| 1 |
.\" RCSid "$Id: mkpmap.1,v 1.10 2018/03/20 19:53:09 rschregle Exp $"
| 2 |
.TH MKPMAP 1 "$Date: 2018/03/20 19:53:09 $ $Revision: 1.10 $" RADIANCE
| 3 |
| 4 |
.SH NAME
| 5 |
mkpmap - generate RADIANCE photon map
| 6 |
| 7 |
.SH SYNOPSIS
| 8 |
mkpmap \fB\-apg\fR|\fB\-apc\fR|\fB\-apv\fR|\fB\-apd\fR|\fB\-app\fR|\fB\-apC\fR
| 9 |
\fIfile nphotons\fR [\fIbwidth\fR] ...
| 10 |
[options] \fIoctree\fR
| 11 |
| 12 |
.SH DESCRIPTION
| 13 |
\fIMkpmap\fR takes a RADIANCE scene description as an octree and
| 14 |
performs Monte Carlo forward path tracing from the light sources,
| 15 |
depositing indirect ray hitpoints along with their energy (flux) as
| 16 |
"photons". The resulting localised energy distribution represents a
| 17 |
global illumination solution which is written to a file for subsequent
| 18 |
evaluation by \fIrpict(1), rtrace(1)\fR and \fIrvu(1)\fR in a backward
| 19 |
raytracing pass. The photon map(s) can be reused for multiple viewpoints
| 20 |
and sensor locations as long as the geometry remains unchanged.
| 21 |
| 22 |
.SH OPTIONS
| 23 |
\fIMkpmap\fR can generate different types of photon maps depending on
| 24 |
the materials present in the scene. In most cases, these can be
| 25 |
specified independently or in combination on the command line. If
| 26 |
multiple photon maps of the same type are specified, the last instance
| 27 |
takes precedence.
| 28 |
| 29 |
.IP "\fB\-apg \fIfile nphotons\fR"
| 30 |
Generate a global photon map containing approximately \fInphotons\fR
| 31 |
photons, and output to \fIfile\fR. This accounts for all
| 32 |
indirect illumination, from both specular and diffuse scattering, on
| 33 |
surfaces with a diffuse component. This is the most general type of
| 34 |
photon map and replaces the ambient calculation in \fIrpict(1),
| 35 |
rtrace(1)\fR and \fIrvu(1)\fR.
| 36 |
| 37 |
.IP "\fB\-apc \fIfile nphotons\fR"
| 38 |
Generate a separate caustic photon map containing approximately
| 39 |
\fInphotons\fR photons, and output to file \fIfile\fR. This is a
| 40 |
subset of the global photon map intended for direct visualisation at
| 41 |
primary rays, This accounts for all indirect illumination on diffuse
| 42 |
surfaces from specular scattering, which usually exhibits a large
| 43 |
gradient and requires a higher resolution than the global photon map,
| 44 |
typically containing the tenfold number of photons.
| 45 |
| 46 |
.IP "\fB\-apv \fIfile nphotons\fR"
| 47 |
Generate a volume photon map containing approximately \fInphotons\fR
| 48 |
photons, and output to file \fIfile\fR. These account for indirect
| 49 |
inscattering in participating media such as \fBmist\fR and complement
| 50 |
the direct inscattering computed by \fIrpict(1), rtrace(1)\fR and
| 51 |
\fIrvu(1)\fR. See also the \fB\-me\fR, \fB\-ma\fR and \fB\-mg\fR options
| 52 |
below.
| 53 |
| 54 |
.IP "\fB\-apd \fIfile nphotons\fR"
| 55 |
Generate a direct photon map containing approximately \fInphotons\fR
| 56 |
photons, and output to file \fIfile\fR. This only accounts for direct
| 57 |
illumination and is intended for debugging and validation of photon emission
| 58 |
from the light sources, as the quality is too low for actual rendering.
| 59 |
| 60 |
.IP "\fB\-apC \fIfile nphotons\fR"
| 61 |
Generate a contribution photon map containing approximately
| 62 |
\fInphotons\fR photons, and output to file \fIfile\fR. This may then be
| 63 |
used by \fIrcontrib(1)\fR to compute light source contributions. When used
| 64 |
with \fIrtrace(1)\fR or \fIrpict(1)\fR, contribution photon maps behave as
| 65 |
regular global photon maps and yield cumulative contributions from all light
| 66 |
sources.
