1 |
greg |
1.8 |
.\" RCSid $Id: normtiff.1,v 1.7 2021/04/07 21:13:52 greg Exp $ |
2 |
greg |
1.1 |
.TH NORMTIFF 1 2/25/99 RADIANCE |
3 |
.SH NAME |
4 |
greg |
1.2 |
normtiff - tone-map and convert RADIANCE picture or HDR TIFF to standard TIFF |
5 |
greg |
1.1 |
.SH SYNOPSIS |
6 |
.B normtiff |
7 |
8 |
.B options |
9 |
10 |
.B input |
11 |
.B output.tif |
12 |
.SH DESCRIPTION |
13 |
.I Normtiff |
14 |
greg |
1.2 |
prepares a Radiance picture or high dynamic-range TIFF |
15 |
greg |
1.1 |
for output to a display or hard copy device. |
16 |
If the dynamic range of the scene exceeds that of the display (as is |
17 |
usually the case), |
18 |
.I normtiff |
19 |
will compress the dynamic range of the picture such that both |
20 |
dark and bright regions are visible. |
21 |
In addition, certain limitations in human vision may be mimicked in |
22 |
order to provide an appearance similar to the experience one might |
23 |
have in the actual scene. |
24 |
.PP |
25 |
Output is always an uncompressed RGB TIFF, which must be named |
26 |
on the command line along with the input file. |
27 |
If the input file has a ".tif" or ".tiff" extension, |
28 |
.I normtiff |
29 |
attempts to read it as a TIFF. |
30 |
Otherwise, |
31 |
.I normtiff |
32 |
first tries opening it as a RADIANCE picture, only opening it |
33 |
as a TIFF if it fails header inspection. |
34 |
(See the |
35 |
.I getinfo(1) |
36 |
program.)\0 |
37 |
greg |
1.2 |
If the input is neither a RADIANCE picture nor a high dynamic-range TIFF, |
38 |
greg |
1.1 |
the program reports an error and exits. |
39 |
greg |
1.8 |
Hyperspectral radiance pictures are silently converted to RGB, though |
40 |
the colors will be more accurate if the HSR picture is passed through |
41 |
.I ra_xyze(1), |
42 |
first. |
43 |
greg |
1.1 |
.PP |
44 |
The following command line options are understood. |
45 |
Since this program is very similar to |
46 |
.I pcond(1), |
47 |
several of the switches are identical. |
48 |
.TP 10n |
49 |
.BR -b |
50 |
Toggle 8-bit black and white (grayscale) TIFF output. |
51 |
greg |
1.2 |
If the input is a grayscale TIFF, this switch is |
52 |
greg |
1.1 |
automatically selected. |
53 |
Otherwise, the output defaults to 24-bit RGB. |
54 |
.TP |
55 |
greg |
1.3 |
.BR -z |
56 |
Output LZW-compressed TIFF (smaller file). |
57 |
.TP |
58 |
greg |
1.1 |
.BR -h |
59 |
Mimic human visual response in the output. |
60 |
The goal of this process is to produce output that correlates |
61 |
strongly with a person's subjective impression of a scene. |
62 |
This switch turns on both the |
63 |
.I \-s |
64 |
and |
65 |
.I \-c |
66 |
switches, described below. |
67 |
.TP |
68 |
.BR -s |
69 |
Toggle the use of the human contrast sensitivity function in determining the |
70 |
exposure for the image. |
71 |
A darker scene will have relatively lower exposure with lower |
72 |
contrast than a well-lit scene. |
73 |
.TP |
74 |
.BR -c |
75 |
Toggle mesopic color correction. |
76 |
If parts of the image are in the mesopic or scotopic range where |
77 |
the cone photoreceptors lose their efficiency, this switch will |
78 |
cause a corresponding loss of color visibility in the output and a |
79 |
shift to a scotopic (blue-dominant) response function. |
80 |
.TP |
81 |
.BR -l |
82 |
Toggle the use of a linear response function versus the standard dynamic |
83 |
range compression algorithm. |
84 |
This may make some parts of the resulting image too |
85 |
dark or too bright to see. |
86 |
.TP |
87 |
.BI -u \ Ldmax |
88 |
Specifies the top of the luminance range for the target output device. |
89 |
That is, the luminance (in candelas/m^2) for an output pixel value |
90 |
of (R,G,B)=(255,255,255). |
91 |
This parameter affects tone mapping only when the |
92 |
.I \-s |
93 |
switch is on. |
94 |
The default value is 100 cd/m^2. |
95 |
.TP |
96 |
.BI -d \ Lddyn |
97 |
Specifies the dynamic range for the target output device, which is |
98 |
the ratio of the maximum and minimum usable display luminances. |
99 |
greg |
1.7 |
The default value is 100, which is typical for LCD monitors. |
100 |
greg |
1.1 |
.TP |
101 |
.BI -p " xr yr xg yg xb yb xw yw" |
102 |
Specifies the RGB primaries for the target output device. |
103 |
These are the 1931 CIE (x,y) chromaticity values for red, green, |
104 |
blue and white, respectively. |
105 |
.TP |
106 |
.BI -g \ gamma |
107 |
Specifies the output device gamma correction value. |
108 |
The default value is 2.2, which is appropriate for most CRT monitors. |
109 |
(A value of 1.8 is common in color prepress and color printers.)\0 |
110 |
.SH EXAMPLES |
111 |
To convert a RADIANCE picture to an 8-bit grayscale TIFF: |
112 |
.IP "" .2i |
113 |
greg |
1.5 |
normtiff \-b scene.hdr sceneb.tif |
114 |
greg |
1.1 |
.PP |
115 |
greg |
1.2 |
To condition a high dynamic-range TIFF for a particular film recorder with |
116 |
greg |
1.1 |
known color primaries, dynamic range and gamma response: |
117 |
.IP "" .2i |
118 |
greg |
1.4 |
pcond \-d 50 \-g 2.5 \-p .580 .340 .281 .570 .153 .079 .333 .333 orig.tif filmrgb.tif |
119 |
greg |
1.1 |
.PP |
120 |
To simulate human visual response on a monitor with known maximum luminance: |
121 |
.IP "" .2i |
122 |
greg |
1.5 |
normtiff \-h \-u 80 scene.hdr sceneh.tif |
123 |
greg |
1.1 |
.SH REFERENCE |
124 |
Greg Ward Larson, Holly Rushmeier, Christine Piatko, |
125 |
``A Visibility Matching Tone Reproduction Operator for High Dynamic Range |
126 |
Scenes,'' |
127 |
.I "IEEE Transactions on Visualization and Computer Graphics", |
128 |
December 1997. |
129 |
.PP |
130 |
http://positron.cs.berkeley.edu/gwlarson/pixformat/ |
131 |
.SH AUTHOR |
132 |
greg |
1.8 |
Greg Ward |
133 |
greg |
1.1 |
.SH "SEE ALSO" |
134 |
getinfo(1), pcond(1), pflip(1), |
135 |
pvalue(1), protate(1), ra_xyze(1), rpict(1), ximage(1) |
