root/radiance/ray/doc/man/man1/normpat.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (21 years, 3 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH NORMPAT 1 11/15/93 RADIANCE
3 .SH NAME
4 normpat - normalize RADIANCE pictures for use as patterns.
5 .SH SYNOPSIS
6 .B normpat
7 [
8 .B \-v
9 ][
10 .B \-b
11 ][
12 .B \-f
13 ][
14 .B "\-r maxres"
15 ]
16 .B "picture .."
17 .SH DESCRIPTION
18 .I Normpat
19 normalizes one or more RADIANCE pictures to an average brightness of 1.0
20 and optionally removes fundamental frequencies and blends the edges
21 of the image.
22 The original images are overwritten during this process, and it is
23 recommended that the program work on copies of the pictures for this reason.
24 .PP
25 The
26 .I \-r
27 option can be used to set the maximum horizontal or vertical resolution
28 of the final result, which should not be greater than 256 for most
29 patterns (due to the associated memory burden during rendering).
30 The
31 .I \-f
32 option uses a Fourier transform to remove the lowest frequencies
33 from the image, reducing the noticeability of pattern repitition.
34 The
35 .I \-b
36 option can be used to blend the edges of the image so that when
37 it is tiled, the seams are less apparent.
38 The
39 .I \-v
40 option turns on the verbose flag, which prints on the standard output
41 progress messages as the script runs.
42 .PP
43 .I Normpat
44 is a shell script that makes calls to other RADIANCE programs
45 that do the actual work.
46 .SH AUTHOR
47 Greg Ward
48 .SH "SEE ALSO"
49 getinfo(1), pcomb(1), pcompos(1), pfilt(1), pflip(1), protate(1),
50 psign(1), ra_bn(1), ra_pr(1), ra_t8(1), ra_t16(1), rpict(1)
