1 |
.\" RCSid "$Id: obj2mesh.1,v 1.6 2004/01/01 19:31:45 greg Exp $" |
2 |
.TH OBJ2MESH 1 03/11/03 RADIANCE |
3 |
.SH NAME |
4 |
obj2mesh - create a compiled RADIANCE mesh file from Wavefront .OBJ input |
5 |
.SH SYNOPSIS |
6 |
.B obj2mesh |
7 |
8 |
.B "\-a matinput" |
9 |
10 |
.B "\-n objlim" |
11 |
12 |
.B "\-r maxres" |
13 |
14 |
.B \-w |
15 |
16 |
17 |
.B "input.obj" |
18 |
19 |
.B "output.rtm" |
20 |
21 |
22 |
.SH DESCRIPTION |
23 |
.I Obj2mesh |
24 |
reads a Wavefront .OBJ file from |
25 |
.I input.obj |
26 |
(or the standard input) and compiles it into a RADIANCE triangle mesh, |
27 |
which is sent to |
28 |
.I output.rtm |
29 |
(or standard output). |
30 |
Any RADIANCE material descriptions included via one or more |
31 |
.I \-a |
32 |
options will be compiled and stored in the mesh as well. |
33 |
This mesh may be included in a RADIANCE scene description via the |
34 |
.I mesh |
35 |
primitive, thus: |
36 |
.IP "" .2i |
37 |
mod mesh id |
38 |
.br |
39 |
1+ output.rtm [xform args] |
40 |
.br |
41 |
0 |
42 |
.br |
43 |
0 |
44 |
.PP |
45 |
The syntax and semantics are identical to the RADIANCE |
46 |
.I instance |
47 |
primitive. |
48 |
If |
49 |
.I mod |
50 |
is "void", then the stored mesh materials will be applied during rendering. |
51 |
Otherwise, the given material will be substituted on |
52 |
all the mesh surfaces. |
53 |
.PP |
54 |
The |
55 |
.I \-n |
56 |
option specifies the maximum surface set size for |
57 |
each voxel. |
58 |
Larger numbers result in quicker mesh generation needing |
59 |
less memory, but potentially slower rendering. |
60 |
Smaller values may produce faster renderings, |
61 |
since the default number (15) is on the high side to reduce |
62 |
the compiled mesh octree size. |
63 |
Values below 6 are not recommended, since this is the median |
64 |
valence for a mesh vertex (the number of adjacent faces), |
65 |
and smaller values will result in pointless octree subdivision. |
66 |
.PP |
67 |
The |
68 |
.I \-r |
69 |
option specifies the maximum octree resolution. |
70 |
This should be greater than or equal to the ratio of the mesh bounding |
71 |
box to the smallest triangle. |
72 |
The default is 16384. |
73 |
.PP |
74 |
The |
75 |
.I \-w |
76 |
option suppresses warnings. |
77 |
.PP |
78 |
Although the mesh file format is binary, it is meant to be portable |
79 |
between machines. |
80 |
The only limitation is that machines with radically different integer |
81 |
sizes will not work together. |
82 |
.SH DETAILS |
83 |
The following Wavefront statements are understood and compiled by |
84 |
.I obj2mesh. |
85 |
.TP 10n |
86 |
.BI v " x y z" |
87 |
A vertex location, given by its Cartesian coordinates. |
88 |
The final mesh position may of course be modified by |
89 |
the transform arguments given to the |
90 |
.I mesh |
91 |
primitive in the Radiance scene description. |
92 |
.TP |
93 |
.BI vn " dx dy dz" |
94 |
A vertex normal vector, given by its three |
95 |
direction components, which will be normalized by |
96 |
.I obj2mesh. |
97 |
Normals will be interpolated over the mesh |
98 |
during rendering to produce a smooth surface. |
99 |
If no vertex normals are present, the mesh will appear tesselated. |
100 |
A zero length normal (i.e., 0 0 0) will generate a syntax error. |
101 |
.TP |
102 |
.BI vt " u v" |
103 |
A local vertex texture coordinate. |
104 |
These coordinates will be interpolated and passed |
105 |
to the "Lu" and "Lv" variables during rendering. |
106 |
Local coordinates can extend over any desired range of values. |
107 |
.TP |
108 |
.BI usemtl " mname" |
109 |
A material name. |
110 |
The following faces will use the named material, which is |
111 |
taken from the material definitions in the |
