root/radiance/ray/doc/man/man1/mkpmap.1
Wed Apr 14 11:28:36 2021 UTC (4 years ago) by rschregle
CVS Tags: HEAD, rad5R4
Changes since 1.15: +13 -9 lines
Diff to previous 1.15 , to selected 1.12
docs(mkpmap): documented -apI option
Tue Mar 23 21:42:47 2021 UTC (4 years, 1 month ago) by rschregle
Changes since 1.14: +3 -3 lines
Diff to previous 1.14 , to selected 1.12
docs(mkpmap): increased-->reduced in description of -ds.
Tue Mar 23 21:31:56 2021 UTC (4 years, 1 month ago) by rschregle
Changes since 1.13: +44 -20 lines
Diff to previous 1.13 , to selected 1.12
docs(mkpmap): Clarified effect of -dp and -ds on photon ports.
Fri Aug 7 01:22:59 2020 UTC (4 years, 9 months ago) by rschregle
Changes since 1.12: +65 -24 lines
Diff to previous 1.12
docs(mkpmap): Documented extended -apo option to reorient photon ports,
updated acknowledgements and copyright.
Revision 1.12 - (view) (download) (annotate) - [selected]
Mon Jun 3 17:08:23 2019 UTC (5 years, 11 months ago) by rschregle
Changes since 1.11: +4 -4 lines
Diff to previous 1.11
Minor typo fix
Thu Dec 6 20:13:13 2018 UTC (6 years, 5 months ago) by rschregle
Changes since 1.10: +8 -5 lines
Diff to previous 1.10 , to selected 1.12
Documented rudimentary support for *data and *func materials
Tue Mar 20 19:53:09 2018 UTC (7 years, 1 month ago) by rschregle
Changes since 1.9: +34 -3 lines
Diff to previous 1.9 , to selected 1.12
Documented new -ae/-ai exclude/include options for mkpmap
Tue Feb 6 16:02:22 2018 UTC (7 years, 3 months ago) by rschregle
Diff to previous 1.8 , to selected 1.12
Minor addition to -apr
Fri Feb 2 19:49:02 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 1.7: +58 -27 lines
Diff to previous 1.7 , to selected 1.12
Documented -lr, -ld and -api, added warnings for Ze non-Ekspertz
Fri Jan 26 18:36:04 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 1.6: +2 -7 lines
Diff to previous 1.6 , to selected 1.12
Removed deprecated -i option from mkpmap manpage
Tue Oct 10 16:10:14 2017 UTC (7 years, 6 months ago) by greg
Changes since 1.5: +3 -3 lines
Diff to previous 1.5 , to selected 1.12
Minor formatting fixes
Thu Mar 30 11:58:17 2017 UTC (8 years, 1 month ago) by rschregle
Diff to previous 1.4 , to selected 1.12
Added caveats for Windows to mkpmap manpage
Thu Mar 30 11:54:53 2017 UTC (8 years, 1 month ago) by rschregle
Diff to previous 1.3 , to selected 1.12
Updated mkpmap manpage
Wed May 18 12:45:55 2016 UTC (8 years, 11 months ago) by rschregle
Changes since 1.2: +6 -2 lines
Diff to previous 1.2 , to selected 1.12
Updated man pages with pmap parallelisation and ooC options
Fri Jun 5 08:48:09 2015 UTC (9 years, 11 months ago) by rschregle
Diff to previous 1.1 , to selected 1.12
Renamed "dummy sensor surfaces" to more glamourous "virtual receiver
surfaces"
Tue Feb 24 19:39:26 2015 UTC (10 years, 2 months ago) by greg
Diff to selected 1.12
