root/radiance/ray/doc/man/man1/meta2bmp.1
Revision: 1.3
Committed: Tue Sep 4 17:36:40 2007 UTC (17 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad5R3, HEAD
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: meta2bmp.1,v 1.2 2005/10/27 00:20:08 greg Exp $"
2 .TH META2BMP 1 6/24/98 RADIANCE
3 .SH NAME
4 meta2bmp - convert metafile to Windows Bitmap (BMP) File
5 .SH SYNOPSIS
6 .B meta2bmp
7 [
8 .B \-c | \-r
9 ][
10 .B "\-x width"
11 ][
12 .B "\-y height"
13 ][
14 .B "\-m minrad"
15 ][
16 .B "\-o outname"
17 ]
18 file ..
19 .SH DESCRIPTION
20 .I Meta2bmp
21 reads each metafile
22 .I file
23 in sequence and converts it to a compressed, color-mapped BMP file.
24 The result is sent to the standard output (which must be redirected)
25 unless the
26 .I \-o
27 option is used.
28 The argument to the
29 .I \-o
30 option specifies the base file name, to which a page number and ".bmp" is added
31 as a suffix.
32 Note that this option must be present in order to produce more than a single
33 page of output.
34 .PP
35 The default output resolution is 400 by 400, but a different resolution
36 can be given with the
37 .I \-x
38 and
39 .I \-y
40 options.
41 .PP
42 The
43 .I \-m
44 option can be used to set a minimum value for the line radius in pixels.
45 This may be helpful for improving the readability of high resolution output.
46 The default value is 0, which allows lines of one pixel thickness.
47 .PP
48 If the option
49 .I \-c
50 is specified, the input files are only conditioned for output, ie.
51 expanded (see pexpand).
52 This is useful if many copies of the same output is desired.
53 If the option
54 .I \-r
55 is instead specified, the input is assumed already to be conditioned.
56 If no input files are specified, the standard input is read.
57 .SH EXAMPLE
58 To convert the plots examp1.plt and examp2.plt to 1024x1024 Targa files:
59 .IP "" .2i
60 bgraph examp1.plt examp2.plt | meta2bmp \-o examp \-x 1024 \-y 1024
61 .SH FILES
62 see pexpand(1) and psort(1)
63 .SH AUTHOR
64 Greg Ward
65 .SH "SEE ALSO"
66 bgraph(1), igraph(1), meta2tga(1), pexpand(1), psmeta(1),
67 psort(1), ra_t8(1)
