--- ray/doc/man/man1/mgf2rad.1 2003/03/11 19:20:21 1.1 +++ ray/doc/man/man1/mgf2rad.1 2024/01/17 00:43:45 1.4 @@ -1,10 +1,12 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: mgf2rad.1,v 1.4 2024/01/17 00:43:45 greg Exp $" .TH MGF2RAD 1 4/12/95 RADIANCE .SH NAME mgf2rad - convert Materials and Geometry Format file to RADIANCE description .SH SYNOPSIS .B mgf2rad [ +.B \-s +][ .B "\-m matfile" ][ .B "\-e mult" @@ -53,6 +55,15 @@ into a single file, since no output is produced for un materials; i.e. translating just the MGF materials does not work. .PP The +.I \-s +option turns on spectral data conversion, producing "spectrum" +modifiers in the output as supported by RADIANCE 6.0 and later. +If you do not plan to employ spectral rendering, then it is +better to have +.I mgf2rad +convert to RGB colors, which is the default. +.PP +The .I \-e option may be used to multiply all the emission values by the given @@ -72,9 +83,9 @@ one geometry file: mgf2rad -m materials.rad building1.mgf building2.mgf > building1+2.rad .PP To create an octree directly from two MGF files and one RADIANCE -file: +file, including spectra: .IP "" .2i -oconv '\\!mgf2rad materials.mgf scene.mgf' source.rad > scene.oct +oconv '!mgf2rad -s materials.mgf scene.mgf' source.rad > scene.oct .SH FILES tmesh.cal Used to smooth polygonal geometry .br
