root/radiance/ray/doc/man/man1/mkpmap.1
Revision: 1.12
Committed: Mon Jun 3 17:08:23 2019 UTC (6 years ago) by rschregle
Changes since 1.11: +4 -4 lines
Minor typo fix
1 .\" RCSid "$Id: mkpmap.1,v 1.11 2018/12/06 20:13:13 rschregle Exp $"
2 .TH MKPMAP 1 "$Date: 2018/12/06 20:13:13 $ $Revision: 1.11 $" RADIANCE
3
4 .SH NAME
5 mkpmap - generate RADIANCE photon map
6
7 .SH SYNOPSIS
8 mkpmap \fB\-apg\fR|\fB\-apc\fR|\fB\-apv\fR|\fB\-apd\fR|\fB\-app\fR|\fB\-apC\fR
9 \fIfile nphotons\fR [\fIbwidth\fR] ...
10 [options] \fIoctree\fR
11
12 .SH DESCRIPTION
13 \fIMkpmap\fR takes a RADIANCE scene description as an octree and
14 performs Monte Carlo forward path tracing from the light sources,
15 depositing indirect ray hitpoints along with their energy (flux) as
16 "photons". The resulting localised energy distribution represents a
17 global illumination solution which is written to a file for subsequent
18 evaluation by \fIrpict(1), rtrace(1)\fR and \fIrvu(1)\fR in a backward
19 raytracing pass. The photon map(s) can be reused for multiple viewpoints
20 and sensor locations as long as the geometry remains unchanged.
21
22 .SH OPTIONS
23 \fIMkpmap\fR can generate different types of photon maps depending on
24 the materials present in the scene. In most cases, these can be
25 specified independently or in combination on the command line. If
26 multiple photon maps of the same type are specified, the last instance
27 takes precedence.
28
29 .IP "\fB\-apg \fIfile nphotons\fR"
30 Generate a global photon map containing approximately \fInphotons\fR
31 photons, and output to \fIfile\fR. This accounts for all
32 indirect illumination, from both specular and diffuse scattering, on
33 surfaces with a diffuse component. This is the most general type of
34 photon map and replaces the ambient calculation in \fIrpict(1),
35 rtrace(1)\fR and \fIrvu(1)\fR.
36
37 .IP "\fB\-apc \fIfile nphotons\fR"
38 Generate a separate caustic photon map containing approximately
39 \fInphotons\fR photons, and output to file \fIfile\fR. This is a
40 subset of the global photon map intended for direct visualisation at
41 primary rays, This accounts for all indirect illumination on diffuse
42 surfaces from specular scattering, which usually exhibits a large
43 gradient and requires a higher resolution than the global photon map,
44 typically containing the tenfold number of photons.
45
46 .IP "\fB\-apv \fIfile nphotons\fR"
47 Generate a volume photon map containing approximately \fInphotons\fR
48 photons, and output to file \fIfile\fR. These account for indirect
49 inscattering in participating media such as \fBmist\fR and complement
50 the direct inscattering computed by \fIrpict(1), rtrace(1)\fR and
51 \fIrvu(1)\fR. See also the \fB\-me\fR, \fB\-ma\fR and \fB\-mg\fR options
52 below.
53
54 .IP "\fB\-apd \fIfile nphotons\fR"
55 Generate a direct photon map containing approximately \fInphotons\fR
56 photons, and output to file \fIfile\fR. This only accounts for direct
57 illumination and is intended for debugging and validation of photon emission
58 from the light sources, as the quality is too low for actual rendering.
59
60 .IP "\fB\-apC \fIfile nphotons\fR"
61 Generate a contribution photon map containing approximately
62 \fInphotons\fR photons, and output to file \fIfile\fR. This may then be
63 used by \fIrcontrib(1)\fR to compute light source contributions. When used
64 with \fIrtrace(1)\fR or \fIrpict(1)\fR, contribution photon maps behave as
65 regular global photon maps and yield cumulative contributions from all light
66 sources.