| 67 |
.IP
| 68 |
With this option, \fImkpmap\fR uses a modified photon distribution
| 69 |
algorithm that ensures all light sources contribute approximately the
| 70 |
same number of photons. Each photon indexes a primary hitpoint, incident
| 71 |
direction, and emitting light source which can be used to bin
| 72 |
contributions per light source and direction.
| 73 |
.IP
| 74 |
\fIMkpmap\fR cannot generate a contribution photon map in combination with
| 75 |
others in a single run, as it uses a different distribution algorithm. Other
| 76 |
photon maps specified on the command line will be ignored.
| 77 |
| 78 |
.IP "\fB\-app \fIfile nphotons bwidth\fR"
| 79 |
Generate a precomputed global photon map containing a fraction of
| 80 |
\fInphotons\fR photons (specified with the \fB\-apP\fR option, see
| 81 |
below), and output to file \fIfile\fR. This is a special case of the
| 82 |
global photon map where the irradiance is evaluated for a fraction of
| 83 |
the photon positions using \fIbwidth\fR nearest photons, and stored as
| 84 |
photon flux; the remaining photons are discarded as their contributions
| 85 |
have been accounted for.
| 86 |
.IP
| 87 |
This obviates the explicit irradiance evaluation by \fIrpict(1),
| 88 |
rtrace(1)\fR and \fIrvu(1)\fR, thus providing a speedup at the expense of
| 89 |
accuracy. The resulting error is tolerable if the indirect illumination has
| 90 |
a low gradient, as is usually the case with diffuse illumination.
| 91 |
| 92 |
.IP "\fB\-apD \fIpredistrib\fR"
| 93 |
Photon predistribution factor; this is the fraction of \fInphotons\fR
| 94 |
which are emitted in a distribution prepass in order to estimate the
| 95 |
remaining number of photons to emit in the main pass to approximately
| 96 |
yield a photon map of size \fInphotons\fR.
| 97 |
.IP
| 98 |
Setting this too high may yield more than \fInphotons\fR in the initial pass
| 99 |
with highly reflective geometry. Note that this value may exceed 1, which
| 100 |
may be useful if the resulting photon map size greatly deviates from
| 101 |
\fInphotons\fR with a very low average reflectance.
| 102 |
| 103 |
.IP "\fB\-api \fIxmin ymin zmin xmax ymax zmax\fR"
| 104 |
Define a region of interest within which to store photons exclusively;
| 105 |
photons will only be stored within the volume bounded by the given minimum
| 106 |
and maximum coordinates. Multiple instances of this option may be specified
| 107 |
with cumulative effect to define compound regions of interest. This is
| 108 |
useful for constraining photons to only the relevant regions of a scene, but
| 109 |
may increase the photon distribution time.
| 110 |
.IP
| 111 |
\fBWARNING: this is an optimisation option for advanced users (an elite
| 112 |
group collectively known as \fIZe Ekspertz\fB) and may yield biased results.
| 113 |
Use with caution!\fR
| 114 |
| 115 |
.IP "\fB\-apm \fImaxbounce\fR"
| 116 |
Synonymous with \fB\-lr\fR for backwards compatibility. May be removed in
| 117 |
future releases.
| 118 |
| 119 |
.IP "\fB\-apM \fImaxprepass\fR"
| 120 |
Maximum number of iterations of the distribution prepass before terminating
| 121 |
if some photon maps are still empty. This option is rarely needed as a
| 122 |
an aborted prepass indicates an anomaly in the geometry or an
| 123 |
incompatibility with the specified photon map types (see \fBNOTES\fR below).
| 124 |
| 125 |
.IP "\fB\-apo \fImod\fR"
| 126 |
Specifies a modifier \fImod\fR to act as a \fIphoton port\fR. All
| 127 |
objects using this modifier will emit photons directly in lieu of any
| 128 |
light sources defined with the \fIsource\fR material. This greatly
| 129 |
accelerates photon distribution in scenes where photons have to enter a
| 130 |
space which separates them from the emitting light source via an
| 131 |
opening, or port.
| 132 |
.IP
| 133 |
A typical application is daylight simulation, where a fenestration acts as
| 134 |
port to admit photons into an interior after emission from an external light
| 135 |
source. Multiple instances of this option may be specified.
| 136 |
.IP
| 137 |
Note that port objects must be defined with their surface normals
| 138 |
pointing \fIinside\fR as per \fImkillum\fR convention.
| 139 |
| 140 |
.IP "\fB\-apO \fImodfile\fR"
| 141 |
Read photon port modifiers from the file \fImodfile\fR as a more convenient
| 142 |
alternative to multiple instances of \fB\-apo\fR.
