1 |
.\" RCSid "$Id$" |
2 |
.TH NEATEN 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
neaten - neaten up output columns |
5 |
.SH SYNOPSIS |
6 |
.B neaten |
7 |
8 |
.B format |
9 |
10 |
.SH DESCRIPTION |
11 |
.I Neaten |
12 |
reads from its standard input and neatens up columns separated |
13 |
by white space using the specified format. |
14 |
The format is a string consisting of a positive integer followed |
15 |
by an alignment character and another integer. |
16 |
The alignment character is usually a decimal point ('.'), but it can |
17 |
be any non-digit. |
18 |
.PP |
19 |
The alignment character is used as the central point of each column. |
20 |
The total column field width will be the number to the |
21 |
left of the alignment character plus one for the alignment character |
22 |
itself plus the number to the right of the alignment character. |
23 |
.PP |
24 |
If a field does not contain the alignment character, it will be |
25 |
printed to the left of where the alignment character would have |
26 |
appeared. |
27 |
If a field is too long to print within the specified format, the entire |
28 |
field will be printed and that row will not be aligned with the rest. |
29 |
.PP |
30 |
The default format is "8.8". |
31 |
.SH EXAMPLE |
32 |
To examine a file with columns of numbers: |
33 |
.IP "" .2i |
34 |
neaten 10.8 < input | more |
35 |
.SH BUGS |
36 |
Columns wider than the total width of the format specification |
37 |
will be printed without any separating white space. |
38 |
.PP |
39 |
The program does not do anything special with tabs on the input. |
40 |
.SH AUTHOR |
41 |
Greg Ward |
42 |
.SH "SEE ALSO" |
43 |
cnt(1), rcalc(1), rlam(1), total(1) |
