--- ray/doc/man/man1/mkpmap.1 2018/03/20 19:53:09 1.10 +++ ray/doc/man/man1/mkpmap.1 2018/12/06 20:13:13 1.11 @@ -1,5 +1,5 @@ -.\" RCSid "$Id: mkpmap.1,v 1.10 2018/03/20 19:53:09 rschregle Exp $" -.TH MKPMAP 1 "$Date: 2018/03/20 19:53:09 $ $Revision: 1.10 $" RADIANCE +.\" RCSid "$Id: mkpmap.1,v 1.11 2018/12/06 20:13:13 rschregle Exp $" +.TH MKPMAP 1 "$Date: 2018/12/06 20:13:13 $ $Revision: 1.11 $" RADIANCE .SH NAME mkpmap - generate RADIANCE photon map @@ -306,9 +306,12 @@ attempts before terminating with an error. This can be \fB\-apM\fR option. .SS Material Support -The \fIplasfunc\fR, \fImetfunc\fR, \fItransfunc\fR, \fIbrtdfunc\fR, -\fIplasdata\fR, \fImetdata\fR and \fItransdata\fR materials are not -supported by the photon mapping extension. Use the newer \fIbsdf\fR material +Not all materials are fully supported by the photon map extension. The +\fIplasfunc\fR, \fImetfunc\fR, \fItransfunc\fR, \fIplasdata\fR, +\fImetdata\fR and \fItransdata\fR materials currently only scatter photons +diffusely, and will not produce caustics. The \fIbrtdfunc\fR material only +produces caustics via ideal (mirror) specular reflection and transmission. +For more realistic scattering behaviour, use the newer \fIbsdf\fR material instead. .PP Virtual light sources (normally enabled with the \fImirror\fR material) are