| 143 |
| 144 |
.IP "\fB\-apP \fIprecomp\fR"
| 145 |
Fraction of global photons to precompute in the range ]0,1] when using the
| 146 |
\fB\-app\fR option.
| 147 |
| 148 |
.IP "\fB\-apr \fIseed\fR"
| 149 |
Seed for the random number generator. This is useful for generating
| 150 |
different photon distributions for the same octree and photon map size,
| 151 |
notably in progressive applications.
| 152 |
| 153 |
.IP "\fB\-aps \fImod\fR"
| 154 |
Specifies a modifier \fImod\fR defined as \fIantimatter\fR material to act
| 155 |
as a virtual (i.e. invisible) receiver surface. Photons will be deposited on
| 156 |
all surfaces using this modifier, just like regular materials, but will then
| 157 |
be transferred through the surface without undergoing scattering; the
| 158 |
surface therefore does not affect the light transport and simply acts as an
| 159 |
invisible photon receiver. This is useful when photon irradiance is to be
| 160 |
evaluated at points which do not lie on regular geometry, e.g. at workplane
| 161 |
height with \fIrtrace\fR's \fB-I\fR option. Without this workaround,
| 162 |
photons would be collected from parallel but distant planes, leading to
| 163 |
underestimation. Note that photons are only deposited when incident from
| 164 |
the front side of the sensor surface, i.e. when entering the
| 165 |
\fIantimatter\fR, thus the surface normal is relevant. \fIMkpmap\fR reports
| 166 |
an error if the specified modifier is not an \fIantimatter\fR material.
| 167 |
| 168 |
.IP "\fB\-apS \fImodfile\fR"
| 169 |
Read virtual receiver surface modifiers from the file \fImodfile\fR as a more
| 170 |
convenient alternative to multiple instances of \fB\-aps\fR.
| 171 |
| 172 |
.IP "\fB\-ae \fImod\fR"
| 173 |
Add \fImod\fR to the ambient exclude list, so that it will be ignored by the
| 174 |
photon map. Objects having \fImod\fR as their modifier will not have
| 175 |
photons deposited on them. Multiple modifiers may be given, each as separate
| 176 |
instances of this option.
| 177 |
.IP
| 178 |
\fBWARNING: this is an optimisation option for advanced users and may yield
| 179 |
biased results. It may also significantly increase photon distribution
| 180 |
times. Use with caution!\fR
| 181 |
| 182 |
.IP "\fB\-aE \fIfile\fR"
| 183 |
Same as \fI-ae\fR, except modifiers to be exluded are read from \fIfile\fR,
| 184 |
separated by whitespace. The RAYPATH environment variable determines which
| 185 |
directories are searched for this file.
| 186 |
| 187 |
.IP "\fB\-ai \fImod\fR"
| 188 |
Add \fImod\fR to the ambient include list, so that it will contribute to the
| 189 |
photon map. Only objects having \fImod\fR as their modifier will have
| 190 |
| 191 |
instances of this option. Note that the ambient include and exclude options
| 192 |
are mutually exclusive.
| 193 |
.IP
| 194 |
| 195 |
| 196 |
| 197 |
| 198 |
.IP "\fB\-aI \fIfile\fR"
| 199 |
Same as \fI-ai\fR, except modifiers to be included are read from \fIfile\fR,
| 200 |
| 201 |
| 202 |
| 203 |
.IP "\fB\-bv\fR[\fB+\fR|\fB-\fR]"
| 204 |
Toggles backface visibility; enabling this causes photons to be stored and
| 205 |
possibly scattered if they strike the back of a surface, otherwise they
| 206 |
are unconditionally absorbed and discarded.
| 207 |
| 208 |
.IP "\fB\-dp \fIsampleres\fR"
| 209 |
Resolution for sampling the spatial emission distribution of a modified
| 210 |
light source (e.g. via \fIbrightfunc\fR), in samples per steradian. This
| 211 |
is required for numerically integrating the flux emitted by the light
| 212 |
source and for constructing a probability density function for photon
| 213 |
emission. The accuracy of photon emission from modified sources
| 214 |
therefore depends on this parameter. This parameter may need increasing
| 215 |
with complex emission distributions in combination with caustics.
