--- ray/doc/man/man1/obj2mesh.1 2003/03/11 22:48:20 1.1 +++ ray/doc/man/man1/obj2mesh.1 2014/01/24 01:26:44 1.12 @@ -1,10 +1,14 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: obj2mesh.1,v 1.12 2014/01/24 01:26:44 greg Exp $" .TH OBJ2MESH 1 03/11/03 RADIANCE .SH NAME obj2mesh - create a compiled RADIANCE mesh file from Wavefront .OBJ input .SH SYNOPSIS .B obj2mesh [ +.B "\-a matfile" +][ +.B "\-l matlib" +][ .B "\-n objlim" ][ .B "\-r maxres" @@ -25,6 +29,13 @@ reads a Wavefront .OBJ file from which is sent to .I output.rtm (or standard output). +Any RADIANCE material descriptions included via one or more +.I \-a +options will be compiled and stored in the mesh as well. +If the +.I \-l +option is used to specify a material file, the RADIANCE library +locations are searched. This mesh may be included in a RADIANCE scene description via the .I mesh primitive, thus: @@ -37,23 +48,25 @@ mod mesh id .br 0 .PP -The syntax and semantics are nearly identical to the RADIANCE +The syntax and semantics are identical to the RADIANCE .I instance -primitive, except that the mesh modifier may not be "void", since -materials are not included in a compiled mesh file. +primitive. +If +.I mod +is "void", then the stored mesh materials will be applied during rendering. +Otherwise, the given material will be substituted on +all the mesh surfaces. .PP The .I \-n option specifies the maximum surface set size for each voxel. -Larger numbers result in quicker mesh generation needing -less memory, but potentially slower rendering. -Smaller values may produce faster renderings, -since the default number (15) is on the high side to reduce -the compiled mesh octree size. -Values below 6 are not recommended, since the median -valence (number of adjacent faces) for a mesh vertex is 6, -and smaller limits will result in pointless octree subdivision. +Larger numbers result in quicker mesh generation, +but potentially slower rendering. +Values below 6 are not recommended, since this is the median +valence for a mesh vertex (the number of adjacent faces), +and smaller values will result in pointless octree subdivision. +The default setting is 9. .PP The .I \-r @@ -70,6 +83,70 @@ Although the mesh file format is binary, it is meant t between machines. The only limitation is that machines with radically different integer sizes will not work together. +.SH DETAILS +The following Wavefront statements are understood and compiled by +.I obj2mesh. +.TP 10n +.BI v " x y z" +A vertex location, given by its Cartesian coordinates. +The final mesh position may of course be modified by +the transform arguments given to the +.I mesh +primitive in the Radiance scene description. +.TP +.BI vn " dx dy dz" +A vertex normal vector, given by its three +direction components, which will be normalized by +.I obj2mesh. +Normals will be interpolated over the mesh +during rendering to produce a smooth surface. +If no vertex normals are present, the mesh will appear tesselated. +A zero length normal (i.e., 0 0 0) will generate a syntax error. +.TP +.BI vt " u v" +A local vertex texture coordinate. +These coordinates will be interpolated and passed +to the "Lu" and "Lv" variables during rendering. +Local coordinates can extend over any desired range of values. +.TP +.BI usemtl " mname" +A material name. +The following faces will use the named material, which is +taken from the material definitions in the +.I \-a +input file(s). +.TP +.BI g " gname" +Group association. +The following faces are associated with the named group. +If no "usemtl" statement has been +encountered, the current group is used for the surface material +identifier. +.TP +.BI f " v1/t1/n1 v2/t2/n2 v3/t3/n3" " .." +A polygonal face. +Polygon vertices are specified as three indices separated +by slashes ('/'). +The first index is the vertex location, the +second index is the local (u,v) texture coordinate, and the +third index is the vertex surface normal. +Positive indices count from the beginning of the input, +where the first vertex position ( +.I v +statement) is numbered 1, and likewise +for the first texture coordinate and the first surface normal. +Negative indices count backward from the current position in +the input, where \-1 is the last vertex encountered, \-2 +is the one before that, etc. +An index of 0 may be used for the vertex texture or normal to +indicate none, or these may be left off entirely. +All faces will be broken into triangles in the final mesh. +.PP +All other statement types will be ignored on the input. +Statements understood by +.I obj2rad(1) +will be ignored silently; other statements will generate +a warning message after translation to indicate how much was missed. .SH DIAGNOSTICS There are four basic error types reported by obj2mesh: .IP @@ -88,7 +165,7 @@ However, the following internal errors should be menti .IP "Set overflow in addobject (id)" This error occurs when too many surfaces are close together in a scene. -Sometimes a dense mesh can be accomodated by increasing +Sometimes a dense mesh can be accommodated by increasing the maximum resolution (by powers of two) using the .I \-r option, but usually this error indicates something is wrong. @@ -100,12 +177,34 @@ those causing the problem. .IP "Hash table overflow in fullnode" This error is caused by too many surfaces, and there is little hope of compiling this mesh. -.SH EXAMPLE -To create a compiled triangle mesh from the scene file mesh.obj: +.SH EXAMPLES +To create a compiled triangle mesh from the scene file mesh.obj +using materials from the file mesh.mat: .IP "" .2i -oconv mesh.obj mesh.rtm +obj2mesh \-a mesh.mat mesh.obj mesh.rtm +.PP +To use local coordinates to place a square tiled image on a mesh object: +.sp +.nf +void colorpict tiled_pat +7 red green blue mytile.hdr . frac(Lu) frac(Lv) +0 +0 + +tiled_pat plastic tiled_mat +0 +0 +5 .9 .9 .9 0 0 + +tiled_mat mesh tiled_mesh +1 mymesh.rtm +0 +0 +.fi +.SH ENVIRONMENT +RAYPATH the directories to search for material files. .SH AUTHOR Greg Ward .SH "SEE ALSO" -gensurf(1), getinfo(1), make(1), -oconv(1), rpict(1), rview(1), rtrace(1), xform(1) +gensurf(1), getinfo(1), make(1), obj2rad(1), +oconv(1), rpict(1), rvu(1), rtrace(1), xform(1)
