--- ray/doc/man/man1/obj2mesh.1 2003/03/12 17:26:58 1.2 +++ ray/doc/man/man1/obj2mesh.1 2003/03/14 21:27:45 1.3 @@ -5,6 +5,8 @@ obj2mesh - create a compiled RADIANCE mesh file from W .SH SYNOPSIS .B obj2mesh [ +.B "\-a matinput" +][ .B "\-n objlim" ][ .B "\-r maxres" @@ -25,6 +27,9 @@ reads a Wavefront .OBJ file from which is sent to .I output.rtm (or standard output). +Any RADIANCE material descriptions included via one or more +.I \-a +options will be compiled and stored in the mesh as well. This mesh may be included in a RADIANCE scene description via the .I mesh primitive, thus: @@ -39,8 +44,12 @@ mod mesh id .PP The syntax and semantics are identical to the RADIANCE .I instance -primitive, except that the mesh modifier may not be "void", since -materials are not included in a compiled mesh file. +primitive. +If +.I mod +is "void", then the stored mesh materials will be applied during rendering. +Otherwise, the given material will be substituted on +all the mesh surfaces. .PP The .I \-n @@ -95,6 +104,20 @@ A local vertex texture coordinate. These coordinates will be interpolated and passed to the "Lu" and "Lv" variables during rendering. Local coordinates can extend over any desired range of values. +.TP +.BI usemtl " mname" +A material name. +The following faces will use the named material, which is +taken from the material definitions in the +.I \-a +input file(s). +.TP +.BI g " gname" +Group association. +The following faces are associated with the named group. +If no "usemtl" statement has been +encountered, the current group is used for the surface material +identifier. .TP .BI f " v1/t1/n1 v2/t2/n2 v3/t3/n3" " .." A polygonal face.
