root/radiance/ray/doc/man/man1/normtiff.1
Revision: 1.8
Committed: Wed Oct 2 15:58:56 2024 UTC (8 months, 2 weeks ago) by greg
Changes since 1.7: +6 -4 lines
feat(normtiff): Added ability to ingest hyperspectral radiance pictures
1 .\" RCSid $Id: normtiff.1,v 1.7 2021/04/07 21:13:52 greg Exp $
2 .TH NORMTIFF 1 2/25/99 RADIANCE
3 .SH NAME
4 normtiff - tone-map and convert RADIANCE picture or HDR TIFF to standard TIFF
5 .SH SYNOPSIS
6 .B normtiff
7 [
8 .B options
9 ]
10 .B input
11 .B output.tif
12 .SH DESCRIPTION
13 .I Normtiff
14 prepares a Radiance picture or high dynamic-range TIFF
15 for output to a display or hard copy device.
16 If the dynamic range of the scene exceeds that of the display (as is
17 usually the case),
18 .I normtiff
19 will compress the dynamic range of the picture such that both
20 dark and bright regions are visible.
21 In addition, certain limitations in human vision may be mimicked in
22 order to provide an appearance similar to the experience one might
23 have in the actual scene.
24 .PP
25 Output is always an uncompressed RGB TIFF, which must be named
26 on the command line along with the input file.
27 If the input file has a ".tif" or ".tiff" extension,
28 .I normtiff
29 attempts to read it as a TIFF.
30 Otherwise,
31 .I normtiff
32 first tries opening it as a RADIANCE picture, only opening it
33 as a TIFF if it fails header inspection.
34 (See the
35 .I getinfo(1)
36 program.)\0
37 If the input is neither a RADIANCE picture nor a high dynamic-range TIFF,
38 the program reports an error and exits.
39 Hyperspectral radiance pictures are silently converted to RGB, though
40 the colors will be more accurate if the HSR picture is passed through
41 .I ra_xyze(1),
42 first.
43 .PP
44 The following command line options are understood.
45 Since this program is very similar to
46 .I pcond(1),
47 several of the switches are identical.
48 .TP 10n
49 .BR -b
50 Toggle 8-bit black and white (grayscale) TIFF output.
51 If the input is a grayscale TIFF, this switch is
52 automatically selected.
53 Otherwise, the output defaults to 24-bit RGB.
54 .TP
55 .BR -z
56 Output LZW-compressed TIFF (smaller file).
57 .TP
58 .BR -h
59 Mimic human visual response in the output.
60 The goal of this process is to produce output that correlates
61 strongly with a person's subjective impression of a scene.
62 This switch turns on both the
63 .I \-s
64 and
65 .I \-c
66 switches, described below.
67 .TP
68 .BR -s
69 Toggle the use of the human contrast sensitivity function in determining the
70 exposure for the image.
71 A darker scene will have relatively lower exposure with lower
72 contrast than a well-lit scene.
73 .TP
74 .BR -c
75 Toggle mesopic color correction.
76 If parts of the image are in the mesopic or scotopic range where
77 the cone photoreceptors lose their efficiency, this switch will
78 cause a corresponding loss of color visibility in the output and a
79 shift to a scotopic (blue-dominant) response function.
80 .TP
81 .BR -l
82 Toggle the use of a linear response function versus the standard dynamic
83 range compression algorithm.
84 This may make some parts of the resulting image too
85 dark or too bright to see.
86 .TP
87 .BI -u \ Ldmax
88 Specifies the top of the luminance range for the target output device.
89 That is, the luminance (in candelas/m^2) for an output pixel value
90 of (R,G,B)=(255,255,255).
91 This parameter affects tone mapping only when the
92 .I \-s
93 switch is on.
94 The default value is 100 cd/m^2.
95 .TP
96 .BI -d \ Lddyn
97 Specifies the dynamic range for the target output device, which is
98 the ratio of the maximum and minimum usable display luminances.
99 The default value is 100, which is typical for LCD monitors.
100 .TP
101 .BI -p " xr yr xg yg xb yb xw yw"
102 Specifies the RGB primaries for the target output device.
103 These are the 1931 CIE (x,y) chromaticity values for red, green,
104 blue and white, respectively.
105 .TP
106 .BI -g \ gamma
107 Specifies the output device gamma correction value.
108 The default value is 2.2, which is appropriate for most CRT monitors.
109 (A value of 1.8 is common in color prepress and color printers.)\0
110 .SH EXAMPLES
111 To convert a RADIANCE picture to an 8-bit grayscale TIFF:
112 .IP "" .2i
113 normtiff \-b scene.hdr sceneb.tif
114 .PP
115 To condition a high dynamic-range TIFF for a particular film recorder with
116 known color primaries, dynamic range and gamma response:
117 .IP "" .2i
118 pcond \-d 50 \-g 2.5 \-p .580 .340 .281 .570 .153 .079 .333 .333 orig.tif filmrgb.tif
119 .PP
120 To simulate human visual response on a monitor with known maximum luminance:
121 .IP "" .2i
122 normtiff \-h \-u 80 scene.hdr sceneh.tif
123 .SH REFERENCE
124 Greg Ward Larson, Holly Rushmeier, Christine Piatko,
125 ``A Visibility Matching Tone Reproduction Operator for High Dynamic Range
126 Scenes,''
127 .I "IEEE Transactions on Visualization and Computer Graphics",
128 December 1997.
129 .PP
130 http://positron.cs.berkeley.edu/gwlarson/pixformat/
131 .SH AUTHOR
132 Greg Ward
133 .SH "SEE ALSO"
134 getinfo(1), pcond(1), pflip(1),
135 pvalue(1), protate(1), ra_xyze(1), rpict(1), ximage(1)
