| 1 |
greg |
1.1 |
.\" RCSid "$Id"
| 2 |
.TH NEAT 1 11/15/93 RADIANCE
| 3 |
.SH NAME
| 4 |
neat - neaten up output columns
| 5 |
.SH SYNOPSIS
| 6 |
.B neat
| 7 |
| 8 |
.B format
| 9 |
| 10 |
.SH DESCRIPTION
| 11 |
.I Neat
| 12 |
reads from its standard input and neatens up columns separated
| 13 |
by white space using the specified format.
| 14 |
The format is a string consisting of a positive integer followed
| 15 |
by an alignment character and another integer.
| 16 |
The alignment character is usually a decimal point ('.'), but it can
| 17 |
be any non-digit.
| 18 |
.PP
| 19 |
The alignment character is used as the central point of each column.
| 20 |
The total column field width will be the number to the
| 21 |
left of the alignment character plus one for the alignment character
| 22 |
itself plus the number to the right of the alignment character.
| 23 |
.PP
| 24 |
If a field does not contain the alignment character, it will be
| 25 |
printed to the left of where the alignment character would have
| 26 |
appeared.
| 27 |
If a field is too long to print within the specified format, the entire
| 28 |
field will be printed and that row will not be aligned with the rest.
| 29 |
.PP
| 30 |
The default format is "8.8".
| 31 |
.SH EXAMPLE
| 32 |
To examine a file with columns of numbers:
| 33 |
.IP "" .2i
| 34 |
neat 10.8 < input | more
| 35 |
.SH BUGS
| 36 |
Columns wider than the total width of the format specification
| 37 |
will be printed without any separating white space.
| 38 |
.PP
| 39 |
The program does not do anything special with tabs on the input.
| 40 |
.SH AUTHOR
| 41 |
Greg Ward
| 42 |
.SH "SEE ALSO"
| 43 |
cnt(1), lam(1), rcalc(1), total(1)
