1 |
.\" RCSid "$Id: mkpmap.1,v 1.15 2021/03/23 21:42:47 rschregle Exp $" |
2 |
.TH MKPMAP 1 "$Date: 2021/03/23 21:42:47 $ $Revision: 1.15 $" RADIANCE |
3 |
4 |
.SH NAME |
5 |
mkpmap - generate RADIANCE photon map |
6 |
7 |
.SH SYNOPSIS |
8 |
mkpmap \fB\-apg\fR|\fB\-apc\fR|\fB\-apv\fR|\fB\-apd\fR|\fB\-app\fR|\fB\-apC\fR |
9 |
\fIfile nphotons\fR [\fIbwidth\fR] ... |
10 |
[options] \fIoctree\fR |
11 |
12 |
.SH DESCRIPTION |
13 |
\fIMkpmap\fR takes a RADIANCE scene description as an octree and |
14 |
performs Monte Carlo forward path tracing from the light sources, |
15 |
depositing indirect ray hitpoints along with their energy (flux) as |
16 |
"photons". The resulting localised energy distribution represents a |
17 |
global illumination solution which is written to a file for subsequent |
18 |
evaluation by \fIrpict(1), rtrace(1)\fR and \fIrvu(1)\fR in a backward |
19 |
raytracing pass. The photon map(s) can be reused for multiple viewpoints |
20 |
and sensor locations as long as the geometry remains unchanged. |
21 |
22 |
.SH OPTIONS |
23 |
\fIMkpmap\fR can generate different types of photon maps depending on |
24 |
the materials present in the scene. In most cases, these can be |
25 |
specified independently or in combination on the command line. If |
26 |
multiple photon maps of the same type are specified, the last instance |
27 |
takes precedence. |
28 |
29 |
.IP "\fB\-apg \fIfile nphotons\fR" |
30 |
Generate a global photon map containing approximately \fInphotons\fR |
31 |
photons, and output to \fIfile\fR. This accounts for all |
32 |
indirect illumination, from both specular and diffuse scattering, on |
33 |
surfaces with a diffuse component. This is the most general type of |
34 |
photon map and replaces the ambient calculation in \fIrpict(1), |
35 |
rtrace(1)\fR and \fIrvu(1)\fR. |
36 |
37 |
.IP "\fB\-apc \fIfile nphotons\fR" |
38 |
Generate a separate caustic photon map containing approximately |
39 |
\fInphotons\fR photons, and output to file \fIfile\fR. This is a |
40 |
subset of the global photon map intended for direct visualisation at |
41 |
primary rays, This accounts for all indirect illumination on diffuse |
42 |
surfaces from specular scattering, which usually exhibits a large |
43 |
gradient and requires a higher resolution than the global photon map, |
44 |
typically containing the tenfold number of photons. |
45 |
46 |
.IP "\fB\-apv \fIfile nphotons\fR" |
47 |
Generate a volume photon map containing approximately \fInphotons\fR |
48 |
photons, and output to file \fIfile\fR. These account for indirect |
49 |
inscattering in participating media such as \fBmist\fR and complement |
50 |
the direct inscattering computed by \fIrpict(1), rtrace(1)\fR and |
51 |
\fIrvu(1)\fR. See also the \fB\-me\fR, \fB\-ma\fR and \fB\-mg\fR options |
52 |
below. |
53 |
54 |
.IP "\fB\-apd \fIfile nphotons\fR" |
55 |
Generate a direct photon map containing approximately \fInphotons\fR |
56 |
photons, and output to file \fIfile\fR. This only accounts for direct |
57 |
illumination and is intended for debugging and validation of photon emission |
58 |
from the light sources, as the quality is too low for actual rendering. |
59 |
60 |
.IP "\fB\-apC \fIfile nphotons\fR" |
61 |
Generate a contribution photon map containing approximately |
62 |
\fInphotons\fR photons, and output to file \fIfile\fR. This may then be |
63 |
used by \fIrcontrib(1)\fR to compute light source contributions. When used |
64 |
with \fIrtrace(1)\fR or \fIrpict(1)\fR, contribution photon maps behave as |
65 |
regular global photon maps and yield cumulative contributions from all light |
66 |
sources. |
67 |
.IP |
68 |
With this option, \fImkpmap\fR uses a modified photon distribution |
69 |
algorithm that ensures all light sources contribute approximately the |
70 |