67 .IP
68 With this option, \fImkpmap\fR uses a modified photon distribution
69 algorithm that ensures all light sources contribute approximately the
70 same number of photons. Each photon indexes a primary hitpoint, incident
71 direction, and emitting light source which can be used to bin
72 contributions per light source and direction.
73 .IP
74 \fIMkpmap\fR cannot generate a contribution photon map in combination with
75 others in a single run, as it uses a different distribution algorithm. Other
76 photon maps specified on the command line will be ignored.
77
78 .IP "\fB\-app \fIfile nphotons bwidth\fR"
79 Generate a precomputed global photon map containing a fraction of
80 \fInphotons\fR photons (specified with the \fB\-apP\fR option, see
81 below), and output to file \fIfile\fR. This is a special case of the
82 global photon map where the irradiance is evaluated for a fraction of
83 the photon positions using \fIbwidth\fR nearest photons, and stored as
84 photon flux; the remaining photons are discarded as their contributions
85 have been accounted for.
86 .IP
87 This obviates the explicit irradiance evaluation by \fIrpict(1),
88 rtrace(1)\fR and \fIrvu(1)\fR, thus providing a speedup at the expense of
89 accuracy. The resulting error is tolerable if the indirect illumination has
90 a low gradient, as is usually the case with diffuse illumination.
91
92 .IP "\fB\-apD \fIpredistrib\fR"
93 Photon predistribution factor; this is the fraction of \fInphotons\fR
94 which are emitted in a distribution prepass in order to estimate the
95 remaining number of photons to emit in the main pass to approximately
96 yield a photon map of size \fInphotons\fR.
97 .IP
98 Setting this too high may yield more than \fInphotons\fR in the initial pass
99 with highly reflective geometry. Note that this value may exceed 1, which
100 may be useful if the resulting photon map size greatly deviates from
101 \fInphotons\fR with a very low average reflectance.
102
103 .IP "\fB\-api \fIxmin ymin zmin xmax ymax zmax\fR"
104 Define a region of interest within which to store photons exclusively;
105 photons will only be stored within the volume bounded by the given minimum
106 and maximum coordinates. Multiple instances of this option may be specified
107 with cumulative effect to define compound regions of interest. This is
108 useful for constraining photons to only the relevant regions of a scene, but
109 may increase the photon distribution time.
110 .IP
111 \fBWARNING: this is an optimisation option for advanced users (an elite
112 group collectively known as \fIZe Ekspertz\fB) and may yield biased results.
113 Use with caution!\fR
114
115 .IP "\fB\-apm \fImaxbounce\fR"
116 Synonymous with \fB\-lr\fR for backwards compatibility. May be removed in
117 future releases.
118
119 .IP "\fB\-apM \fImaxprepass\fR"
120 Maximum number of iterations of the distribution prepass before terminating
121 if some photon maps are still empty. This option is rarely needed as
122 an aborted prepass may indicate an anomaly in the geometry or an
123 incompatibility with the specified photon map types (see \fBNOTES\fR below).
124
125 .IP "\fB\-apo \fImod\fR"
126 Specifies a modifier \fImod\fR to act as a \fIphoton port\fR. All
127 objects using this modifier will emit photons directly in lieu of any
128 light sources defined with the \fIsource\fR material. This greatly
129 accelerates photon distribution in scenes where photons have to enter a
130 space which separates them from the emitting light source via an
131 opening, or port.
132 .IP
133 A typical application is daylight simulation, where a fenestration acts as
134 port to admit photons into an interior after emission from an external light
135 source. Multiple instances of this option may be specified.
136 .IP
137 Note that port objects must be defined with their surface normals
138 pointing \fIinside\fR as per \fImkillum\fR convention.
139
140 .IP "\fB\-apO \fImodfile\fR"
141 Read photon port modifiers from the file \fImodfile\fR as a more convenient
142 alternative to multiple instances of \fB\-apo\fR.
