root/radiance/ray/doc/man/man1/neaten.1
Revision: 1.3
Committed: Sat Jul 20 00:57:43 2019 UTC (5 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Added mention of rsplit(1)
1 .\" RCSid "$Id: neaten.1,v 1.2 2013/09/05 17:53:22 greg Exp $"
2 .TH NEATEN 1 11/15/93 RADIANCE
3 .SH NAME
4 neaten - neaten up output columns
5 .SH SYNOPSIS
6 .B neaten
7 [
8 .B format
9 ]
10 .SH DESCRIPTION
11 .I Neaten
12 reads from its standard input and neatens up columns separated
13 by white space using the specified format.
14 The format is a string consisting of a positive integer followed
15 by an alignment character and another integer.
16 The alignment character is usually a decimal point ('.'), but it can
17 be any non-digit.
18 .PP
19 The alignment character is used as the central point of each column.
20 The total column field width will be the number to the
21 left of the alignment character plus one for the alignment character
22 itself plus the number to the right of the alignment character.
23 .PP
24 If a field does not contain the alignment character, it will be
25 printed to the left of where the alignment character would have
26 appeared.
27 If a field is too long to print within the specified format, the entire
28 field will be printed and that row will not be aligned with the rest.
29 .PP
30 The default format is "8.8".
31 .SH EXAMPLE
32 To examine a file with columns of numbers:
33 .IP "" .2i
34 neaten 10.8 < input | more
35 .SH BUGS
36 Columns wider than the total width of the format specification
37 will be printed without any separating white space.
38 .PP
39 The program does not do anything special with tabs on the input.
40 .SH AUTHOR
41 Greg Ward
42 .SH "SEE ALSO"
43 cnt(1), rcalc(1), rcollate(1), rlam(1), rsplit(1), total(1)
