1 |
.\" RCSid "$Id" |
2 |
.TH OBJ2MESH 1 03/11/03 RADIANCE |
3 |
.SH NAME |
4 |
obj2mesh - create a compiled RADIANCE mesh file from Wavefront .OBJ input |
5 |
.SH SYNOPSIS |
6 |
.B obj2mesh |
7 |
8 |
.B "\-n objlim" |
9 |
10 |
.B "\-r maxres" |
11 |
12 |
.B \-w |
13 |
14 |
15 |
.B "input.obj" |
16 |
17 |
.B "output.rtm" |
18 |
19 |
20 |
.SH DESCRIPTION |
21 |
.I Obj2mesh |
22 |
reads a Wavefront .OBJ file from |
23 |
.I input.obj |
24 |
(or the standard input) and compiles it into a RADIANCE triangle mesh, |
25 |
which is sent to |
26 |
.I output.rtm |
27 |
(or standard output). |
28 |
This mesh may be included in a RADIANCE scene description via the |
29 |
.I mesh |
30 |
primitive, thus: |
31 |
.IP "" .2i |
32 |
mod mesh id |
33 |
.br |
34 |
1+ output.rtm [xform args] |
35 |
.br |
36 |
0 |
37 |
.br |
38 |
0 |
39 |
.PP |
40 |
The syntax and semantics are nearly identical to the RADIANCE |
41 |
.I instance |
42 |
primitive, except that the mesh modifier may not be "void", since |
43 |
materials are not included in a compiled mesh file. |
44 |
.PP |
45 |
The |
46 |
.I \-n |
47 |
option specifies the maximum surface set size for |
48 |
each voxel. |
49 |
Larger numbers result in quicker mesh generation needing |
50 |
less memory, but potentially slower rendering. |
51 |
Smaller values may produce faster renderings, |
52 |
since the default number (15) is on the high side to reduce |
53 |
the compiled mesh octree size. |
54 |
Values below 6 are not recommended, since the median |
55 |
valence (number of adjacent faces) for a mesh vertex is 6, |
56 |
and smaller limits will result in pointless octree subdivision. |
57 |
.PP |
58 |
The |
59 |
.I \-r |
60 |
option specifies the maximum octree resolution. |
61 |
This should be greater than or equal to the ratio of the mesh bounding |
62 |
box to the smallest triangle. |
63 |
The default is 16384. |
64 |
.PP |
65 |
The |
66 |
.I \-w |
67 |
option suppresses warnings. |
68 |
.PP |
69 |
Although the mesh file format is binary, it is meant to be portable |
70 |
between machines. |
71 |
The only limitation is that machines with radically different integer |
72 |
sizes will not work together. |
73 |
.SH DIAGNOSTICS |
74 |
There are four basic error types reported by obj2mesh: |
75 |
.IP |
76 |
warning - a non-fatal input-related error |
77 |
.IP |
78 |
fatal - an unrecoverable input-related error |
79 |
.IP |
80 |
system - a system-related error |
81 |
.IP |
82 |
internal - a fatal error related to program limitations |
83 |
.IP |
84 |
consistency - a program-caused error |
85 |
.PP |
86 |
Most errors are self-explanatory. |
87 |
However, the following internal errors should be mentioned: |
88 |
.IP "Set overflow in addobject (id)" |
89 |
This error occurs when too many surfaces are close together in a |
90 |
scene. |
91 |
Sometimes a dense mesh can be accomodated by increasing |
92 |
the maximum resolution (by powers of two) using the |
93 |
.I \-r |
94 |
option, but usually this error indicates something is wrong. |
95 |
Either too many surfaces are lying right on top of each other, |
96 |
or the bounding cube is inflated from disparate geometry |
97 |
in the input. |
98 |
Chances are, the face number "id" is near |
99 |
those causing the problem. |
100 |
.IP "Hash table overflow in fullnode" |
101 |
This error is caused by too many surfaces, and there is |
102 |
little hope of compiling this mesh. |
103 |
.SH EXAMPLE |
104 |
To create a compiled triangle mesh from the scene file mesh.obj: |
105 |
.IP "" .2i |
106 |
oconv mesh.obj mesh.rtm |
107 |
.SH AUTHOR |
108 |
Greg Ward |
109 |
.SH "SEE ALSO" |
110 |
gensurf(1), getinfo(1), make(1), |
111 |
oconv(1), rpict(1), rview(1), rtrace(1), xform(1) |
