root/Development/ray/doc/man/man1/mgf2rad.1
Revision: 1.4
Committed: Wed Jan 17 00:43:45 2024 UTC (20 months, 4 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 1.3: +15 -4 lines
feat(mgf2rad): Made spectra conversion optional with -s command-line flag
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: mgf2rad.1,v 1.3 2007/09/04 17:36:40 greg Exp $"
2 greg 1.1 .TH MGF2RAD 1 4/12/95 RADIANCE
3     .SH NAME
4     mgf2rad - convert Materials and Geometry Format file to RADIANCE description
5     .SH SYNOPSIS
6     .B mgf2rad
7     [
8 greg 1.4 .B \-s
9     ][
10 greg 1.1 .B "\-m matfile"
11     ][
12     .B "\-e mult"
13     ][
14     .B "\-g dist"
15     ]
16     [
17     .B input ..
18     ]
19     .SH DESCRIPTION
20     .I Mgf2rad
21     converts one or more Materials and Geometry Format (MGF)
22     files to a RADIANCE scene description.
23     By definition, all output dimensions are in meters.
24     The material names and properties
25     for the surfaces will be those assigned in MGF.
26     Any materials not defined in MGF will result in an error during
27     translation.
28     Light sources are described inline as IES luminaire files, and
29     .I mgf2rad
30     calls the program
31     .I ies2rad(1)
32     to translate these files.
33     If an IES file in turn contains an MGF description of the local
34     fixture geometry, this may result in a recursive call to
35     .I mgf2rad,
36     which is normal and should be transparent.
37     The only side-effect of this additional translation is the
38     appearance of other RADIANCE scene and data files produced
39     automatically by
40     .I ies2rad.
41     .PP
42     The
43     .I \-m
44     option may be used to put all the translated materials into a separate
45     RADIANCE file.
46     This is not always advisable, as any given material name may be
47     reused at different points in the MGF description, and writing them
48     to a separate file loses the contextual association between
49     materials and surfaces.
50     As long as unique material names are used throughout the MGF
51     description and material properties are not redefined, there
52     will be no problem.
53     Note that this is the only way to get all the translated materials
54     into a single file, since no output is produced for unreferenced
55     materials; i.e. translating just the MGF materials does not work.
56     .PP
57     The
58 greg 1.4 .I \-s
59     option turns on spectral data conversion, producing "spectrum"
60     modifiers in the output as supported by RADIANCE 6.0 and later.
61     If you do not plan to employ spectral rendering, then it is
62     better to have
63     .I mgf2rad
64     convert to RGB colors, which is the default.
65     .PP
66     The
67 greg 1.1 .I \-e
68     option may be used to multiply all the emission values by the
69     given
70     .I mult
71     factor.
72     The
73     .I \-g
74     option may be used to establish a glow distance (in meters)
75     for all emitting surfaces.
76     These two options are employed principally by
77     .I ies2rad,
78     and are not generally useful to most users.
79     .SH EXAMPLE
80     To translate two MGF files into one RADIANCE materials file and
81     one geometry file:
82     .IP "" .2i
83 greg 1.4 mgf2rad -m materials.rad building1.mgf building2.mgf > building1+2.rad
84 greg 1.1 .PP
85     To create an octree directly from two MGF files and one RADIANCE
86 greg 1.4 file, including spectra:
87 greg 1.1 .IP "" .2i
88 greg 1.4 oconv '!mgf2rad -s materials.mgf scene.mgf' source.rad > scene.oct
89 greg 1.1 .SH FILES
90     tmesh.cal Used to smooth polygonal geometry
91     .br
92     *.rad RADIANCE source descriptions created by ies2rad
93     .br
94     *.dat RADIANCE source data created by ies2rad
95     .br
96     source.cal Used for IES source coordinates
97     .SH AUTHOR
98     Greg Ward
99     .SH "SEE ALSO"
100     ies2rad(1), mgf2meta(1), obj2rad(1), oconv(1), rad2mgf(1), xform(1)
101     .PP
102     MGF web site "http://radsite.lbl.gov/mgf/HOME.html"
