--- ray/doc/man/man1/obj2mesh.1 2003/03/14 21:27:45 1.3 +++ ray/doc/man/man1/obj2mesh.1 2004/04/23 00:56:27 1.8 @@ -1,12 +1,14 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: obj2mesh.1,v 1.8 2004/04/23 00:56:27 greg Exp $" .TH OBJ2MESH 1 03/11/03 RADIANCE .SH NAME obj2mesh - create a compiled RADIANCE mesh file from Wavefront .OBJ input .SH SYNOPSIS .B obj2mesh [ -.B "\-a matinput" +.B "\-a matfile" ][ +.B "\-l matlib" +][ .B "\-n objlim" ][ .B "\-r maxres" @@ -30,6 +32,10 @@ which is sent to Any RADIANCE material descriptions included via one or more .I \-a options will be compiled and stored in the mesh as well. +If the +.I \-l +option is used to specify a material file, the RADIANCE library +locations are searched. This mesh may be included in a RADIANCE scene description via the .I mesh primitive, thus: @@ -96,7 +102,7 @@ direction components, which will be normalized by .I obj2mesh. Normals will be interpolated over the mesh during rendering to produce a smooth surface. -If no vertex normals are present, the mess will appear tesselated. +If no vertex normals are present, the mesh will appear tesselated. A zero length normal (i.e., 0 0 0) will generate a syntax error. .TP .BI vt " u v" @@ -176,12 +182,34 @@ those causing the problem. .IP "Hash table overflow in fullnode" This error is caused by too many surfaces, and there is little hope of compiling this mesh. -.SH EXAMPLE -To create a compiled triangle mesh from the scene file mesh.obj: +.SH EXAMPLES +To create a compiled triangle mesh from the scene file mesh.obj +using materials from the file mesh.mat: .IP "" .2i -oconv mesh.obj mesh.rtm +obj2mesh -a mesh.mat mesh.obj mesh.rtm +.PP +To use local coordinates to place a square tiled image on a mesh object: +.sp +.nf +void colorpict tiled_pat +7 red green blue mytile.pic . frac(Lu) frac(Lv) +0 +0 + +tiled_pat plastic tiled_mat +0 +0 +5 .9 .9 .9 0 0 + +tiled_mat mesh tiled_mesh +1 mymesh.rtm +0 +0 +.fi +.SH ENVIRONMENT +RAYPATH the directories to search for material files. .SH AUTHOR Greg Ward .SH "SEE ALSO" gensurf(1), getinfo(1), make(1), obj2rad(1), -oconv(1), rpict(1), rview(1), rtrace(1), xform(1) +oconv(1), rpict(1), rvu(1), rtrace(1), xform(1)