143
144 .IP "\fB\-apP \fIprecomp\fR"
145 Fraction of global photons to precompute in the range ]0,1] when using the
146 \fB\-app\fR option.
147
148 .IP "\fB\-apr \fIseed\fR"
149 Seed for the random number generator. This is useful for generating
150 different photon distributions for the same octree and photon map size,
151 notably in progressive applications.
152
153 .IP "\fB\-aps \fImod\fR"
154 Specifies a modifier \fImod\fR defined as \fIantimatter\fR material to act
155 as a virtual (i.e. invisible) receiver surface. Photons will be deposited on
156 all surfaces using this modifier, just like regular materials, but will then
157 be transferred through the surface without undergoing scattering; the
158 surface therefore does not affect the light transport and simply acts as an
159 invisible photon receiver. This is useful when photon irradiance is to be
160 evaluated at points which do not lie on regular geometry, e.g. at workplane
161 height with \fIrtrace\fR's \fB-I\fR option. Without this workaround,
162 photons would be collected from parallel but distant planes, leading to
163 underestimation. Note that photons are only deposited when incident from
164 the front side of the sensor surface, i.e. when entering the
165 \fIantimatter\fR, thus the surface normal is relevant. \fIMkpmap\fR reports
166 an error if the specified modifier is not an \fIantimatter\fR material.
167
168 .IP "\fB\-apS \fImodfile\fR"
169 Read virtual receiver surface modifiers from the file \fImodfile\fR as a more
170 convenient alternative to multiple instances of \fB\-aps\fR.
171
172 .IP "\fB\-ae \fImod\fR"
173 Add \fImod\fR to the ambient exclude list, so that it will be ignored by the
174 photon map. Objects having \fImod\fR as their modifier will not have
175 photons deposited on them. Multiple modifiers may be given, each as separate
176 instances of this option.
177 .IP
178 \fBWARNING: this is an optimisation option for advanced users and may yield
179 biased results. It may also significantly increase photon distribution
180 times. Use with caution!\fR
181
182 .IP "\fB\-aE \fIfile\fR"
183 Same as \fI-ae\fR, except modifiers to be exluded are read from \fIfile\fR,
184 separated by whitespace. The RAYPATH environment variable determines which
185 directories are searched for this file.
186
187 .IP "\fB\-ai \fImod\fR"
188 Add \fImod\fR to the ambient include list, so that it will contribute to the
189 photon map. Only objects having \fImod\fR as their modifier will have
190 photons deposited on them. Multiple modifiers may be given, each as separate
191 instances of this option. Note that the ambient include and exclude options
192 are mutually exclusive.
193 .IP
194 \fBWARNING: this is an optimisation option for advanced users and may yield
195 biased results. It may also significantly increase photon distribution
196 times. Use with caution!\fR
197
198 .IP "\fB\-aI \fIfile\fR"
199 Same as \fI-ai\fR, except modifiers to be included are read from \fIfile\fR,
200 separated by whitespace. The RAYPATH environment variable determines which
201 directories are searched for this file.
202
203 .IP "\fB\-bv\fR[\fB+\fR|\fB-\fR]"
204 Toggles backface visibility; enabling this causes photons to be stored and
205 possibly scattered if they strike the back of a surface, otherwise they
206 are unconditionally absorbed and discarded.
207
208 .IP "\fB\-dp \fIsampleres\fR"
209 Resolution for sampling the spatial emission distribution of a modified
210 light source (e.g. via \fIbrightfunc\fR), in samples per steradian. This
211 is required for numerically integrating the flux emitted by the light
212 source and for constructing a probability density function for photon
213 emission. The accuracy of photon emission from modified sources
214 therefore depends on this parameter. This parameter may need increasing
215 with complex emission distributions in combination with caustics.
