| 1 |
.\" RCSid "$Id: macbethcal.1,v 1.3 2004/01/01 19:31:45 greg Exp $"
| 2 |
.TH MACBETHCAL 1 1/16/97 RADIANCE
| 3 |
.SH NAME
| 4 |
macbethcal - compute color compensation based on measured Macbeth chart
| 5 |
.SH SYNOPSIS
| 6 |
.B macbethcal
| 7 |
| 8 |
.B "\-d debug.pic"
| 9 |
| 10 |
.B "\-p xul yul xur yur xll yll xlr ylr"
| 11 |
| 12 |
.B scannedin.pic
| 13 |
| 14 |
.B calibout.cal
| 15 |
| 16 |
.br
| 17 |
.B macbethcal
| 18 |
.B \-c
| 19 |
| 20 |
.B "\-d debug.pic"
| 21 |
| 22 |
| 23 |
.B measured.xyY
| 24 |
| 25 |
.B calibout.cal
| 26 |
| 27 |
| 28 |
.SH DESCRIPTION
| 29 |
.I Macbethcal
| 30 |
takes a scanned image or measurement set
| 31 |
of a Macbeth ColorChecker\u\s-3TM\s+3\d color
| 32 |
rendition chart and computes a color mapping
| 33 |
function suitable as input to
| 34 |
.I pcomb(1).
| 35 |
.PP
| 36 |
In the first form,
| 37 |
.I macbethcal
| 38 |
takes a scanned image of a Macbeth chart that has been converted
| 39 |
into a Radiance picture using a fixed procedure.
| 40 |
When used properly as input to
| 41 |
.I pcomb,
| 42 |
the computed calibration file will adjust the
| 43 |
brightness and color of any similarly scanned and converted image
| 44 |
so as to best match the original.
| 45 |
If the lighting conditions are carefully controlled (as in the case
| 46 |
of a flatbed scanner), it is even possible to get reliable
| 47 |
reflectance values this way, at least within 10% or so.
| 48 |
The input picture is named on the command line.
| 49 |
The output calibration file will be written to the standard output
| 50 |
if no file name is given on the command line.
| 51 |
.PP
| 52 |
In the second form, the input is from a file containing measured
| 53 |
values for each Macbeth color.
| 54 |
This file must contain entries of the form:
| 55 |
.sp
| 56 |
.nf
| 57 |
N x y Y
| 58 |
.fi
| 59 |
.sp
| 60 |
Where
| 61 |
.I N
| 62 |
is the number of the corresponding Macbeth color.
| 63 |
(See back of ColorChecker chart
| 64 |
for color names and indexing, but it basically starts from the upper
| 65 |
left with 1 and proceeds in English text order to the lower right,
| 66 |
which is 24.)
| 67 |
The values
| 68 |
.I x,
| 69 |
.I y
| 70 |
and
| 71 |
.I Y
| 72 |
are the 1931 CIE (x,y) chromaticity coordinates followed by the
| 73 |
luminance for that color, which can be in any units.
| 74 |
If a white value is known (i.e. maximum output level), then it may
| 75 |
be given as entry number 0.
| 76 |
The entries may be in any order, and comments may be included
| 77 |
delimited by a pound sign ('#') and continuing to the end of line.
| 78 |
It is recommended that measurements be done for all 24 colors,
| 79 |
but the only required entries are the 6 neutral values on the bottom
| 80 |
row of the chart.
| 81 |
.PP
| 82 |
Computing a mapping from measured colors is usually more convenient
| 83 |
when calibrating a particular output device.
| 84 |
This is accomplished by printing the picture
| 85 |
.I macbeth_spec.pic
| 86 |
(which may be found in the standard RADIANCE library directory in
| 87 |
the lib subdirectory) and measuring the output with a chroma meter
| 88 |
or spectrophotometer.
| 89 |
.PP
| 90 |
For a scanned image, the locations of the 24 Macbeth patches
| 91 |
in the input picture must be known.
| 92 |
If the chart borders are not at the edges of the input picture, or
| 93 |
the chart has been reversed or rotated or is uncentered or at an
| 94 |
oblique angle, then it is necessary to specify the pixel locations
| 95 |
of the corners of the chart with the
| 96 |
.I \-p
| 97 |
option.
| 98 |
The corner postions (x,y pixel addresses as given by the
| 99 |
.I ximage(1)
| 100 |
"p" command)
| 101 |
are ordered on the command line:
| 102 |
upper-left, upper-right, lower-left, lower-right
| 103 |
(i.e. English text ordering).
| 104 |
These coordinates should be the outside corner positions of
| 105 |
the following patches:
| 106 |
.sp
| 107 |
.nf
| 108 |
upper-left = 1. dark skin
| 109 |
upper-right = 6. bluish green
| 110 |
lower-left = 19. white
| 111 |
lower-right = 24. black
| 112 |
.fi
| 113 |
.sp
| 114 |
If the chart has been flipped or rotated, simply give the pixel
| 115 |
positions of the appropriate patch corners, wherever
| 116 |
they are in the image.
| 117 |
(Note: if the Radiance picture has been flipped or rotated with
| 118 |
.I pflip(1)
| 119 |
or
| 120 |
.I protate(1),
| 121 |
.I ximage
| 122 |
will report the original pixel positions if the
| 123 |
.I \-c
| 124 |
option was not used by the reorienting program(s).
