| 1 |
.\" RCSid "$Id"
| 2 |
.TH MKILLUM 1 10/6/95 RADIANCE
| 3 |
.SH NAME
| 4 |
mkillum - compute illum sources for a RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B mkillum
| 7 |
| 8 |
.B "rtrace options"
| 9 |
| 10 |
.B octree
| 11 |
.B "[ \< file .. ]"
| 12 |
.br
| 13 |
.B "mkillum [ rtrace options ] \-defaults"
| 14 |
.SH DESCRIPTION
| 15 |
.I Mkillum
| 16 |
takes a prepared RADIANCE scene description and an octree and computes
| 17 |
light source distributions for each surface, replacing them with
| 18 |
secondary sources whose contributions can be computed more efficiently by
| 19 |
.I rpict(1)
| 20 |
and
| 21 |
.I rview(1).
| 22 |
This type of optimization is most useful for windows and skylights which
| 23 |
represent concentrated sources of indirect illumination.
| 24 |
.I Mkillum
| 25 |
is not appropriate for very large sources or sources with highly
| 26 |
directional distributions.
| 27 |
These are best handled respectively by the ambient calculation
| 28 |
and the secondary source types in RADIANCE.
| 29 |
.PP
| 30 |
The arguments to
| 31 |
.I mkillum
| 32 |
are passed directly to
| 33 |
.I rtrace(1),
| 34 |
which is used to compute the light distributions for the input surfaces.
| 35 |
These surfaces can be any combination of polygons, spheres and rings.
| 36 |
Other surfaces may be included, but
| 37 |
.I mkillum
| 38 |
cannot compute their distributions.
| 39 |
.PP
| 40 |
By default,
| 41 |
.I mkillum
| 42 |
reads from its standard input and writes to its standard output.
| 43 |
It is possible to specify multiple input files in a somewhat
| 44 |
unconventional fashion by placing a lesser-than symbol ('<') before
| 45 |
the file names.
| 46 |
(Note that this character must be escaped from most shells.)
| 47 |
This is necessary so
| 48 |
.I mkillum
| 49 |
can tell where the arguments to
| 50 |
.I rtrace(1)
| 51 |
end and its own input files begin.
| 52 |
.SH VARIABLES
| 53 |
.I Mkillum
| 54 |
has a number of parameters that can be changed by
| 55 |
comments in the input file of the form:
| 56 |
.nf
| 57 |
| 58 |
#@mkillum variable=value option switch{+|-} ..
| 59 |
| 60 |
.fi
| 61 |
String or integer variables are separated from their values by the
| 62 |
equals sign ('=').
| 63 |
Options appear by themselves.
| 64 |
Switches are followed either by a
| 65 |
plus sign to turn them on or a minus sign to turn them off.
| 66 |
.PP
| 67 |
Parameters are usually changed many times within the
| 68 |
same input file to tailor the calculation, specify different
| 69 |
labels and so on.
| 70 |
The parameters and their meanings are described below.
| 71 |
.TP 10n
| 72 |
.BI o =string
| 73 |
Set the output file to
| 74 |
.I string.
| 75 |
All subsequent scene data will be sent to this file.
| 76 |
If this appears in the first comment in the input, nothing will be
| 77 |
sent to the standard output.
| 78 |
Note that this is not recommended when running
| 79 |
.I mkillum
| 80 |
from
| 81 |
.I rad(1),
| 82 |
which expects the output to be on the standard output.
| 83 |
.TP
| 84 |
.BI m =string
| 85 |
Set the material identifier to
| 86 |
.I string.
| 87 |
This name will be used not only as the new surface modifier, but it
| 88 |
will also be used to name the distribution pattern and the data files.
| 89 |
The distribution name will be
| 90 |
.I string
| 91 |
plus the suffix ".dist".
| 92 |
The data file will be named
| 93 |
.I string
| 94 |
plus possibly an integer plus a ".dat" suffix.