216
217 .IP "\fB\-ds \fIpartsize\fR"
218 Light source partition size ratio; a light source object is spatially
219 partitioned to distribute the photon emission over its surface. This
220 parameter specifies the ratio of the size (per dimension) of each
221 partition to the scene cube, and may need increasing for modified light
222 sources (e.g. via \fIbrightfunc\fR) with high spatial variation.
223
224 .IP "\fB\-e \fIfile\fR"
225 Redirect diagnostics and progress reports to \fIfile\fR instead of the
226 console.
227
228 .IP "\fB\-fo\fR[\fB+\fR|\fB-\fR]"
229 Toggles overwriting of output files. By default, \fImkpmap\fR will not
230 overwrite an already existing photon map file. This is to prevent
231 inadvertently destroying the results of potentially lengthy photon
232 mapping runs.
233
234 .IP "\fB\-ld \fImaxdist\fR"
235 Limit cumulative distance travelled by a photon along its path to
236 \fImaxdist\fR. Photon hits within this distance will be stored, and the
237 photon is terminated once its path length exceeds this limit. This is
238 useful for setting radial regions of interest around emitting/reflecting
239 geometry, but may increase the photon distribution time.
240 .IP
241 \fBWARNING: this is an optimisation option for advanced users (an elite
242 group collectively known as \fIZe Ekspertz\fB) and may yield biased results.
243 Use with caution!\fR
244
245 .IP "\fB\-lr \fImaxbounce\fR"
246 Limit number of bounces (scattering events) along a photon path to
247 \fImaxbounce\fR before being considered "runaway" and terminated. Photons
248 paths are normally terminated via \fIRussian Roulette\fR, depending on their
249 albedo. With unrealistically high albedos, this is not guaranteed, and this
250 option imposes a hard limit to avoid an infinite loop.
251 .IP
252 \fBWARNING: this is an optimisation option for advanced users (an elite
253 group collectively known as \fIZe Ekspertz\fB) and may yield biased results.
254 Use with caution!\fR
255
256 .IP "\fB\-ma \fIralb galb balb\fR"
257 Set the global scattering albedo for participating media in conjunction
258 with the \fB\-apv\fR option. See \fIrpict(1)\fR for details.
259
260 .IP "\fB\-me \fIrext gext bext\fR"
261 Set the global extinction coefficient for participating media in conjunction
262 with the \fB\-apv\fR option. See \fIrpict(1)\fR for details.
263
264 .IP "\fB\-mg \fIgecc\fR"
265 Set the global scattering eccentricity for participating media in conjunction
266 with the \fB\-apv\fR option. See \fIrpict(1)\fR for details.
267
268 .IP "\fB\-n \fInproc\fR"
269 Use \fInproc\fR processes for parallel photon distribution. There is no
270 benefit in specifying more than the number of physical CPU cores available.
271 This option is currently not available on Windows.
272
273 .IP "\fB\-t \fIinterval\fR"
274 Output a progress report every \fIinterval\fR seconds. This includes
275 statistics about the currently emitting light source (including number of
276 partitions), the total number of photons emitted, the number of each type
277 stored, the percentage of the completed pass (pre or main), and the elapsed
278 time.
279
280 .SH NOTES
281
282 .SS Parametrisation
283 \fIMkpmap\fR recognises multiplier suffixes (k = 1000, m = 1000000) to
284 facilitate the specification of \fInphotons\fR, both in upper and lower
285 case.
286 .PP
287
288 .SS Distribution Algorithm
289 The photon distribution algorithm estimates the number of required
290 photons to emit to arrive at the specified target count \fInphotons\fR
291 per photon map using a distribution prepass followed by a main pass.
292 As a result, \fImkpmap\fR generates the \fBapproximate\fR number of photons
293 specified, which can vary by up to 10% for typical scenes, but can be
294 higher for scenes with unusually high or low reflectance. In this case,
295 the predistribution factor \fB\-apD\fR should be increased for scenes
296 with low reflectance, and reduced for those with high reflectance.