| 125 |
This will be wrong, so be sure to use the
| 126 |
.I \-c
| 127 |
option.)
| 128 |
.I Macbethcal
| 129 |
can handle a chart with any orientation or perspective warping if
| 130 |
the corner coordinates are given correctly.
| 131 |
The debug picture output is the best way to check for consistency.
| 132 |
(See the
| 133 |
.I \-d
| 134 |
option, below.)
| 135 |
.PP
| 136 |
The
| 137 |
.I \-d
| 138 |
option may be used to specify an additional output file, which will
| 139 |
be a picture comparing the scanned image processed according to the
| 140 |
computed mapping against the standard Macbeth colors.
| 141 |
It is a good idea to use the debug option to check that the color
| 142 |
patches are being located correctly, and to see how well
| 143 |
.I macbethcal
| 144 |
does at matching colors.
| 145 |
The center of each patch will show the target color;
| 146 |
the left side of each patch will show the original
| 147 |
color, and the right side will show the corrected value.
| 148 |
If the match works well, the debug picture should have a sort of
| 149 |
"notch on the left" look in each patch.
| 150 |
Macbeth colors that could not be matched because they were out of
| 151 |
gamut on this device are indicated with diagonal lines drawn
| 152 |
through the associated target colors.
| 153 |
.SH METHOD
| 154 |
.I Macbethcal
| 155 |
computes the color mapping in two stages.
| 156 |
The first stage uses the six neutral color patches at the bottom of
| 157 |
the Macbeth chart to compute a piecewise linear approximation to the
| 158 |
brightness mapping of each RGB primary.
| 159 |
The second stage looks at all the colors that are within the
| 160 |
device's gamut to compute a
| 161 |
least-sqaures fit for a linear color transformation from the
| 162 |
measured space into the standard Radiance RGB space (as defined by
| 163 |
the three primaries in src/common/color.h).
| 164 |
.PP
| 165 |
Thanks to the nature of inverse mappings, this method should work
| 166 |
either for converting scanned data to match the original, or for
| 167 |
preconditioning pictures to be sent to specific output devices.
| 168 |
In other words, the same calibration file works either for
| 169 |
correcting scanned images OR precorrecting images before printing.
| 170 |
.PP
| 171 |
A warning is printed if some unsaturated colors are determined to
| 172 |
be out of gamut, as this may indicate a poor rendition or improper
| 173 |
picture alignment.
| 174 |
The debug picture will show which colors were excluded by drawing
| 175 |
diagonal lines through their entries.
| 176 |
.SH NOTE
| 177 |
It is very important that the same settings be applied when
| 178 |
scanning or printing other images to be calibrated with the computed file.
| 179 |
In particular, all exposure adjustments should be fixed manually,
| 180 |
and no tweaking of the settings should be done along the way.
| 181 |
The final result will be best if the original scanned image is not
| 182 |
too far off from what it should be.
| 183 |
In the case of slide and negative scanners, it is best to apply the
| 184 |
recommended calibration file for the type of film used, so long as
| 185 |
this calibration is fixed and not adjusted on a per-image basis.
| 186 |
.SH CHART AVAILABILITY
| 187 |
The Macbeth chart is available at most photographic supply stores,
| 188 |
or may be ordered directly from Macbeth:
| 189 |
.sp
| 190 |
.nf
| 191 |
Macbeth
| 192 |
Munsell Color
| 193 |
405 Little Britain Rd.
| 194 |
New Windsor, NY 12553-6148
| 195 |
tel. 1-800-622-2384 (USA)
| 196 |
fax. 1-914-561-0267
| 197 |
.fi
| 198 |
.sp
| 199 |
The chart sells for under $50 US at the time of this writing.
| 200 |
.SH EXAMPLES
| 201 |
To compute a calibration for a FunkyThing scanner and check the
| 202 |
results:
| 203 |
.IP "" .2i
| 204 |
ra_tiff \-r mbscan.tif mbscan.pic
| 205 |
.br
| 206 |
macbethcal \-d debug.pic mbscan.pic FunkyThing.cal
| 207 |
.br
| 208 |
ximage debug.pic
| 209 |
.PP
| 210 |
To apply this computed calibration to another scanned image:
| 211 |
.IP "" .2i
| 212 |
ra_tiff \-r another.tif | pcomb \-f FunkyThing.cal \- > another_calib.pic
| 213 |
.PP
| 214 |
To compute a calibration file for the BigWhiz film recorder, after
| 215 |
taking measurements of a slide made from macbeth_spec.pic:
| 216 |
.IP "" .2i
| 217 |
macbethcal \-c macbeth_spec.xyY BigWhiz.cal
| 218 |
.PP
| 219 |
To prepare a picture prior to output on the same film recorder:
| 220 |
.IP "" .2i
| 221 |
pcomb \-f BigWhiz.cal standard.pic > toprint.pic
| 222 |
.PP
| 223 |
To use
| 224 |
.I pcond(1)
| 225 |
to also adjust the image for human response:
| 226 |
.IP "" .2i
| 227 |
pcond \-f BigWhiz.cal \-h standard.pic > toprint.pic
| 228 |
.SH AUTHOR
| 229 |
Greg Ward
| 230 |
.br
| 231 |
Paul Heckbert supplied code for perspective projective mapping
| 232 |
.SH "SEE ALSO"
| 233 |
icalc(1), pcomb(1), pcond(1), pfilt(1), ximage(1)