same number of photons. Each photon indexes a primary hitpoint, incident |
71 |
direction, and emitting light source which can be used to bin |
72 |
contributions per light source and direction. |
73 |
.IP |
74 |
\fIMkpmap\fR cannot generate a contribution photon map in combination with |
75 |
others in a single run, as it uses a different distribution algorithm. Other |
76 |
photon maps specified on the command line will be ignored. |
77 |
78 |
.IP "\fB\-app \fIfile nphotons bwidth\fR" |
79 |
Generate a precomputed global photon map containing a fraction of |
80 |
\fInphotons\fR photons (specified with the \fB\-apP\fR option, see |
81 |
below), and output to file \fIfile\fR. This is a special case of the |
82 |
global photon map where the irradiance is evaluated for a fraction of |
83 |
the photon positions using \fIbwidth\fR nearest photons, and stored as |
84 |
photon flux; the remaining photons are discarded as their contributions |
85 |
have been accounted for. |
86 |
.IP |
87 |
This obviates the explicit irradiance evaluation by \fIrpict(1), |
88 |
rtrace(1)\fR and \fIrvu(1)\fR, thus providing a speedup at the expense of |
89 |
accuracy. The resulting error is tolerable if the indirect illumination has |
90 |
a low gradient, as is usually the case with diffuse illumination. |
91 |
92 |
.IP "\fB\-apD \fIpredistrib\fR" |
93 |
Photon predistribution factor; this is the fraction of \fInphotons\fR |
94 |
which are emitted in a distribution prepass in order to estimate the |
95 |
remaining number of photons to emit in the main pass to approximately |
96 |
yield a photon map of size \fInphotons\fR. |
97 |
.IP |
98 |
Setting this too high may yield more than \fInphotons\fR in the initial pass |
99 |
with highly reflective geometry. Note that this value may exceed 1, which |
100 |
may be useful if the resulting photon map size greatly deviates from |
101 |
\fInphotons\fR with a very low average reflectance. |
102 |
103 |
.IP "\fB\-api \fImin_x min_y min_z max_x max_y max_z\fR" |
104 |
Define a rectangular region of interest within which to store photons |
105 |
exclusively; photons will only be stored within the volume bounded by the |
106 |
given minimum and maximum coordinates. Multiple instances of this option may |
107 |
be specified with cumulative effect to define compound regions of interest. |
108 |
This is useful for constraining photons to only the relevant regions of a |
109 |
scene, but may increase the photon distribution time. |
110 |
.IP |
111 |
\fBWARNING: this is an optimisation option for advanced users (an elite |
112 |
group collectively known as \fIZe Ekspertz\fB) and may yield biased results. |
113 |
Use with caution!\fR |
114 |
115 |
.IP "\fB-apI \fIpos_x pos_y pos_z rad\fR" |
116 |
Similar to \fB\-api\fR, but with a spherical region of interest of given |
117 |
radius, centred at the given coordinates. |
118 |
119 |
.IP "\fB\-apm \fImaxbounce\fR" |
120 |
Synonymous with \fB\-lr\fR for backwards compatibility. May be removed in |
121 |
future releases. |
122 |
123 |
.IP "\fB\-apM \fImaxprepass\fR" |
124 |
Maximum number of iterations of the distribution prepass before terminating |
125 |
if some photon maps are still empty. This option is rarely needed as |
126 |
an aborted prepass may indicate an anomaly in the geometry or an |
127 |
incompatibility with the specified photon map types (see \fBNOTES\fR below). |
128 |
129 |
.IP "\fB\-apo\fR[\fB+\fR|\fB-\fR|\fB0\fR] \fImod\fR" |
130 |
Specifies a modifier \fImod\fR to act as a \fIphoton port\fR. All |
131 |
objects using this modifier will emit photons directly in lieu of any |
132 |
light sources defined with the \fIsource\fR material. This greatly |
133 |
accelerates photon distribution in scenes where photons have to enter a |
134 |
