root/radiance/ray/doc/man/man1/mksource.1
Revision: 1.1
Committed: Tue Apr 12 03:30:43 2005 UTC (20 years, 3 months ago) by greg
Created mksource program
1 .\" RCSid "$Id$"
2 .TH MKSOURCE 1 04/11/05 RADIANCE
3 .SH NAME
4 mksource - compute distant sources for RADIANCE image-based lighting
5 .SH SYNOPSIS
6 .B mksource
7 [
8 .B "\-d nsamps"
9 ][
10 .B "\-t thresh"
11 ][
12 .B "\-a maxang"
13 ]
14 [
15 .B octree
16 ]
17 .SH DESCRIPTION
18 .I Mksource
19 produces a RADIANCE scene description of distant illum
20 sources corresponding to bright, concentrated regions in
21 the given ambient environment.
22 Any local geometry is ignored in the input octree, which
23 should be derived from a captured light probe.
24 The output sources may then be combined with this environment
25 to produce a more efficient scene for rendering, faster and
26 less prone to sampling artifacts.
27 .PP
28 The
29 .I \-d
30 option may be used to specify the number of ray samples, which
31 defaults to 262,000.
32 Calculation time is roughly proportional to accuracy, and the
33 default is fine enough to find sources the size of the sun
34 (half a degree) or larger.
35 .PP
36 The
37 .I \-t
38 option may be used to manually set the radiance threshold for
39 sources, in watts/sr/meter^2.
40 The default uses the top 1 percentile of the environment, which
41 is usally a good value.
42 .PP
43 The
44 .I \-a
45 option may be used to specify a maximum source diameter,
46 which defaults to 15 degrees.
47 .I Mkillum
48 silently enforces a maximum of 180 degrees for this option.
49 .PP
50 If no input octree is specified, the standard input is read.
51 .SH EXAMPLE
52 To add sources with a maximum size of 20 degrees
53 to the enviornment described in environ.oct:
54 .IP "" .2i
55 mksource -a 20 environ.oct > srcs.rad
56 .br
57 oconv -i environ.oct srcs.rad > env+srcs.oct
58 .SH AUTHOR
59 Greg Ward
60 .SH "SEE ALSO"
61 mkillum(1), rpict(1), rvu(1)