| 95 |
The integer is used to avoid accidently writing over an existing
| 96 |
file.
| 97 |
If overwriting the file is desired, use the
| 98 |
.I f
| 99 |
variable below.
| 100 |
.TP
| 101 |
.BI f =string
| 102 |
Set the data file name to
| 103 |
.I string.
| 104 |
The next data file will be given this name plus a ".dat" suffix.
| 105 |
Subsequent files will be named
| 106 |
.I string
| 107 |
plus an integer plus the ".dat" suffix.
| 108 |
An existing file with the same name will be clobbered.
| 109 |
This variable may be unset by leaving off the value.
| 110 |
(See also the
| 111 |
.I m
| 112 |
variable above.)
| 113 |
.TP
| 114 |
.BR a
| 115 |
Produce secondary sources for all of the surfaces in the input.
| 116 |
This is the default.
| 117 |
.TP
| 118 |
.BI e =string
| 119 |
Produce secondary sources for all surfaces except those modified by
| 120 |
.I string.
| 121 |
Surfaces modified by
| 122 |
.I string
| 123 |
will be passed to the output unchanged.
| 124 |
.TP
| 125 |
.BI i =string
| 126 |
Only produce secondary sources for surfaces modified by
| 127 |
.I string.
| 128 |
.TP
| 129 |
.BR n
| 130 |
Do not produce any secondary sources.
| 131 |
All input will be passed to the output unaffected.
| 132 |
.TP
| 133 |
.BI b =real
| 134 |
Do not produce a secondary source for a surface if its average
| 135 |
brightness (radiance) is less than the value
| 136 |
.I real.
| 137 |
.TP
| 138 |
.BI c ={d|a|n}
| 139 |
Use color information according to the given character.
| 140 |
If the character is
| 141 |
.I d,
| 142 |
then color information will be used in three separate data files and
| 143 |
the distribution will be fully characterized in terms of color.
| 144 |
If the character is
| 145 |
.I a,
| 146 |
then only the average color is computed and the distribution will
| 147 |
not contain color information.
| 148 |
If the character is
| 149 |
.I n,
| 150 |
even the average distribution color will be thrown away,
| 151 |
producing secondary sources that are completely uncolored.
| 152 |
This may be desirable from a color-balancing point of view.
| 153 |
.TP
| 154 |
.BI d =integer
| 155 |
Set the number of direction samples per projected steradian to
| 156 |
.I integer.
| 157 |
The number of directions stored in the associated data file will be
| 158 |
approximately this number multiplied by pi for polygons and rings, and
| 159 |
by 4pi for spheres.
| 160 |
If
| 161 |
.I integer
| 162 |
is zero, then a diffuse source is assumed and no distribution is
| 163 |
created.
| 164 |
.TP
| 165 |
.BI s =integer
| 166 |
Set the number of ray samples per direction to
| 167 |
.I integer.
| 168 |
This variable affects the accuracy of the distribution value for
| 169 |
each direction as well as the computation time for
| 170 |
.I mkillum.
| 171 |
.TP
| 172 |
.BR l{+|-}
| 173 |
Switch between light sources and illum sources.
| 174 |
If this switch is enabled
| 175 |
.I (l+),
| 176 |
.I mkillum
| 177 |
will use the material type "light" to represent surfaces.
| 178 |
If disabled
| 179 |
.I (l-),
| 180 |
.I mkillum
| 181 |
will use the material type "illum" with the input surface modifier
| 182 |
as its alternate material.
| 183 |
The default is
| 184 |
.I l-.
| 185 |
.SH AUTHOR
| 186 |
Greg Ward
| 187 |
.SH ACKNOWLEDGEMENT
| 188 |
Work on this program was initiated and sponsored by the LESO
| 189 |
group at EPFL in Switzerland.
| 190 |
.SH "SEE ALSO"
| 191 |
oconv(1), rad(1), rpict(1), rtrace(1), rview(1)