space which separates them from the emitting light source via an |
135 |
aperture (e.g. fenestration, skylight) acting as a port. |
136 |
.IP |
137 |
In a typical daylight simulation scenario, a fenestration acts as a port to |
138 |
admit photons into an interior after emission from sky and solar sources. |
139 |
Multiple instances of this option may be specified. |
140 |
.IP |
141 |
By default, ports are oriented to emit in the halfspace defined |
142 |
by their associated surface normal. This can be overridden by |
143 |
specifying a trivalent suffix as follows: |
144 |
.RS |
145 |
.IP \fB+\fR: |
146 |
Forward emission; this is equivalent to the abovementioned default behaviour. |
147 |
.IP \fB-\fR: |
148 |
Backward emission; the port is reversed and photons are emitted into the |
149 |
halfspace facing away from the surface normal. |
150 |
.IP \fB0\fR: |
151 |
Bidirectional emission; photons are emitted from both sides of the port. |
152 |
.RE |
153 |
.IP |
154 |
Some typical situations that call for a reversed photon port include, for |
155 |
example: |
156 |
.RS |
157 |
.IP (a) |
158 |
Using fenestrations as ports that were (for whatever |
159 |
reason) defined with outward facing normals, |
160 |
.IP (b) |
161 |
Using a \fBmist\fR |
162 |
primitive as a port, since this requires outward facing normals in order to |
163 |
register the photons as having entered the volume, |
164 |
.IP (c) |
165 |
Reorienting a port associated with a \fBbsdf\fR modifier, since inverting |
166 |
its normal would also reorient the BSDF and alter its behaviour. |
167 |
.RE |
168 |
.IP |
169 |
Other oddball scenarios are conceivable. If in doubt, specify a |
170 |
bidirectional port orientation for a slight performance penalty, |
171 |
as photon emission is attempted from both sides. For well-defined |
172 |
port geometry with inward-facing normals, just use the default; |
173 |
doan' mess with da normalz. |
174 |
.IP |
175 |
Photon port geometry is discretised according to the |
176 |
\fB\-dp\fR and \fB\-ds\fR options. These parameters aid in resolving |
177 |
spatially and directionally varying illuminance received by the port |
178 |
from distant light sources, e.g due to partial occlusion |
179 |
or when using climate-based sky models. |
180 |
181 |
.IP "\fB\-apO \fImodfile\fR" |
182 |
Read photon port modifiers from the file \fImodfile\fR as a more convenient |
183 |
alternative to multiple instances of \fB\-apo\fR. |
184 |
185 |
.IP "\fB\-apP \fIprecomp\fR" |
186 |
Fraction of global photons to precompute in the range ]0,1] when using the |
187 |
\fB\-app\fR option. |
188 |
189 |
.IP "\fB\-apr \fIseed\fR" |
190 |
Seed for the random number generator. This is useful for generating |
191 |
different photon distributions for the same octree and photon map size, |
192 |
notably in progressive applications. |
193 |
194 |
.IP "\fB\-aps \fImod\fR" |
195 |
Specifies a modifier \fImod\fR defined as \fIantimatter\fR material to act |
196 |
as a virtual (i.e. invisible) receiver surface. Photons will be deposited on |
197 |
all surfaces using this modifier, just like regular materials, but will then |
198 |
be transferred through the surface without undergoing scattering; the |
199 |
surface therefore does not affect the light transport and simply acts as an |
200 |
invisible photon receiver. This is useful when photon irradiance is to be |
201 |
evaluated at points which do not lie on regular geometry, e.g. at workplane |
202 |
height with \fIrtrace\fR's \fB-I\fR option. Without this workaround, |
203 |
photons would be collected from parallel but distant planes, leading to |
204 |
underestimation. Note that photons are only deposited when incident from |
205 |
the front side of the sensor surface, i.e. when entering the |
206 |
\fIantimatter\fR, thus the surface normal is relevant. \fIMkpmap\fR reports |
