root/Development/ray/doc/man/man1/macbethcal.1
Revision: 1.4
Committed: Tue Sep 4 17:36:40 2007 UTC (18 years, 3 months ago) by greg
Changes since 1.3: +7 -7 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: macbethcal.1,v 1.3 2004/01/01 19:31:45 greg Exp $"
2 greg 1.1 .TH MACBETHCAL 1 1/16/97 RADIANCE
3     .SH NAME
4     macbethcal - compute color compensation based on measured Macbeth chart
5     .SH SYNOPSIS
6     .B macbethcal
7     [
8     .B "\-d debug.pic"
9     ][
10     .B "\-p xul yul xur yur xll yll xlr ylr"
11     ]
12     .B scannedin.pic
13     [
14     .B calibout.cal
15     ]
16     .br
17     .B macbethcal
18     .B \-c
19     [
20     .B "\-d debug.pic"
21     ]
22     [
23     .B measured.xyY
24     [
25     .B calibout.cal
26     ]
27     ]
28     .SH DESCRIPTION
29     .I Macbethcal
30     takes a scanned image or measurement set
31     of a Macbeth ColorChecker\u\s-3TM\s+3\d color
32     rendition chart and computes a color mapping
33     function suitable as input to
34     .I pcomb(1).
35     .PP
36     In the first form,
37     .I macbethcal
38     takes a scanned image of a Macbeth chart that has been converted
39     into a Radiance picture using a fixed procedure.
40     When used properly as input to
41     .I pcomb,
42     the computed calibration file will adjust the
43     brightness and color of any similarly scanned and converted image
44     so as to best match the original.
45     If the lighting conditions are carefully controlled (as in the case
46     of a flatbed scanner), it is even possible to get reliable
47     reflectance values this way, at least within 10% or so.
48     The input picture is named on the command line.
49     The output calibration file will be written to the standard output
50     if no file name is given on the command line.
51     .PP
52     In the second form, the input is from a file containing measured
53     values for each Macbeth color.
54     This file must contain entries of the form:
55     .sp
56     .nf
57     N x y Y
58     .fi
59     .sp
60     Where
61     .I N
62     is the number of the corresponding Macbeth color.
63     (See back of ColorChecker chart
64     for color names and indexing, but it basically starts from the upper
65     left with 1 and proceeds in English text order to the lower right,
66     which is 24.)
67     The values
68     .I x,
69     .I y
70     and
71     .I Y
72     are the 1931 CIE (x,y) chromaticity coordinates followed by the
73     luminance for that color, which can be in any units.
74     If a white value is known (i.e. maximum output level), then it may
75     be given as entry number 0.
76     The entries may be in any order, and comments may be included
77     delimited by a pound sign ('#') and continuing to the end of line.
78     It is recommended that measurements be done for all 24 colors,
79     but the only required entries are the 6 neutral values on the bottom
80     row of the chart.
81     .PP
82     Computing a mapping from measured colors is usually more convenient
83     when calibrating a particular output device.
84     This is accomplished by printing the picture
85     .I macbeth_spec.pic
86     (which may be found in the standard RADIANCE library directory in
87     the lib subdirectory) and measuring the output with a chroma meter
88     or spectrophotometer.
89     .PP
90     For a scanned image, the locations of the 24 Macbeth patches
91     in the input picture must be known.
92     If the chart borders are not at the edges of the input picture, or
93     the chart has been reversed or rotated or is uncentered or at an
94     oblique angle, then it is necessary to specify the pixel locations
95     of the corners of the chart with the
96     .I \-p
97     option.
98     The corner postions (x,y pixel addresses as given by the
99     .I ximage(1)
100     "p" command)
101     are ordered on the command line:
102     upper-left, upper-right, lower-left, lower-right
103     (i.e. English text ordering).
104     These coordinates should be the outside corner positions of
105     the following patches:
106     .sp
107     .nf
108     upper-left = 1. dark skin
109     upper-right = 6. bluish green
110     lower-left = 19. white
111     lower-right = 24. black
112     .fi
113     .sp
114     If the chart has been flipped or rotated, simply give the pixel
115     positions of the appropriate patch corners, wherever
116     they are in the image.
117     (Note: if the Radiance picture has been flipped or rotated with
118     .I pflip(1)
119     or
120     .I protate(1),
121     .I ximage
122     will report the original pixel positions if the
123     .I \-c
124     option was not used by the reorienting program(s).
125     This will be wrong, so be sure to use the
126     .I \-c
127     option.)
