root/radiance/ray/doc/man/man1/mgf2rad.1
Revision: 1.2
Committed: Tue Dec 9 15:59:06 2003 UTC (21 years, 5 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH MGF2RAD 1 4/12/95 RADIANCE
3 .SH NAME
4 mgf2rad - convert Materials and Geometry Format file to RADIANCE description
5 .SH SYNOPSIS
6 .B mgf2rad
7 [
8 .B "\-m matfile"
9 ][
10 .B "\-e mult"
11 ][
12 .B "\-g dist"
13 ]
14 [
15 .B input ..
16 ]
17 .SH DESCRIPTION
18 .I Mgf2rad
19 converts one or more Materials and Geometry Format (MGF)
20 files to a RADIANCE scene description.
21 By definition, all output dimensions are in meters.
22 The material names and properties
23 for the surfaces will be those assigned in MGF.
24 Any materials not defined in MGF will result in an error during
25 translation.
26 Light sources are described inline as IES luminaire files, and
27 .I mgf2rad
28 calls the program
29 .I ies2rad(1)
30 to translate these files.
31 If an IES file in turn contains an MGF description of the local
32 fixture geometry, this may result in a recursive call to
33 .I mgf2rad,
34 which is normal and should be transparent.
35 The only side-effect of this additional translation is the
36 appearance of other RADIANCE scene and data files produced
37 automatically by
38 .I ies2rad.
39 .PP
40 The
41 .I \-m
42 option may be used to put all the translated materials into a separate
43 RADIANCE file.
44 This is not always advisable, as any given material name may be
45 reused at different points in the MGF description, and writing them
46 to a separate file loses the contextual association between
47 materials and surfaces.
48 As long as unique material names are used throughout the MGF
49 description and material properties are not redefined, there
50 will be no problem.
51 Note that this is the only way to get all the translated materials
52 into a single file, since no output is produced for unreferenced
53 materials; i.e. translating just the MGF materials does not work.
54 .PP
55 The
56 .I \-e
57 option may be used to multiply all the emission values by the
58 given
59 .I mult
60 factor.
61 The
62 .I \-g
63 option may be used to establish a glow distance (in meters)
64 for all emitting surfaces.
65 These two options are employed principally by
66 .I ies2rad,
67 and are not generally useful to most users.
68 .SH EXAMPLE
69 To translate two MGF files into one RADIANCE materials file and
70 one geometry file:
71 .IP "" .2i
72 mgf2rad -m materials.rad building1.mgf building2.mgf > building1+2.rad
73 .PP
74 To create an octree directly from two MGF files and one RADIANCE
75 file:
76 .IP "" .2i
77 oconv '\\!mgf2rad materials.mgf scene.mgf' source.rad > scene.oct
78 .SH FILES
79 tmesh.cal Used to smooth polygonal geometry
80 .br
81 *.rad RADIANCE source descriptions created by ies2rad
82 .br
83 *.dat RADIANCE source data created by ies2rad
84 .br
85 source.cal Used for IES source coordinates
86 .SH AUTHOR
87 Greg Ward
88 .SH "SEE ALSO"
89 ies2rad(1), mgf2meta(1), obj2rad(1), oconv(1), rad2mgf(1), xform(1)
90 .PP
91 MGF web site "http://radsite.lbl.gov/mgf/HOME.html"