207 |
an error if the specified modifier is not an \fIantimatter\fR material. |
208 |
209 |
.IP "\fB\-apS \fImodfile\fR" |
210 |
Read virtual receiver surface modifiers from the file \fImodfile\fR as a more |
211 |
convenient alternative to multiple instances of \fB\-aps\fR. |
212 |
213 |
.IP "\fB\-ae \fImod\fR" |
214 |
Add \fImod\fR to the ambient exclude list, so that it will be ignored by the |
215 |
photon map. Objects having \fImod\fR as their modifier will not have |
216 |
photons deposited on them. Multiple modifiers may be given, each as separate |
217 |
instances of this option. |
218 |
.IP |
219 |
\fBWARNING: this is an optimisation option for advanced users and may yield |
220 |
biased results. It may also significantly increase photon distribution |
221 |
times. Use with caution!\fR |
222 |
223 |
.IP "\fB\-aE \fIfile\fR" |
224 |
Same as \fI-ae\fR, except modifiers to be exluded are read from \fIfile\fR, |
225 |
separated by whitespace. The RAYPATH environment variable determines which |
226 |
directories are searched for this file. |
227 |
228 |
.IP "\fB\-ai \fImod\fR" |
229 |
Add \fImod\fR to the ambient include list, so that it will contribute to the |
230 |
photon map. Only objects having \fImod\fR as their modifier will have |
231 |
232 |
instances of this option. Note that the ambient include and exclude options |
233 |
are mutually exclusive. |
234 |
.IP |
235 |
236 |
237 |
238 |
239 |
.IP "\fB\-aI \fIfile\fR" |
240 |
Same as \fI-ai\fR, except modifiers to be included are read from \fIfile\fR, |
241 |
242 |
243 |
244 |
.IP "\fB\-bv\fR[\fB+\fR|\fB-\fR]" |
245 |
Toggles backface visibility; enabling this causes photons to be stored and |
246 |
possibly scattered if they strike the back of a surface, otherwise they |
247 |
are unconditionally absorbed and discarded. |
248 |
249 |
.IP "\fB\-dp \fIsampleres\fR" |
250 |
Angular resolution for sampling the spatial emission distribution of a |
251 |
modified light source or photon port (e.g. via \fIbrightfunc\fR), in samples |
252 |
per steradian. |
253 |
This is required to numerically integrate the flux emitted by the light |
254 |
source and construct a probability density function for photon emission. |
255 |
The accuracy of photon emission from a modified source or port |
256 |
therefore depends on this parameter. The resolution may need to be increased |
257 |
with complex emission distributions in combination with caustics. |
258 |
259 |
.IP "\fB\-ds \fIpartsize\fR" |
260 |
Light source partition size ratio; a local light source object (or photon |
261 |
port in case of a distant source) is spatially partitioned to distribute the |
262 |
photon emission over its surface. This parameter specifies the ratio of the |
263 |
size (per dimension) of each partition to the scene cube, and may need |
264 |
to be reduced for modified light sources (e.g. via \fIbrightfunc\fR) with |
265 |
high spatial variance, or for partially occluded photon ports. |
266 |
267 |
.IP "\fB\-e \fIfile\fR" |
268 |
Redirect diagnostics and progress reports to \fIfile\fR instead of the |
269 |
console. |
270 |
271 |
.IP "\fB\-fo\fR[\fB+\fR|\fB-\fR]" |
272 |
Toggles overwriting of output files. By default, \fImkpmap\fR will not |
273 |
overwrite an already existing photon map file. This is to prevent |
274 |
inadvertently destroying the results of potentially lengthy photon |
275 |
mapping runs. |
276 |
277 |
.IP "\fB\-ld \fImaxdist\fR" |
278 |
Limit cumulative distance travelled by a photon along its path to |
279 |
\fImaxdist\fR. Photon hits within this distance will be stored, and the |
280 |
photon is terminated once its path length exceeds this limit. This is |
281 |
useful for setting radial regions of interest around emitting/reflecting |
282 |
