root/Development/ray/doc/man/man1/obj2mesh.1
Mon Mar 30 18:28:35 2020 UTC (5 years, 8 months ago) by greg
CVS Tags: HEAD, rad5R3, rad5R4, rad6R0
Changes since 1.13: +2 -2 lines
Diff to previous 1.13 , to selected 1.7
Fri Mar 3 01:25:27 2017 UTC (8 years, 9 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 1.12: +6 -1 lines
Diff to previous 1.12 , to selected 1.7
Added -v option to obj2mesh for reporting mesh statistics
Fri Jan 24 01:26:44 2014 UTC (11 years, 10 months ago) by greg
Changes since 1.11: +1 -4 lines
Diff to previous 1.11 , to selected 1.7
Mon Nov 10 19:08:17 2008 UTC (17 years, 1 month ago) by greg
CVS Tags: rad4R0, rad4R1
Diff to previous 1.10 , to selected 1.7
Tue Sep 4 17:36:40 2007 UTC (18 years, 3 months ago) by greg
Diff to previous 1.9 , to selected 1.7
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Thu Jul 12 14:58:52 2007 UTC (18 years, 5 months ago) by greg
Changes since 1.8: +4 -6 lines
Diff to previous 1.8 , to selected 1.7
Decreased default -n setting in obj2mesh from 15 to 9
Fri Apr 23 00:56:27 2004 UTC (21 years, 7 months ago) by greg
Changes since 1.7: +10 -2 lines
Diff to previous 1.7
Revision 1.7 - (view) (download) (annotate) - [selected]
Sun Feb 1 22:31:19 2004 UTC (21 years, 10 months ago) by greg
Changes since 1.6: +22 -3 lines
Diff to previous 1.6
Added example of tiled texture
Thu Jan 1 19:31:45 2004 UTC (21 years, 11 months ago) by greg
Mon Dec 15 17:14:28 2003 UTC (22 years ago) by greg
Changes since 1.4: +4 -3 lines
Typo correction -- oconv was where obj2mesh should have been!
Tue Dec 9 15:59:06 2003 UTC (22 years ago) by greg
Fixed RCSid specification
Fri Mar 14 21:27:45 2003 UTC (22 years, 9 months ago) by greg
Changes since 1.2: +25 -2 lines
Wed Mar 12 17:26:58 2003 UTC (22 years, 9 months ago) by greg
Changes since 1.1: +59 -6 lines
Tue Mar 11 22:48:20 2003 UTC (22 years, 9 months ago) by greg
Diff to selected 1.7