112 |
.I \-a |
113 |
input file(s). |
114 |
.TP |
115 |
.BI g " gname" |
116 |
Group association. |
117 |
The following faces are associated with the named group. |
118 |
If no "usemtl" statement has been |
119 |
encountered, the current group is used for the surface material |
120 |
identifier. |
121 |
.TP |
122 |
.BI f " v1/t1/n1 v2/t2/n2 v3/t3/n3" " .." |
123 |
A polygonal face. |
124 |
Polygon vertices are specified as three indices separated |
125 |
by slashes ('/'). |
126 |
The first index is the vertex location, the |
127 |
second index is the local (u,v) texture coordinate, and the |
128 |
third index is the vertex surface normal. |
129 |
Positive indices count from the beginning of the input, |
130 |
where the first vertex position ( |
131 |
.I v |
132 |
statement) is numbered 1, and likewise |
133 |
for the first texture coordinate and the first surface normal. |
134 |
Negative indices count backward from the current position in |
135 |
the input, where -1 is the last vertex encountered, -2 |
136 |
is the one before that, etc. |
137 |
An index of 0 may be used for the vertex texture or normal to |
138 |
indicate none, or these may be left off entirely. |
139 |
All faces will be broken into triangles in the final mesh. |
140 |
.I Obj2mesh |
141 |
currently makes an unsafe assumption that faces are convex, |
142 |
which may result in odd results if they are not. |
143 |
.PP |
144 |
All other statement types will be ignored on the input. |
145 |
Statements understood by |
146 |
.I obj2rad(1) |
147 |
will be ignored silently; other statements will generate |
148 |
a warning message after translation to indicate how much was missed. |
149 |
.SH DIAGNOSTICS |
150 |
There are four basic error types reported by obj2mesh: |
151 |
.IP |
152 |
warning - a non-fatal input-related error |
153 |
.IP |
154 |
fatal - an unrecoverable input-related error |
155 |
.IP |
156 |
system - a system-related error |
157 |
.IP |
158 |
internal - a fatal error related to program limitations |
159 |
.IP |
160 |
consistency - a program-caused error |
161 |
.PP |
162 |
Most errors are self-explanatory. |
163 |
However, the following internal errors should be mentioned: |
164 |
.IP "Set overflow in addobject (id)" |
165 |
This error occurs when too many surfaces are close together in a |
166 |
scene. |
167 |
Sometimes a dense mesh can be accommodated by increasing |
168 |
the maximum resolution (by powers of two) using the |
169 |
.I \-r |
170 |
option, but usually this error indicates something is wrong. |
171 |
Either too many surfaces are lying right on top of each other, |
172 |
or the bounding cube is inflated from disparate geometry |
173 |
in the input. |
174 |
Chances are, the face number "id" is near |
175 |
those causing the problem. |
176 |
.IP "Hash table overflow in fullnode" |
177 |
This error is caused by too many surfaces, and there is |
178 |
little hope of compiling this mesh. |
179 |
.SH EXAMPLES |
180 |
To create a compiled triangle mesh from the scene file mesh.obj |
181 |
using materials from the file mesh.mat: |
182 |
.IP "" .2i |
183 |
obj2mesh -a mesh.mat mesh.obj mesh.rtm |
184 |
.PP |
185 |
To use local coordinates to place a square tiled image on a mesh object: |
186 |
.sp |
187 |
.nf |
188 |
void colorpict tiled_pat |
189 |
7 red green blue mytile.pic . frac(Lu) frac(Lv) |
190 |
0 |
191 |
0 |
192 |
193 |
tiled_pat plastic tiled_mat |
194 |
0 |
195 |
0 |
196 |
5 .9 .9 .9 0 0 |
197 |
198 |
tiled_mat mesh tiled_mesh |
199 |
1 mymesh.rtm |
200 |
0 |
201 |
0 |
202 |
.fi |
203 |
.SH AUTHOR |
204 |
Greg Ward |
205 |
.SH "SEE ALSO" |
206 |
gensurf(1), getinfo(1), make(1), obj2rad(1), |
207 |
oconv(1), rpict(1), rvu(1), rtrace(1), xform(1) |