geometry, but may increase the photon distribution time. |
283 |
.IP |
284 |
285 |
286 |
287 |
288 |
.IP "\fB\-lr \fImaxbounce\fR" |
289 |
Limit number of bounces (scattering events) along a photon path to |
290 |
\fImaxbounce\fR before being considered "runaway" and terminated. Photons |
291 |
paths are normally terminated via \fIRussian Roulette\fR, depending on their |
292 |
albedo. With unrealistically high albedos, this is not guaranteed, and this |
293 |
option imposes a hard limit to avoid an infinite loop. |
294 |
.IP |
295 |
296 |
297 |
298 |
299 |
.IP "\fB\-ma \fIralb galb balb\fR" |
300 |
Set the global scattering albedo for participating media in conjunction |
301 |
with the \fB\-apv\fR option. See \fIrpict(1)\fR for details. |
302 |
303 |
.IP "\fB\-me \fIrext gext bext\fR" |
304 |
Set the global extinction coefficient for participating media in conjunction |
305 |
306 |
307 |
.IP "\fB\-mg \fIgecc\fR" |
308 |
Set the global scattering eccentricity for participating media in conjunction |
309 |
310 |
311 |
.IP "\fB\-n \fInproc\fR" |
312 |
Use \fInproc\fR processes for parallel photon distribution. There is no |
313 |
benefit in specifying more than the number of physical CPU cores available |
314 |
(so doan' even try). This option is currently not available on Windows -- |
315 |
so there, tuff luck. |
316 |
317 |
.IP "\fB\-t \fIinterval\fR" |
318 |
Output a progress report every \fIinterval\fR seconds. This includes |
319 |
statistics about the currently emitting light source (including number of |
320 |
partitions), the total number of photons emitted, the number of each type |
321 |
stored, the percentage of the completed pass (pre or main), and the elapsed |
322 |
time. |
323 |
324 |
.SH NOTES |
325 |
326 |
.SS Parametrisation |
327 |
\fIMkpmap\fR recognises multiplier suffixes (k = 1000, m = 1000000) to |
328 |
facilitate the specification of \fInphotons\fR, both in upper and lower |
329 |
case. |
330 |
.PP |
331 |
332 |
.SS Distribution Algorithm |
333 |
The photon distribution algorithm estimates the number of required |
334 |
photons to emit to arrive at the specified target count \fInphotons\fR |
335 |
per photon map using a distribution prepass followed by a main pass. |
336 |
As a result, \fImkpmap\fR generates the \fBapproximate\fR number of photons |
337 |
specified, which can vary by up to 10% for typical scenes, but can be |
338 |
higher for scenes with unusually high or low reflectance. In this case, |
339 |
the predistribution factor \fB\-apD\fR should be increased for scenes |
340 |
with low reflectance, and reduced for those with high reflectance. |
341 |
.PP |
342 |
There are situations which may prevent certain (or any) |
343 |
photon types from being generated, depending on the light source and material |
344 |
configuration. This typically occurs when attempting to generate a caustic |
345 |
photon map without specular materials present in the scene, or a volume |
346 |
photon map without participating media. Ill-configured light sources may also |
347 |
prevent indirect rays from reaching a surface, and thus no photons being |
348 |
deposited. In these cases, \fImkpmap\fR will make a number of distribution |
349 |
attempts before terminating with an error. This can be adjusted with the |
350 |
\fB\-apM\fR option. |
351 |
352 |
.SS Material Support |
353 |
Not all materials are fully supported by the photon map extension. The |
354 |
\fIplasfunc\fR, \fImetfunc\fR, \fItransfunc\fR, \fIplasdata\fR, |
355 |
\fImetdata\fR and \fItransdata\fR materials currently only scatter photons |
356 |
diffusely, and will not produce caustics. The \fIbrtdfunc\fR material only |
357 |
produces caustics via ideal (mirror) specular reflection and transmission. |
358 |
For more realistic scattering behaviour, use the newer \fIbsdf\fR material |