| 216 |
| 217 |
.IP "\fB\-ds \fIpartsize\fR"
| 218 |
Light source partition size ratio; a light source object is spatially
| 219 |
partitioned to distribute the photon emission over its surface. This
| 220 |
parameter specifies the ratio of the size (per dimension) of each
| 221 |
partition to the scene cube, and may need increasing for modified light
| 222 |
sources (e.g. via \fIbrightfunc\fR) with high spatial variation.
| 223 |
| 224 |
.IP "\fB\-e \fIfile\fR"
| 225 |
Redirect diagnostics and progress reports to \fIfile\fR instead of the
| 226 |
console.
| 227 |
| 228 |
.IP "\fB\-fo\fR[\fB+\fR|\fB-\fR]"
| 229 |
Toggles overwriting of output files. By default, \fImkpmap\fR will not
| 230 |
overwrite an already existing photon map file. This is to prevent
| 231 |
inadvertently destroying the results of potentially lengthy photon
| 232 |
mapping runs.
| 233 |
| 234 |
.IP "\fB\-ld \fImaxdist\fR"
| 235 |
Limit cumulative distance travelled by a photon along its path to
| 236 |
\fImaxdist\fR. Photon hits within this distance will be stored, and the
| 237 |
photon is terminated once its path length exceeds this limit. This is
| 238 |
useful for setting radial regions of interest around emitting/reflecting
| 239 |
geometry, but may increase the photon distribution time.
| 240 |
.IP
| 241 |
| 242 |
| 243 |
| 244 |
| 245 |
.IP "\fB\-lr \fImaxbounce\fR"
| 246 |
Limit number of bounces (scattering events) along a photon path to
| 247 |
\fImaxbounce\fR before being considered "runaway" and terminated. Photons
| 248 |
paths are normally terminated via \fIRussian Roulette\fR, depending on their
| 249 |
albedo. With unrealistically high albedos, this is not guaranteed, and this
| 250 |
option imposes a hard limit to avoid an infinite loop.
| 251 |
.IP
| 252 |
| 253 |
| 254 |
| 255 |
| 256 |
.IP "\fB\-ma \fIralb galb balb\fR"
| 257 |
Set the global scattering albedo for participating media in conjunction
| 258 |
with the \fB\-apv\fR option. See \fIrpict(1)\fR for details.
| 259 |
| 260 |
.IP "\fB\-me \fIrext gext bext\fR"
| 261 |
Set the global extinction coefficient for participating media in conjunction
| 262 |
| 263 |
| 264 |
.IP "\fB\-mg \fIgecc\fR"
| 265 |
Set the global scattering eccentricity for participating media in conjunction
| 266 |
| 267 |
| 268 |
.IP "\fB\-n \fInproc\fR"
| 269 |
Use \fInproc\fR processes for parallel photon distribution. There is no
| 270 |
benefit in specifying more than the number of physical CPU cores available.
| 271 |
This option is currently not available on Windows.
| 272 |
| 273 |
.IP "\fB\-t \fIinterval\fR"
| 274 |
Output a progress report every \fIinterval\fR seconds. This includes
| 275 |
statistics about the currently emitting light source (including number of
| 276 |
partitions), the total number of photons emitted, the number of each type
| 277 |
stored, the percentage of the completed pass (pre or main), and the elapsed
| 278 |
time.
| 279 |
| 280 |
.SH NOTES
| 281 |
| 282 |
.SS Parametrisation
| 283 |
\fIMkpmap\fR recognises multiplier suffixes (k = 1000, m = 1000000) to
| 284 |
facilitate the specification of \fInphotons\fR, both in upper and lower
| 285 |
case.
| 286 |
.PP
| 287 |
| 288 |
.SS Distribution Algorithm
| 289 |
The photon distribution algorithm estimates the number of required
| 290 |
photons to emit to arrive at the specified target count \fInphotons\fR
| 291 |
per photon map using a distribution prepass followed by a main pass.
| 292 |
As a result, \fImkpmap\fR generates the \fBapproximate\fR number of photons
| 293 |
specified, which can vary by up to 10% for typical scenes, but can be
| 294 |
higher for scenes with unusually high or low reflectance. In this case,
| 295 |
the predistribution factor \fB\-apD\fR should be increased for scenes
| 296 |
with low reflectance, and reduced for those with high reflectance.
