root/Development/ray/doc/man/man1/normtiff.1
Revision: 1.8
Committed: Wed Oct 2 15:58:56 2024 UTC (12 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 1.7: +6 -4 lines
feat(normtiff): Added ability to ingest hyperspectral radiance pictures
# User Rev Content
1 greg 1.8 .\" RCSid $Id: normtiff.1,v 1.7 2021/04/07 21:13:52 greg Exp $
2 greg 1.1 .TH NORMTIFF 1 2/25/99 RADIANCE
3     .SH NAME
4 greg 1.2 normtiff - tone-map and convert RADIANCE picture or HDR TIFF to standard TIFF
5 greg 1.1 .SH SYNOPSIS
6     .B normtiff
7     [
8     .B options
9     ]
10     .B input
11     .B output.tif
12     .SH DESCRIPTION
13     .I Normtiff
14 greg 1.2 prepares a Radiance picture or high dynamic-range TIFF
15 greg 1.1 for output to a display or hard copy device.
16     If the dynamic range of the scene exceeds that of the display (as is
17     usually the case),
18     .I normtiff
19     will compress the dynamic range of the picture such that both
20     dark and bright regions are visible.
21     In addition, certain limitations in human vision may be mimicked in
22     order to provide an appearance similar to the experience one might
23     have in the actual scene.
24     .PP
25     Output is always an uncompressed RGB TIFF, which must be named
26     on the command line along with the input file.
27     If the input file has a ".tif" or ".tiff" extension,
28     .I normtiff
29     attempts to read it as a TIFF.
30     Otherwise,
31     .I normtiff
32     first tries opening it as a RADIANCE picture, only opening it
33     as a TIFF if it fails header inspection.
34     (See the
35     .I getinfo(1)
36     program.)\0
37 greg 1.2 If the input is neither a RADIANCE picture nor a high dynamic-range TIFF,
38 greg 1.1 the program reports an error and exits.
39 greg 1.8 Hyperspectral radiance pictures are silently converted to RGB, though
40     the colors will be more accurate if the HSR picture is passed through
41     .I ra_xyze(1),
42     first.
43 greg 1.1 .PP
44     The following command line options are understood.
45     Since this program is very similar to
46     .I pcond(1),
47     several of the switches are identical.
48     .TP 10n
49     .BR -b
50     Toggle 8-bit black and white (grayscale) TIFF output.
51 greg 1.2 If the input is a grayscale TIFF, this switch is
52 greg 1.1 automatically selected.
53     Otherwise, the output defaults to 24-bit RGB.
54     .TP
55 greg 1.3 .BR -z
56     Output LZW-compressed TIFF (smaller file).
57     .TP
58 greg 1.1 .BR -h
59     Mimic human visual response in the output.
60     The goal of this process is to produce output that correlates
61     strongly with a person's subjective impression of a scene.
62     This switch turns on both the
63     .I \-s
64     and
65     .I \-c
66     switches, described below.
67     .TP
68     .BR -s
69     Toggle the use of the human contrast sensitivity function in determining the
70     exposure for the image.
71     A darker scene will have relatively lower exposure with lower
72     contrast than a well-lit scene.
73     .TP
74     .BR -c
75     Toggle mesopic color correction.
76     If parts of the image are in the mesopic or scotopic range where
77     the cone photoreceptors lose their efficiency, this switch will
78     cause a corresponding loss of color visibility in the output and a
79     shift to a scotopic (blue-dominant) response function.
80     .TP
81     .BR -l
82     Toggle the use of a linear response function versus the standard dynamic
83     range compression algorithm.
84     This may make some parts of the resulting image too
85     dark or too bright to see.
86     .TP
87     .BI -u \ Ldmax
88     Specifies the top of the luminance range for the target output device.
89     That is, the luminance (in candelas/m^2) for an output pixel value
90     of (R,G,B)=(255,255,255).
91     This parameter affects tone mapping only when the
92     .I \-s
93     switch is on.
94     The default value is 100 cd/m^2.
95     .TP
96     .BI -d \ Lddyn
97     Specifies the dynamic range for the target output device, which is
98     the ratio of the maximum and minimum usable display luminances.
99 greg 1.7 The default value is 100, which is typical for LCD monitors.
100 greg 1.1 .TP
101     .BI -p " xr yr xg yg xb yb xw yw"
102     Specifies the RGB primaries for the target output device.
103     These are the 1931 CIE (x,y) chromaticity values for red, green,
104     blue and white, respectively.
105     .TP
106     .BI -g \ gamma
107     Specifies the output device gamma correction value.
108     The default value is 2.2, which is appropriate for most CRT monitors.
109     (A value of 1.8 is common in color prepress and color printers.)\0
110     .SH EXAMPLES
111     To convert a RADIANCE picture to an 8-bit grayscale TIFF:
112     .IP "" .2i
113 greg 1.5 normtiff \-b scene.hdr sceneb.tif
114 greg 1.1 .PP
115 greg 1.2 To condition a high dynamic-range TIFF for a particular film recorder with
116 greg 1.1 known color primaries, dynamic range and gamma response:
117     .IP "" .2i
118 greg 1.4 pcond \-d 50 \-g 2.5 \-p .580 .340 .281 .570 .153 .079 .333 .333 orig.tif filmrgb.tif
119 greg 1.1 .PP
120     To simulate human visual response on a monitor with known maximum luminance:
121     .IP "" .2i
122 greg 1.5 normtiff \-h \-u 80 scene.hdr sceneh.tif
123 greg 1.1 .SH REFERENCE
124     Greg Ward Larson, Holly Rushmeier, Christine Piatko,
125     ``A Visibility Matching Tone Reproduction Operator for High Dynamic Range
126     Scenes,''
127     .I "IEEE Transactions on Visualization and Computer Graphics",
128     December 1997.
129     .PP
130     http://positron.cs.berkeley.edu/gwlarson/pixformat/
131     .SH AUTHOR
132 greg 1.8 Greg Ward
133 greg 1.1 .SH "SEE ALSO"
134     getinfo(1), pcond(1), pflip(1),
135     pvalue(1), protate(1), ra_xyze(1), rpict(1), ximage(1)
