1 |
.\" RCSid "$Id" |
2 |
.TH OBJ2MESH 1 03/11/03 RADIANCE |
3 |
.SH NAME |
4 |
obj2mesh - create a compiled RADIANCE mesh file from Wavefront .OBJ input |
5 |
.SH SYNOPSIS |
6 |
.B obj2mesh |
7 |
8 |
.B "\-n objlim" |
9 |
10 |
.B "\-r maxres" |
11 |
12 |
.B \-w |
13 |
14 |
15 |
.B "input.obj" |
16 |
17 |
.B "output.rtm" |
18 |
19 |
20 |
.SH DESCRIPTION |
21 |
.I Obj2mesh |
22 |
reads a Wavefront .OBJ file from |
23 |
.I input.obj |
24 |
(or the standard input) and compiles it into a RADIANCE triangle mesh, |
25 |
which is sent to |
26 |
.I output.rtm |
27 |
(or standard output). |
28 |
This mesh may be included in a RADIANCE scene description via the |
29 |
.I mesh |
30 |
primitive, thus: |
31 |
.IP "" .2i |
32 |
mod mesh id |
33 |
.br |
34 |
1+ output.rtm [xform args] |
35 |
.br |
36 |
0 |
37 |
.br |
38 |
0 |
39 |
.PP |
40 |
The syntax and semantics are identical to the RADIANCE |
41 |
.I instance |
42 |
primitive, except that the mesh modifier may not be "void", since |
43 |
materials are not included in a compiled mesh file. |
44 |
.PP |
45 |
The |
46 |
.I \-n |
47 |
option specifies the maximum surface set size for |
48 |
each voxel. |
49 |
Larger numbers result in quicker mesh generation needing |
50 |
less memory, but potentially slower rendering. |
51 |
Smaller values may produce faster renderings, |
52 |
since the default number (15) is on the high side to reduce |
53 |
the compiled mesh octree size. |
54 |
Values below 6 are not recommended, since this is the median |
55 |
valence for a mesh vertex (the number of adjacent faces), |
56 |
and smaller values will result in pointless octree subdivision. |
57 |
.PP |
58 |
The |
59 |
.I \-r |
60 |
option specifies the maximum octree resolution. |
61 |
This should be greater than or equal to the ratio of the mesh bounding |
62 |
box to the smallest triangle. |
63 |
The default is 16384. |
64 |
.PP |
65 |
The |
66 |
.I \-w |
67 |
option suppresses warnings. |
68 |
.PP |
69 |
Although the mesh file format is binary, it is meant to be portable |
70 |
between machines. |
71 |
The only limitation is that machines with radically different integer |
72 |
sizes will not work together. |
73 |
.SH DETAILS |
74 |
The following Wavefront statements are understood and compiled by |
75 |
.I obj2mesh. |
76 |
.TP 10n |
77 |
.BI v " x y z" |
78 |
A vertex location, given by its Cartesian coordinates. |
79 |
The final mesh position may of course be modified by |
80 |
the transform arguments given to the |
81 |
.I mesh |
82 |
primitive in the Radiance scene description. |
83 |
.TP |
84 |
.BI vn " dx dy dz" |
85 |
A vertex normal vector, given by its three |
86 |
direction components, which will be normalized by |
87 |
.I obj2mesh. |
88 |
Normals will be interpolated over the mesh |
89 |
during rendering to produce a smooth surface. |
90 |
If no vertex normals are present, the mess will appear tesselated. |
91 |
A zero length normal (i.e., 0 0 0) will generate a syntax error. |
92 |
.TP |
93 |
.BI vt " u v" |
94 |
A local vertex texture coordinate. |
95 |
These coordinates will be interpolated and passed |
96 |
to the "Lu" and "Lv" variables during rendering. |
97 |
Local coordinates can extend over any desired range of values. |
98 |
.TP |
99 |
.BI f " v1/t1/n1 v2/t2/n2 v3/t3/n3" " .." |
100 |
A polygonal face. |
101 |
Polygon vertices are specified as three indices separated |
102 |
by slashes ('/'). |
103 |
The first index is the vertex location, the |
104 |
second index is the local (u,v) texture coordinate, and the |
105 |
third index is the vertex surface normal. |
106 |
Positive indices count from the beginning of the input, |
107 |
where the first vertex position ( |
108 |
.I v |
109 |
statement) is numbered 1, and likewise |
110 |
for the first texture coordinate and the first surface normal. |
111 |
Negative indices count backward from the current position in |
112 |
the input, where -1 is the last vertex encountered, -2 |
113 |
is the one before that, etc. |
114 |
An index of 0 may be used for the vertex texture or normal to |
115 |
indicate none, or these may be left off entirely. |
116 |
All faces will be broken into triangles in the final mesh. |
117 |
.I Obj2mesh |
118 |
currently makes an unsafe assumption that faces are convex, |
119 |
which may result in odd results if they are not. |
120 |
.PP |
121 |
All other statement types will be ignored on the input. |
122 |
Statements understood by |
123 |
.I obj2rad(1) |
124 |
will be ignored silently; other statements will generate |
125 |
a warning message after translation to indicate how much was missed. |
126 |
.SH DIAGNOSTICS |
127 |
There are four basic error types reported by obj2mesh: |
128 |
.IP |
129 |
warning - a non-fatal input-related error |
130 |
.IP |
131 |
fatal - an unrecoverable input-related error |
132 |
.IP |
133 |
system - a system-related error |
134 |
.IP |
135 |
internal - a fatal error related to program limitations |
136 |
.IP |
137 |
consistency - a program-caused error |
138 |
.PP |
139 |
Most errors are self-explanatory. |
140 |
However, the following internal errors should be mentioned: |
141 |
.IP "Set overflow in addobject (id)" |
142 |
This error occurs when too many surfaces are close together in a |
143 |
scene. |
144 |
Sometimes a dense mesh can be accommodated by increasing |
145 |
the maximum resolution (by powers of two) using the |
146 |
.I \-r |
147 |
option, but usually this error indicates something is wrong. |
148 |
Either too many surfaces are lying right on top of each other, |
149 |
or the bounding cube is inflated from disparate geometry |
150 |
in the input. |
151 |
Chances are, the face number "id" is near |
152 |
those causing the problem. |
153 |
.IP "Hash table overflow in fullnode" |
154 |
This error is caused by too many surfaces, and there is |
155 |
little hope of compiling this mesh. |
156 |
.SH EXAMPLE |
157 |
To create a compiled triangle mesh from the scene file mesh.obj: |
158 |
.IP "" .2i |
159 |
oconv mesh.obj mesh.rtm |
160 |
.SH AUTHOR |
161 |
Greg Ward |
162 |
.SH "SEE ALSO" |
163 |
gensurf(1), getinfo(1), make(1), obj2rad(1), |
164 |
oconv(1), rpict(1), rview(1), rtrace(1), xform(1) |
