--- ray/doc/man/man1/mkpmap.1 2016/05/18 12:45:55 1.3 +++ ray/doc/man/man1/mkpmap.1 2017/03/30 11:54:53 1.4 @@ -1,5 +1,5 @@ -.\" RCSid "$Id: mkpmap.1,v 1.3 2016/05/18 12:45:55 rschregle Exp $" -.TH MKPMAP 1 "$Date: 2016/05/18 12:45:55 $ $Revision: 1.3 $" RADIANCE +.\" RCSid "$Id: mkpmap.1,v 1.4 2017/03/30 11:54:53 rschregle Exp $" +.TH MKPMAP 1 "$Date: 2017/03/30 11:54:53 $ $Revision: 1.4 $" RADIANCE .SH NAME mkpmap - generate RADIANCE photon map @@ -57,7 +57,7 @@ photons, and output to file \fIfile\fR. This only acco illumination and is intended for debugging and validation of photon emission from the light sources, as the quality is too low for actual rendering. -.IP "\fB\-apC \fIfile nphotons \fB(EXPERIMENTAL)\fR" +.IP "\fB\-apC \fIfile nphotons\fR" Generate a contribution photon map containing approximately \fInphotons\fR photons, and output to file \fIfile\fR. This may then be used by \fIrcontrib(1)\fR to compute light source contributions. @@ -285,7 +285,7 @@ mkpmap \-apg refRoom.gpm 1m \-apo glazingMat refRoom.o Generate a contribution photon map containing 200000 photons suitable for obtaining light source contributions with \fIrcontrib(1)\fR: .IP -mkpmap \-apl bonzo-contrib.gpm 200k bonzo.oct +mkpmap \-apC bonzo-contrib.gpm 200k bonzo.oct .SH BUGS The focus of a spotlight source, as defined by the length of its direction
