1 |
.\" RCSid "$Id: mkillum.1,v 1.4 2004/09/17 21:43:49 greg Exp $" |
2 |
.TH MKILLUM 1 10/6/95 RADIANCE |
3 |
.SH NAME |
4 |
mkillum - compute illum sources for a RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B mkillum |
7 |
8 |
.B "\-n nprocs" |
9 |
10 |
.B "rtrace options" |
11 |
12 |
.B octree |
13 |
.B "[ \< file .. ]" |
14 |
.br |
15 |
.B "mkillum [ rtrace options ] \-defaults" |
16 |
.SH DESCRIPTION |
17 |
.I Mkillum |
18 |
takes a prepared RADIANCE scene description and an octree and computes |
19 |
light source distributions for each surface, replacing them with |
20 |
secondary sources whose contributions can be computed more efficiently by |
21 |
.I rpict(1) |
22 |
and |
23 |
.I rvu(1). |
24 |
This type of optimization is most useful for windows and skylights which |
25 |
represent concentrated sources of indirect illumination. |
26 |
.I Mkillum |
27 |
is not appropriate for very large sources or sources with highly |
28 |
directional distributions. |
29 |
These are best handled respectively by the ambient calculation |
30 |
and the secondary source types in RADIANCE. |
31 |
.PP |
32 |
If the |
33 |
.I \-n |
34 |
option is specified with a value greater than 1, multiple |
35 |
.I rtrace(1) |
36 |
processes will be used to accelerate computation on a shared |
37 |
memory machine. |
38 |
Note that there is no benefit to using more processes |
39 |
than there are local CPUs available to do the work. |
40 |
.PP |
41 |
Remaining arguments to |
42 |
.I mkillum |
43 |
are passed directly to |
44 |
.I rtrace(1), |
45 |
which is used to compute the light distributions for the input surfaces. |
46 |
These surfaces can be any combination of polygons, spheres and rings. |
47 |
Other surfaces may be included, but |
48 |
.I mkillum |
49 |
cannot compute their distributions. |
50 |
.PP |
51 |
By default, |
52 |
.I mkillum |
53 |
reads from its standard input and writes to its standard output. |
54 |
It is possible to specify multiple input files in a somewhat |
55 |
unconventional fashion by placing a lesser-than symbol ('<') before |
56 |
the file names. |
57 |
(Note that this character must be escaped from most shells.) |
58 |
This is necessary so |
59 |
.I mkillum |
60 |
can tell where the arguments to |
61 |
.I rtrace(1) |
62 |
end and its own input files begin. |
63 |
.SH VARIABLES |
64 |
.I Mkillum |
65 |
has a number of parameters that can be changed by |
66 |
comments in the input file of the form: |
67 |
.nf |
68 |
69 |
#@mkillum variable=value option switch{+|-} .. |
70 |
71 |
.fi |
72 |
String or integer variables are separated from their values by the |
73 |
equals sign ('='). |
74 |
Options appear by themselves. |
75 |
Switches are followed either by a |
76 |
plus sign to turn them on or a minus sign to turn them off. |
77 |
.PP |
78 |
Parameters are usually changed many times within the |
79 |
same input file to tailor the calculation, specify different |
80 |
labels and so on. |
81 |
The parameters and their meanings are described below. |
82 |
.TP 10n |
83 |
.BI o =string |
84 |
Set the output file to |
85 |
.I string. |
86 |
All subsequent scene data will be sent to this file. |
87 |
If this appears in the first comment in the input, nothing will be |
88 |
sent to the standard output. |
89 |
Note that this is not recommended when running |
90 |
.I mkillum |
91 |
from |
92 |
.I rad(1), |
93 |
which expects the output to be on the standard output. |
94 |
.TP |
95 |
.BI m =string |
96 |
Set the material identifier to |
97 |
.I string. |
98 |
This name will be used not only as the new surface modifier, but it |
99 |
will also be used to name the distribution pattern and the data files. |
100 |
The distribution name will be |
101 |
.I string |
102 |
plus the suffix ".dist". |
103 |
The data file will be named |
104 |
.I string |
105 |
