1 |
greg |
1.8 |
.\" RCSid "$Id: obj2mesh.1,v 1.7 2004/02/01 22:31:19 greg Exp $" |
2 |
greg |
1.1 |
.TH OBJ2MESH 1 03/11/03 RADIANCE |
3 |
.SH NAME |
4 |
obj2mesh - create a compiled RADIANCE mesh file from Wavefront .OBJ input |
5 |
.SH SYNOPSIS |
6 |
.B obj2mesh |
7 |
8 |
greg |
1.8 |
.B "\-a matfile" |
9 |
10 |
.B "\-l matlib" |
11 |
greg |
1.3 |
12 |
greg |
1.1 |
.B "\-n objlim" |
13 |
14 |
.B "\-r maxres" |
15 |
16 |
.B \-w |
17 |
18 |
19 |
.B "input.obj" |
20 |
21 |
.B "output.rtm" |
22 |
23 |
24 |
.SH DESCRIPTION |
25 |
.I Obj2mesh |
26 |
reads a Wavefront .OBJ file from |
27 |
.I input.obj |
28 |
(or the standard input) and compiles it into a RADIANCE triangle mesh, |
29 |
which is sent to |
30 |
.I output.rtm |
31 |
(or standard output). |
32 |
greg |
1.3 |
Any RADIANCE material descriptions included via one or more |
33 |
.I \-a |
34 |
options will be compiled and stored in the mesh as well. |
35 |
greg |
1.8 |
If the |
36 |
.I \-l |
37 |
option is used to specify a material file, the RADIANCE library |
38 |
locations are searched. |
39 |
greg |
1.1 |
This mesh may be included in a RADIANCE scene description via the |
40 |
.I mesh |
41 |
primitive, thus: |
42 |
.IP "" .2i |
43 |
mod mesh id |
44 |
.br |
45 |
1+ output.rtm [xform args] |
46 |
.br |
47 |
0 |
48 |
.br |
49 |
0 |
50 |
.PP |
51 |
greg |
1.2 |
The syntax and semantics are identical to the RADIANCE |
52 |
greg |
1.1 |
.I instance |
53 |
greg |
1.3 |
primitive. |
54 |
If |
55 |
.I mod |
56 |
is "void", then the stored mesh materials will be applied during rendering. |
57 |
Otherwise, the given material will be substituted on |
58 |
all the mesh surfaces. |
59 |
greg |
1.1 |
.PP |
60 |
The |
61 |
.I \-n |
62 |
option specifies the maximum surface set size for |
63 |
each voxel. |
64 |
Larger numbers result in quicker mesh generation needing |
65 |
less memory, but potentially slower rendering. |
66 |
Smaller values may produce faster renderings, |
67 |
since the default number (15) is on the high side to reduce |
68 |
the compiled mesh octree size. |
69 |
greg |
1.2 |
Values below 6 are not recommended, since this is the median |
70 |
valence for a mesh vertex (the number of adjacent faces), |
71 |
and smaller values will result in pointless octree subdivision. |
72 |
greg |
1.1 |
.PP |
73 |
The |
74 |
.I \-r |
75 |
option specifies the maximum octree resolution. |
76 |
This should be greater than or equal to the ratio of the mesh bounding |
77 |
box to the smallest triangle. |
78 |
The default is 16384. |
79 |
.PP |
80 |
The |
81 |
.I \-w |
82 |
option suppresses warnings. |
83 |
.PP |
84 |
Although the mesh file format is binary, it is meant to be portable |
85 |
between machines. |
86 |
The only limitation is that machines with radically different integer |
87 |
sizes will not work together. |
88 |
greg |
1.2 |
.SH DETAILS |
89 |
The following Wavefront statements are understood and compiled by |
90 |
.I obj2mesh. |
91 |
.TP 10n |
92 |
.BI v " x y z" |
93 |
A vertex location, given by its Cartesian coordinates. |
94 |
The final mesh position may of course be modified by |
95 |
the transform arguments given to the |
96 |
.I mesh |
97 |
primitive in the Radiance scene description. |
98 |
.TP |
99 |
.BI vn " dx dy dz" |
100 |
A vertex normal vector, given by its three |
101 |
direction components, which will be normalized by |
102 |
.I obj2mesh. |
103 |
Normals will be interpolated over the mesh |
104 |
during rendering to produce a smooth surface. |
105 |
greg |
1.7 |
If no vertex normals are present, the mesh will appear tesselated. |
106 |
greg |
1.2 |
A zero length normal (i.e., 0 0 0) will generate a syntax error. |
107 |
.TP |
108 |
.BI vt " u v" |
109 |
A local vertex texture coordinate. |
110 |
These coordinates will be interpolated and passed |
111 |
to the "Lu" and "Lv" variables during rendering. |
112 |
Local coordinates can extend over any desired range of values. |
113 |
greg |
1.3 |
.TP |
114 |
.BI usemtl " mname" |
115 |
A material name. |
116 |
The following faces will use the named material, which is |