359 |
instead. |
360 |
.PP |
361 |
Virtual light sources (normally enabled with the \fImirror\fR material) are |
362 |
disabled with the photon map, as the resulting caustics are already accounted |
363 |
for. |
364 |
365 |
.SS Virtual Receiver Surfaces |
366 |
Since photons are surface bound, the density estimate is only asymptotically |
367 |
correct when performed at points which lie on the scene geometry. The |
368 |
irradiance is underestimated for arbitrarily placed points when photons are |
369 |
collected from distant surfaces. \fIMkpmap\fR offers a workaround with a |
370 |
virtual receiver surface using the \fIantimatter\fR material; see the \fB-aps\fR |
371 |
and \fB-apS\fR options for details. |
372 |
373 |
.SH EXAMPLES |
374 |
The following command generates a global photon map \fIbonzo.gpm\fR and a |
375 |
caustic photon map \fIbonzo.cpm\fR containing approximately 10000 and 100000 |
376 |
photons, respectively, with progress report every 5 seconds: |
377 |
.IP |
378 |
mkpmap \-apg bonzo.gpm 10k \-apc bonzo.cpm 100k -t 5 bonzo.oct |
379 |
.PP |
380 |
Generate a global photon map containing 80000 photons, then precompute the |
381 |
diffuse irradiance for 1/4 of these with a bandwidth of 40 photons: |
382 |
.IP |
383 |
mkpmap \-app bonzo-precomp.gpm 80k 40 \-apP 0.25 bonzo.oct |
384 |
.PP |
385 |
Generate 1 million global photons by emitting them from external light |
386 |
sources of type \fIsource\fR into a reference room via a fenestration |
387 |
with modifier \fIglazingMat\fR acting as photon port, with inward-facing |
388 |
normal: |
389 |
.IP |
390 |
mkpmap \-apg refRoom.gpm 1m \-apo glazingMat refRoom.oct |
391 |
.PP |
392 |
Generate a contribution photon map containing 10 million photons to bin |
393 |
light source contributions with \fIrcontrib(1)\fR: |
394 |
.IP |
395 |
mkpmap \-apC bonzo-contrib.gpm 10m bonzo.oct |
396 |
397 |
.SH BUGS |
398 |
The focus of a spotlight source, as defined by the length of its direction |
399 |
vector, is ignored by the photon map; photons are unconditionally emitted |
400 |
from the light source surface, which can lead to deviations from standard |
401 |
RADIANCE. |
402 |
.PP |
403 |
Light sources simply absorb incoming photons. |
404 |
405 |
.SH AUTHOR |
406 |
Roland Schregle (roland.schregle@{hslu.ch,gmail.com}) |
407 |
408 |
.SH COPYRIGHT |
409 |
(c) Fraunhofer Institute for Solar Energy Systems, |
410 |
.br |
411 |
(c) Lucerne University of Applied Sciences and Arts, |
412 |
.br |
413 |
(c) Tokyo University of Science. |
414 |
415 |
.SH ACKNOWLEDGEMENTS |
416 |
Development of the RADIANCE photon mapping extension was supported by: |
417 |
418 |
.RS |
419 |
\fIFraunhofer Institute for Solar Energy Systems\fR funded by |
420 |
the German Research Foundation (\fIDFG LU-204/10-2\fR, "Fassadenintegrierte |
421 |
Regelsysteme (FARESYS)"), |
422 |
423 |
\fILucerne University of Applied Sciences and Arts\fR funded by |
424 |
the Swiss National Science Foundation (\fISNSF 147053\fR, "Daylight redirecting components"), |
425 |
426 |
\fITokyo University of Science\fR funded by the JSPS Grants-in-Aid for Scientific |
427 |
Research Programme (\fIKAKENHI JP19KK0115\fR, "Three-dimensional light flow"). |
428 |
.RE |
429 |
430 |
Many thanks also to the many individuals who tested the code and provided |
431 |
valuable feedback. Special greetz to Don Gregorio, PAB and Capt.\~B! |
432 |
433 |
.SH "SEE ALSO" |
434 |
rpict(1), rtrace(1), rvu(1), rcontrib(1), |
435 |
.br |
436 |
\fIThe RADIANCE Photon Map Manual\fR, |
437 |
.br |
438 |
\fIDevelopment and Integration of the RADIANCE Photon Map Extension: |
439 |
Technical Report\fR, |
440 |
.br |
441 |
\fIThe RADIANCE Out-of-Core Photon Map: Technical Report\fR, |
442 |
.br |
443 |
\fIBonzo Daylighting Tool a.k.a. EvilDRC [TM]\fR |
444 |