plus possibly an integer plus a ".dat" suffix. |
106 |
The integer is used to avoid accidently writing over an existing |
107 |
file. |
108 |
If overwriting the file is desired, use the |
109 |
.I f |
110 |
variable below. |
111 |
.TP |
112 |
.BI f =string |
113 |
Set the data file name to |
114 |
.I string. |
115 |
The next data file will be given this name plus a ".dat" suffix. |
116 |
Subsequent files will be named |
117 |
.I string |
118 |
plus an integer plus the ".dat" suffix. |
119 |
An existing file with the same name will be clobbered. |
120 |
This variable may be unset by leaving off the value. |
121 |
(See also the |
122 |
.I m |
123 |
variable above.) |
124 |
.TP |
125 |
.BR a |
126 |
Produce secondary sources for all of the surfaces in the input. |
127 |
This is the default. |
128 |
.TP |
129 |
.BI e =string |
130 |
Produce secondary sources for all surfaces except those modified by |
131 |
.I string. |
132 |
Surfaces modified by |
133 |
.I string |
134 |
will be passed to the output unchanged. |
135 |
.TP |
136 |
.BI i =string |
137 |
Only produce secondary sources for surfaces modified by |
138 |
.I string. |
139 |
.TP |
140 |
.BR n |
141 |
Do not produce any secondary sources. |
142 |
All input will be passed to the output unaffected. |
143 |
.TP |
144 |
.BI b =real |
145 |
Do not produce a secondary source for a surface if its average |
146 |
brightness (radiance) is less than the value |
147 |
.I real. |
148 |
.TP |
149 |
.BI c ={d|a|n} |
150 |
Use color information according to the given character. |
151 |
If the character is |
152 |
.I d, |
153 |
then color information will be used in three separate data files and |
154 |
the distribution will be fully characterized in terms of color. |
155 |
156 |
.I a, |
157 |
then only the average color is computed and the distribution will |
158 |
not contain color information. |
159 |
160 |
.I n, |
161 |
even the average distribution color will be thrown away, |
162 |
producing secondary sources that are completely uncolored. |
163 |
This may be desirable from a color-balancing point of view. |
164 |
.TP |
165 |
.BI d =integer |
166 |
Set the number of direction samples per projected steradian to |
167 |
.I integer. |
168 |
The number of directions stored in the associated data file will be |
169 |
approximately this number multiplied by pi for polygons and rings, and |
170 |
by 4pi for spheres. |
171 |
If |
172 |
.I integer |
173 |
is zero, then a diffuse source is assumed and no distribution is |
174 |
created. |
175 |
.TP |
176 |
.BI s =integer |
177 |
Set the number of ray samples per direction to |
178 |
.I integer. |
179 |
This variable affects the accuracy of the distribution value for |
180 |
each direction as well as the computation time for |
181 |
.I mkillum. |
182 |
.TP |
183 |
.BR l{+|-} |
184 |
Switch between light sources and illum sources. |
185 |
If this switch is enabled |
186 |
.I (l+), |
187 |
.I mkillum |
188 |
will use the material type "light" to represent surfaces. |
189 |
If disabled |
190 |
.I (l-), |
191 |
.I mkillum |
192 |
will use the material type "illum" with the input surface modifier |
193 |
as its alternate material. |
194 |
The default is |
195 |
.I l-. |
196 |
.SH EXAMPLES |
197 |
The following command generates illum's corresponding to geometry |
198 |
in the files "it1.rad" and "it2.rad": |
199 |
.IP "" .3i |
200 |
mkillum -ab 2 -ad 1024 -av .1 .1 .1 basic.oct "<" it1.rad it2.rad > illums.rad |
201 |
.PP |
202 |
The output file "illums.rad" would then be combined with the original |
203 |
scene geometry to create a more easily rendered composite. |
204 |
.SH AUTHOR |
205 |
Greg Ward |
206 |
.SH ACKNOWLEDGEMENT |
207 |
Work on this program was initiated and sponsored by the LESO |
208 |
group at EPFL in Switzerland. |
209 |
.SH "SEE ALSO" |
210 |
oconv(1), rad(1), rpict(1), rtrace(1), rvu(1) |