128     .I Macbethcal
129     can handle a chart with any orientation or perspective warping if
130     the corner coordinates are given correctly.
131     The debug picture output is the best way to check for consistency.
132     (See the
133     .I \-d
134     option, below.)
135     .PP
136     The
137     .I \-d
138     option may be used to specify an additional output file, which will
139     be a picture comparing the scanned image processed according to the
140     computed mapping against the standard Macbeth colors.
141     It is a good idea to use the debug option to check that the color
142     patches are being located correctly, and to see how well
143     .I macbethcal
144     does at matching colors.
145     The center of each patch will show the target color;
146     the left side of each patch will show the original
147     color, and the right side will show the corrected value.
148     If the match works well, the debug picture should have a sort of
149     "notch on the left" look in each patch.
150     Macbeth colors that could not be matched because they were out of
151     gamut on this device are indicated with diagonal lines drawn
152     through the associated target colors.
153     .SH METHOD
154     .I Macbethcal
155     computes the color mapping in two stages.
156     The first stage uses the six neutral color patches at the bottom of
157     the Macbeth chart to compute a piecewise linear approximation to the
158     brightness mapping of each RGB primary.
159     The second stage looks at all the colors that are within the
160     device's gamut to compute a
161     least-sqaures fit for a linear color transformation from the
162     measured space into the standard Radiance RGB space (as defined by
163     the three primaries in src/common/color.h).
164     .PP
165     Thanks to the nature of inverse mappings, this method should work
166     either for converting scanned data to match the original, or for
167     preconditioning pictures to be sent to specific output devices.
168     In other words, the same calibration file works either for
169     correcting scanned images OR precorrecting images before printing.
170     .PP
171     A warning is printed if some unsaturated colors are determined to
172     be out of gamut, as this may indicate a poor rendition or improper
173     picture alignment.
174     The debug picture will show which colors were excluded by drawing
175     diagonal lines through their entries.
176     .SH NOTE
177     It is very important that the same settings be applied when
178     scanning or printing other images to be calibrated with the computed file.
179     In particular, all exposure adjustments should be fixed manually,
180     and no tweaking of the settings should be done along the way.
181     The final result will be best if the original scanned image is not
182     too far off from what it should be.
183     In the case of slide and negative scanners, it is best to apply the
184     recommended calibration file for the type of film used, so long as
185     this calibration is fixed and not adjusted on a per-image basis.
186     .SH CHART AVAILABILITY
187     The Macbeth chart is available at most photographic supply stores,
188     or may be ordered directly from Macbeth:
189     .sp
190     .nf
191     Macbeth
192     Munsell Color
193     405 Little Britain Rd.
194     New Windsor, NY 12553-6148
195     tel. 1-800-622-2384 (USA)
196     fax. 1-914-561-0267
197     .fi
198     .sp
199     The chart sells for under $50 US at the time of this writing.
200     .SH EXAMPLES
201     To compute a calibration for a FunkyThing scanner and check the
202     results:
203     .IP "" .2i
204 greg 1.4 ra_tiff \-r mbscan.tif mbscan.pic
205 greg 1.1 .br
206 greg 1.4 macbethcal \-d debug.pic mbscan.pic FunkyThing.cal
207 greg 1.1 .br
208     ximage debug.pic
209     .PP
210     To apply this computed calibration to another scanned image:
211     .IP "" .2i
212 greg 1.4 ra_tiff \-r another.tif | pcomb \-f FunkyThing.cal \- > another_calib.pic
213 greg 1.1 .PP
214     To compute a calibration file for the BigWhiz film recorder, after
215     taking measurements of a slide made from macbeth_spec.pic:
216     .IP "" .2i
217 greg 1.4 macbethcal \-c macbeth_spec.xyY BigWhiz.cal
218 greg 1.1 .PP
219     To prepare a picture prior to output on the same film recorder:
220     .IP "" .2i
221 greg 1.4 pcomb \-f BigWhiz.cal standard.pic > toprint.pic
222 greg 1.1 .PP
223     To use
224     .I pcond(1)
225     to also adjust the image for human response:
226     .IP "" .2i
227 greg 1.4 pcond \-f BigWhiz.cal \-h standard.pic > toprint.pic
228 greg 1.1 .SH AUTHOR
229     Greg Ward
230     .br
231     Paul Heckbert supplied code for perspective projective mapping
232     .SH "SEE ALSO"
233 greg 1.3 icalc(1), pcomb(1), pcond(1), pfilt(1), ximage(1)