117 |
taken from the material definitions in the |
118 |
.I \-a |
119 |
input file(s). |
120 |
.TP |
121 |
.BI g " gname" |
122 |
Group association. |
123 |
The following faces are associated with the named group. |
124 |
If no "usemtl" statement has been |
125 |
encountered, the current group is used for the surface material |
126 |
identifier. |
127 |
greg |
1.2 |
.TP |
128 |
.BI f " v1/t1/n1 v2/t2/n2 v3/t3/n3" " .." |
129 |
A polygonal face. |
130 |
Polygon vertices are specified as three indices separated |
131 |
by slashes ('/'). |
132 |
The first index is the vertex location, the |
133 |
second index is the local (u,v) texture coordinate, and the |
134 |
third index is the vertex surface normal. |
135 |
Positive indices count from the beginning of the input, |
136 |
where the first vertex position ( |
137 |
.I v |
138 |
statement) is numbered 1, and likewise |
139 |
for the first texture coordinate and the first surface normal. |
140 |
Negative indices count backward from the current position in |
141 |
the input, where -1 is the last vertex encountered, -2 |
142 |
is the one before that, etc. |
143 |
An index of 0 may be used for the vertex texture or normal to |
144 |
indicate none, or these may be left off entirely. |
145 |
All faces will be broken into triangles in the final mesh. |
146 |
.I Obj2mesh |
147 |
currently makes an unsafe assumption that faces are convex, |
148 |
which may result in odd results if they are not. |
149 |
.PP |
150 |
All other statement types will be ignored on the input. |
151 |
Statements understood by |
152 |
.I obj2rad(1) |
153 |
will be ignored silently; other statements will generate |
154 |
a warning message after translation to indicate how much was missed. |
155 |
greg |
1.1 |
.SH DIAGNOSTICS |
156 |
There are four basic error types reported by obj2mesh: |
157 |
.IP |
158 |
warning - a non-fatal input-related error |
159 |
.IP |
160 |
fatal - an unrecoverable input-related error |
161 |
.IP |
162 |
system - a system-related error |
163 |
.IP |
164 |
internal - a fatal error related to program limitations |
165 |
.IP |
166 |
consistency - a program-caused error |
167 |
.PP |
168 |
Most errors are self-explanatory. |
169 |
However, the following internal errors should be mentioned: |
170 |
.IP "Set overflow in addobject (id)" |
171 |
This error occurs when too many surfaces are close together in a |
172 |
scene. |
173 |
greg |
1.2 |
Sometimes a dense mesh can be accommodated by increasing |
174 |
greg |
1.1 |
the maximum resolution (by powers of two) using the |
175 |
.I \-r |
176 |
option, but usually this error indicates something is wrong. |
177 |
Either too many surfaces are lying right on top of each other, |
178 |
or the bounding cube is inflated from disparate geometry |
179 |
in the input. |
180 |
Chances are, the face number "id" is near |
181 |
those causing the problem. |
182 |
.IP "Hash table overflow in fullnode" |
183 |
This error is caused by too many surfaces, and there is |
184 |
little hope of compiling this mesh. |
185 |
greg |
1.7 |
.SH EXAMPLES |
186 |
greg |
1.5 |
To create a compiled triangle mesh from the scene file mesh.obj |
187 |
using materials from the file mesh.mat: |
188 |
greg |
1.1 |
.IP "" .2i |
189 |
greg |
1.5 |
obj2mesh -a mesh.mat mesh.obj mesh.rtm |
190 |
greg |
1.7 |
.PP |
191 |
To use local coordinates to place a square tiled image on a mesh object: |
192 |
.sp |
193 |
.nf |
194 |
void colorpict tiled_pat |
195 |
7 red green blue mytile.pic . frac(Lu) frac(Lv) |
196 |
0 |
197 |
0 |
198 |
199 |
tiled_pat plastic tiled_mat |
200 |
0 |
201 |
0 |
202 |
5 .9 .9 .9 0 0 |
203 |
204 |
tiled_mat mesh tiled_mesh |
205 |
1 mymesh.rtm |
206 |
0 |
207 |
0 |
208 |
.fi |
209 |
greg |
1.8 |
.SH ENVIRONMENT |
210 |
RAYPATH the directories to search for material files. |
211 |
greg |
1.1 |
.SH AUTHOR |
212 |
Greg Ward |
213 |
.SH "SEE ALSO" |
214 |
greg |
1.2 |
gensurf(1), getinfo(1), make(1), obj2rad(1), |
215 |
greg |
1.6 |
oconv(1), rpict(1), rvu(1), rtrace(1), xform(1) |
