--- ray/doc/man/man1/mkillum.1 2003/12/09 15:59:06 1.2 +++ ray/doc/man/man1/mkillum.1 2012/10/13 20:15:43 1.11 @@ -1,10 +1,12 @@ -.\" RCSid "$Id: mkillum.1,v 1.2 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: mkillum.1,v 1.11 2012/10/13 20:15:43 greg Exp $" .TH MKILLUM 1 10/6/95 RADIANCE .SH NAME mkillum - compute illum sources for a RADIANCE scene .SH SYNOPSIS .B mkillum [ +.B "\-n nprocs" +][ .B "rtrace options" ] .B octree @@ -18,7 +20,7 @@ light source distributions for each surface, replacing secondary sources whose contributions can be computed more efficiently by .I rpict(1) and -.I rview(1). +.I rvu(1). This type of optimization is most useful for windows and skylights which represent concentrated sources of indirect illumination. .I Mkillum @@ -27,11 +29,19 @@ directional distributions. These are best handled respectively by the ambient calculation and the secondary source types in RADIANCE. .PP -The arguments to +If the +.I \-n +option is specified with a value greater than 1, multiple +ray tracing processes will be used to accelerate computation on a shared +memory machine. +Note that there is no benefit to using more processes +than there are local CPUs available to do the work. +.PP +Remaining arguments to .I mkillum -are passed directly to +are interpreted as rendering options for .I rtrace(1), -which is used to compute the light distributions for the input surfaces. +to compute the light distributions for the input surfaces. These surfaces can be any combination of polygons, spheres and rings. Other surfaces may be included, but .I mkillum @@ -46,8 +56,7 @@ the file names. (Note that this character must be escaped from most shells.) This is necessary so .I mkillum -can tell where the arguments to -.I rtrace(1) +can tell where the rendering arguments end and its own input files begin. .SH VARIABLES .I Mkillum @@ -128,7 +137,8 @@ Only produce secondary sources for surfaces modified b .TP .BR n Do not produce any secondary sources. -All input will be passed to the output unaffected. +All input will be passed to the output unaffected, except any +void surfaces will be removed. .TP .BI b =real Do not produce a secondary source for a surface if its average @@ -182,10 +192,34 @@ will use the material type "illum" with the input surf as its alternate material. The default is .I l-. +.TP +.BI t =real +Set the surface thickness to +.I real +in world coordinates. +This value is used for determining where to start rays that need to begin +on the opposite side of a fenestration system, specifically +to compute the incoming distribution for a BSDF computation. +If the thickness is set to 0 and a BSDF contains detailed geometry, +it will be translated and output as part of the new description, provided the +.I l- +option is also in effect. +(This currently works only for rectangular polygons.)\0 +The default thickness is 0. +.SH EXAMPLES +The following command generates illum's corresponding to geometry +in the files "it1.rad" and "it2.rad": +.IP "" .3i +mkillum \-ab 2 \-ad 1024 \-av .1 .1 .1 basic.oct "<" it1.rad it2.rad > illums.rad +.PP +The output file "illums.rad" would then be combined with the original +scene geometry to create a more easily rendered composite. +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward .SH ACKNOWLEDGEMENT Work on this program was initiated and sponsored by the LESO group at EPFL in Switzerland. .SH "SEE ALSO" -oconv(1), rad(1), rpict(1), rtrace(1), rview(1) +genBSDF(1), oconv(1), rad(1), rpict(1), rtrace(1), rvu(1)
