--- ray/doc/man/man1/mkillum.1 2003/12/09 15:59:06 1.2 +++ ray/doc/man/man1/mkillum.1 2007/09/04 17:36:40 1.6 @@ -1,10 +1,12 @@ -.\" RCSid "$Id: mkillum.1,v 1.2 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: mkillum.1,v 1.6 2007/09/04 17:36:40 greg Exp $" .TH MKILLUM 1 10/6/95 RADIANCE .SH NAME mkillum - compute illum sources for a RADIANCE scene .SH SYNOPSIS .B mkillum [ +.B "\-n nprocs" +][ .B "rtrace options" ] .B octree @@ -18,7 +20,7 @@ light source distributions for each surface, replacing secondary sources whose contributions can be computed more efficiently by .I rpict(1) and -.I rview(1). +.I rvu(1). This type of optimization is most useful for windows and skylights which represent concentrated sources of indirect illumination. .I Mkillum @@ -27,7 +29,16 @@ directional distributions. These are best handled respectively by the ambient calculation and the secondary source types in RADIANCE. .PP -The arguments to +If the +.I \-n +option is specified with a value greater than 1, multiple +.I rtrace(1) +processes will be used to accelerate computation on a shared +memory machine. +Note that there is no benefit to using more processes +than there are local CPUs available to do the work. +.PP +Remaining arguments to .I mkillum are passed directly to .I rtrace(1), @@ -182,10 +193,18 @@ will use the material type "illum" with the input surf as its alternate material. The default is .I l-. +.SH EXAMPLES +The following command generates illum's corresponding to geometry +in the files "it1.rad" and "it2.rad": +.IP "" .3i +mkillum \-ab 2 \-ad 1024 \-av .1 .1 .1 basic.oct "<" it1.rad it2.rad > illums.rad +.PP +The output file "illums.rad" would then be combined with the original +scene geometry to create a more easily rendered composite. .SH AUTHOR Greg Ward .SH ACKNOWLEDGEMENT Work on this program was initiated and sponsored by the LESO group at EPFL in Switzerland. .SH "SEE ALSO" -oconv(1), rad(1), rpict(1), rtrace(1), rview(1) +oconv(1), rad(1), rpict(1), rtrace(1), rvu(1)
