1 |
.\" RCSid "$Id: mksource.1,v 1.4 2005/08/19 02:31:07 greg Exp $" |
2 |
.TH MKSOURCE 1 04/11/05 RADIANCE |
3 |
.SH NAME |
4 |
mksource - compute distant sources for RADIANCE image-based lighting |
5 |
.SH SYNOPSIS |
6 |
.B mksource |
7 |
8 |
.B "\-d nsamps" |
9 |
10 |
.B "\-t thresh" |
11 |
12 |
.B "\-a maxang" |
13 |
14 |
15 |
.B octree |
16 |
17 |
.SH DESCRIPTION |
18 |
.I Mksource |
19 |
produces a RADIANCE scene description of distant illum |
20 |
sources corresponding to bright, concentrated regions in |
21 |
the given ambient environment. |
22 |
Any local geometry is ignored in the input octree, which |
23 |
should be derived from a captured light probe and modeled |
24 |
as a distant hemispherical or spherical glow source. |
25 |
The output sources may then be combined with this environment |
26 |
to produce a more efficient scene for rendering, faster and |
27 |
less prone to sampling artifacts. |
28 |
.PP |
29 |
The |
30 |
.I \-d |
31 |
option may be used to specify the number of ray samples, which |
32 |
defaults to 262,000. |
33 |
Calculation time is roughly proportional to this setting, and the |
34 |
default is fine enough to resolve sources the size of the sun |
35 |
(half a degree) or larger. |
36 |
.PP |
37 |
The |
38 |
.I \-t |
39 |
option may be used to manually set the radiance threshold for |
40 |
sources, in watts/sr/meter^2. |
41 |
The default uses the top 2 percentile of the environment, which |
42 |
is usally a good value. |
43 |
.PP |
44 |
The |
45 |
.I \-a |
46 |
option may be used to specify a maximum source diameter, |
47 |
which defaults to 15 degrees. |
48 |
.I Mkillum |
49 |
silently enforces a maximum of 180 degrees for this option. |
50 |
.PP |
51 |
If no input octree is specified, the standard input is read. |
52 |
.SH EXAMPLE |
53 |
To add sources with a maximum size of 20 degrees |
54 |
to the enviornment described in environ.oct: |
55 |
.IP "" .2i |
56 |
mksource \-a 20 environ.oct > srcs.rad |
57 |
.br |
58 |
oconv \-i environ.oct srcs.rad > env+srcs.oct |
59 |
.SH AUTHOR |
60 |
Greg Ward |
61 |
.SH "SEE ALSO" |
62 |
mkillum(1), rpict(1), rvu(1) |