297 .PP
298 There are situations which may prevent certain (or any)
299 photon types from being generated, depending on the light source and material
300 configuration. This typically occurs when attempting to generate a caustic
301 photon map without specular materials present in the scene, or a volume
302 photon map without participating media. Ill-configured light sources may also
303 prevent indirect rays from reaching a surface, and thus no photons being
304 deposited. In these cases, \fImkpmap\fR will make a number of distribution
305 attempts before terminating with an error. This can be adjusted with the
306 \fB\-apM\fR option.
307
308 .SS Material Support
309 Not all materials are fully supported by the photon map extension. The
310 \fIplasfunc\fR, \fImetfunc\fR, \fItransfunc\fR, \fIplasdata\fR,
311 \fImetdata\fR and \fItransdata\fR materials currently only scatter photons
312 diffusely, and will not produce caustics. The \fIbrtdfunc\fR material only
313 produces caustics via ideal (mirror) specular reflection and transmission.
314 For more realistic scattering behaviour, use the newer \fIbsdf\fR material
315 instead.
316 .PP
317 Virtual light sources (normally enabled with the \fImirror\fR material) are
318 disabled with the photon map, as the resulting caustics are already accounted
319 for.
320
321 .SS Virtual Receiver Surfaces
322 Since photons are surface bound, the density estimate is only asymptotically
323 correct when performed at points which lie on the scene geometry. The
324 irradiance is underestimated for arbitrarily placed points when photons are
325 collected from distant surfaces. \fIMkpmap\fR offers a workaround with a
326 virtual receiver surface using the \fIantimatter\fR material; see the \fB-aps\fR
327 and \fB-apS\fR options for details.
328
329 .SH EXAMPLES
330 The following command generates a global photon map \fIbonzo.gpm\fR and a
331 caustic photon map \fIbonzo.cpm\fR containing approximately 10000 and 100000
332 photons, respectively, with progress report every 5 seconds:
333 .IP
334 mkpmap \-apg bonzo.gpm 10k \-apc bonzo.cpm 100k -t 5 bonzo.oct
335 .PP
336 Generate a global photon map containing 80000 photons, then precompute the
337 diffuse irradiance for 1/4 of these with a bandwidth of 40 photons:
338 .IP
339 mkpmap \-app bonzo-precomp.gpm 80k 40 \-apP 0.25 bonzo.oct
340 .PP
341 Generate 1 million global photons by emitting them from external light
342 sources of type \fIsource\fR into a reference room via a fenestration
343 with modifier \fIglazingMat\fR:
344 .IP
345 mkpmap \-apg refRoom.gpm 1m \-apo glazingMat refRoom.oct
346 .PP
347 Generate a contribution photon map containing 200000 photons suitable for
348 obtaining light source contributions with \fIrcontrib(1)\fR:
349 .IP
350 mkpmap \-apC bonzo-contrib.gpm 200k bonzo.oct
351
352 .SH BUGS
353 The focus of a spotlight source, as defined by the length of its direction
354 vector, is ignored by the photon map; photons are unconditionally emitted
355 from the light source surface, which can lead to deviations from standard
356 RADIANCE.
357 .PP
358 Light sources simply absorb incoming photons.
359
360 .SH AUTHOR
361 Roland Schregle (roland.schregle@{hslu.ch,gmail.com})
362
363 .SH COPYRIGHT
364 (c) Fraunhofer Institute for Solar Energy Systems, Lucerne University of
365 Applied Sciences and Arts.
366
367 .SH ACKNOWLEDGEMENT
368 Development of the RADIANCE photon mapping extension was sponsored by the
369 German Research Foundation (DFG) and the Swiss National Science Foundation
370 (SNF).
371
372 .SH "SEE ALSO"
373 rpict(1), rtrace(1), rvu(1), rcontrib(1), \fIThe RADIANCE Photon Map
374 Manual\fR, \fIDevelopment and Integration of the RADIANCE Photon Map
375 Extension: Technical Report\fR