| 297 |
.PP
| 298 |
There are situations which may prevent certain (or any)
| 299 |
photon types from being generated, depending on the light source and material
| 300 |
configuration. This typically occurs when attempting to generate a caustic
| 301 |
photon map without specular materials present in the scene, or a volume
| 302 |
photon map without participating media. Ill-configured light sources may also
| 303 |
prevent indirect rays from reaching a surface, and thus no photons being
| 304 |
deposited. In these cases, \fImkpmap\fR will make a number of distribution
| 305 |
attempts before terminating with an error. This can be adjusted with the
| 306 |
\fB\-apM\fR option.
| 307 |
| 308 |
.SS Material Support
| 309 |
Not all materials are fully supported by the photon map extension. The
| 310 |
\fIplasfunc\fR, \fImetfunc\fR, \fItransfunc\fR, \fIplasdata\fR,
| 311 |
\fImetdata\fR and \fItransdata\fR materials currently only scatter photons
| 312 |
diffusely, and will not produce caustics. The \fIbrtdfunc\fR material only
| 313 |
produces caustics via ideal (mirror) specular reflection and transmission.
| 314 |
For more realistic scattering behaviour, use the newer \fIbsdf\fR material
| 315 |
instead.
| 316 |
.PP
| 317 |
Virtual light sources (normally enabled with the \fImirror\fR material) are
| 318 |
disabled with the photon map, as the resulting caustics are already accounted
| 319 |
for.
| 320 |
| 321 |
.SS Virtual Receiver Surfaces
| 322 |
Since photons are surface bound, the density estimate is only asymptotically
| 323 |
correct when performed at points which lie on the scene geometry. The
| 324 |
irradiance is underestimated for arbitrarily placed points when photons are
| 325 |
collected from distant surfaces. \fIMkpmap\fR offers a workaround with a
| 326 |
virtual receiver surface using the \fIantimatter\fR material; see the \fB-aps\fR
| 327 |
and \fB-apS\fR options for details.
| 328 |
| 329 |
.SH EXAMPLES
| 330 |
The following command generates a global photon map \fIbonzo.gpm\fR and a
| 331 |
caustic photon map \fIbonzo.cpm\fR containing approximately 10000 and 100000
| 332 |
photons, respectively, with progress report every 5 seconds:
| 333 |
.IP
| 334 |
mkpmap \-apg bonzo.gpm 10k \-apc bonzo.cpm 100k -t 5 bonzo.oct
| 335 |
.PP
| 336 |
Generate a global photon map containing 80000 photons, then precompute the
| 337 |
diffuse irradiance for 1/4 of these with a bandwidth of 40 photons:
| 338 |
.IP
| 339 |
mkpmap \-app bonzo-precomp.gpm 80k 40 \-apP 0.25 bonzo.oct
| 340 |
.PP
| 341 |
Generate 1 million global photons by emitting them from external light
| 342 |
sources of type \fIsource\fR into a reference room via a fenestration
| 343 |
with modifier \fIglazingMat\fR:
| 344 |
.IP
| 345 |
mkpmap \-apg refRoom.gpm 1m \-apo glazingMat refRoom.oct
| 346 |
.PP
| 347 |
Generate a contribution photon map containing 200000 photons suitable for
| 348 |
obtaining light source contributions with \fIrcontrib(1)\fR:
| 349 |
.IP
| 350 |
mkpmap \-apC bonzo-contrib.gpm 200k bonzo.oct
| 351 |
| 352 |
.SH BUGS
| 353 |
The focus of a spotlight source, as defined by the length of its direction
| 354 |
vector, is ignored by the photon map; photons are unconditionally emitted
| 355 |
from the light source surface, which can lead to deviations from standard
| 356 |
RADIANCE.
| 357 |
.PP
| 358 |
Light sources simply absorb incoming photons.
| 359 |
| 360 |
.SH AUTHOR
| 361 |
Roland Schregle (roland.schregle@{hslu.ch,gmail.com})
| 362 |
| 363 |
.SH COPYRIGHT
| 364 |
(c) Fraunhofer Institute for Solar Energy Systems, Lucerne University of
| 365 |
Applied Sciences and Arts.
| 366 |
| 367 |
.SH ACKNOWLEDGEMENT
| 368 |
Development of the RADIANCE photon mapping extension was sponsored by the
| 369 |
German Research Foundation (DFG) and the Swiss National Science Foundation
| 370 |
(SNF).
| 371 |
| 372 |
.SH "SEE ALSO"
| 373 |
rpict(1), rtrace(1), rvu(1), rcontrib(1), \fIThe RADIANCE Photon Map
| 374 |
Manual\fR, \fIDevelopment and Integration of the RADIANCE Photon Map
| 375 |
Extension: Technical Report\fR
