root/radiance/ray/doc/man/man1/mksource.1
Revision: 1.3
Committed: Thu Apr 14 19:37:02 2005 UTC (20 years ago) by greg
CVS Tags: rad3R7P1
Minor wording fix
1 .\" RCSid "$Id: mksource.1,v 1.2 2005/04/12 20:03:12 greg Exp $"
2 .TH MKSOURCE 1 04/11/05 RADIANCE
3 .SH NAME
4 mksource - compute distant sources for RADIANCE image-based lighting
5 .SH SYNOPSIS
6 .B mksource
7 [
8 .B "\-d nsamps"
9 ][
10 .B "\-t thresh"
11 ][
12 .B "\-a maxang"
13 ]
14 [
15 .B octree
16 ]
17 .SH DESCRIPTION
18 .I Mksource
19 produces a RADIANCE scene description of distant illum
20 sources corresponding to bright, concentrated regions in
21 the given ambient environment.
22 Any local geometry is ignored in the input octree, which
23 should be derived from a captured light probe and modeled
24 as a distant hemispherical or spherical glow source.
25 The output sources may then be combined with this environment
26 to produce a more efficient scene for rendering, faster and
27 less prone to sampling artifacts.
28 .PP
29 The
30 .I \-d
31 option may be used to specify the number of ray samples, which
32 defaults to 262,000.
33 Calculation time is roughly proportional to this setting, and the
34 default is fine enough to resolve sources the size of the sun
35 (half a degree) or larger.
36 .PP
37 The
38 .I \-t
39 option may be used to manually set the radiance threshold for
40 sources, in watts/sr/meter^2.
41 The default uses the top 1 percentile of the environment, which
42 is usally a good value.
43 .PP
44 The
45 .I \-a
46 option may be used to specify a maximum source diameter,
47 which defaults to 15 degrees.
48 .I Mkillum
49 silently enforces a maximum of 180 degrees for this option.
50 .PP
51 If no input octree is specified, the standard input is read.
52 .SH EXAMPLE
53 To add sources with a maximum size of 20 degrees
54 to the enviornment described in environ.oct:
55 .IP "" .2i
56 mksource -a 20 environ.oct > srcs.rad
57 .br
58 oconv -i environ.oct srcs.rad > env+srcs.oct
59 .SH AUTHOR
60 Greg Ward
61 .SH "SEE ALSO"
62 mkillum(1), rpict(1), rvu(1)
