for
48 each voxel.
49 Larger numbers result in quicker mesh generation needing
50 less memory, but potentially slower rendering.
51 Smaller values may produce faster renderings,
52 since the default number (15) is on the high side to reduce
53 the compiled mesh octree size.
54 Values below 6 are not recommended, since this is the median
55 valence for a mesh vertex (the number of adjacent faces),
56 and smaller values will result in pointless octree subdivision.
57 .PP
58 The
59 .I \-r
60 option specifies the maximum octree resolution.
61 This should be greater than or equal to the ratio of the mesh bounding
62 box to the smallest triangle.
63 The default is 16384.
64 .PP
65 The
66 .I \-w
67 option suppresses warnings.
68 .PP
69 Although the mesh file format is binary, it is meant to be portable
70 between machines.
71 The only limitation is that machines with radically different integer
72 sizes will not work together.
73 .SH DETAILS
74 The following Wavefront statements are understood and compiled by
75 .I obj2mesh.
76 .TP 10n
77 .BI v " x y z"
78 A vertex location, given by its Cartesian coordinates.
79 The final mesh position may of course be modified by
80 the transform arguments given to the
81 .I mesh
82 primitive in the Radiance scene description.
83 .TP
84 .BI vn " dx dy dz"
85 A vertex normal vector, given by its three
86 direction components, which will be normalized by
87 .I obj2mesh.
88 Normals will be interpolated over the mesh
89 during rendering to produce a smooth surface.
90 If no vertex normals are present, the mess will appear tesselated.
91 A zero length normal (i.e., 0 0 0) will generate a syntax error.
92 .TP
93 .BI vt " u v"
94 A local vertex texture coordinate.
95 These coordinates will be interpolated and passed
96 to the "Lu" and "Lv" variables during rendering.
97 Local coordinates can extend over any desired range of values.
98 .TP
99 .BI f " v1/t1/n1 v2/t2/n2 v3/t3/n3" " .."
100 A polygonal face.
101 Polygon vertices are specified as three indices separated
102 by slashes ('/').
103 The first index is the vertex location, the
104 second index is the local (u,v) texture coordinate, and the
105 third index is the vertex surface normal.
106 Positive indices count from the beginning of the input,
107 where the first vertex position (
108 .I v
109 statement) is numbered 1, and likewise
110 for the first texture coordinate and the first surface normal.
111 Negative indices count backward from the current position in
112 the input, where -1 is the last vertex encountered, -2
113 is the one before that, etc.
114 An index of 0 may be used for the vertex texture or normal to
115 indicate none, or these may be left off entirely.
116 All faces will be broken into triangles in the final mesh.
117 .I Obj2mesh
118 currently makes an unsafe assumption that faces are convex,
119 which may result in odd results if they are not.
120 .PP
121 All other statement types will be ignored on the input.
122 Statements understood by
123 .I obj2rad(1)
124 will be ignored silently; other statements will generate
125 a warning message after translation to indicate how much was missed.
126 .SH DIAGNOSTICS
127 There are four basic error types reported by obj2mesh:
128 .IP
129 warning - a non-fatal input-related error
130 .IP
131 fatal - an unrecoverable input-related error
132 .IP
133 system - a system-related error
134 .IP
135 internal - a fatal error related to program limitations
136 .IP
137 consistency - a program-caused error
138 .PP
139 Most errors are self-explanatory.
140 However, the following internal errors should be mentioned:
141 .IP "Set overflow in addobject (id)"
142 This error occurs when too many surfaces are close together in a
143 scene.
144 Sometimes a dense mesh can be accommodated by increasing
145 the maximum resolution (by powers of two) using the
146 .I \-r
147 option, but usually this error indicates something is wrong.
148 Either too many surfaces are lying right on top of each other,
149 or the bounding cube is inflated from disparate geometry
150 in the input.
151 Chances are, the face number "id" is near
152 those causing the problem.
153 .IP "Hash table overflow in fullnode"
154 This error is caused by too many surfaces, and there is
155 little hope of compiling this mesh.
156 .SH EXAMPLE
157 To create a compiled triangle mesh from the scene file mesh.obj:
158 .IP "" .2i
159 oconv mesh.obj mesh.rtm
160 .SH AUTHOR
161 Greg Ward
162 .SH "SEE ALSO"
163 gensurf(1), getinfo(1), make(1), obj2rad(1),
164 oconv(1), rpict(1), rview(1), rtrace(1), xform(1)
