root/radiance/ray/doc/man/man1/ltview.1
Revision: 1.2
Committed: Wed Apr 16 20:32:00 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 1.1: +29 -29 lines
Axel updates to ltview and ltpict
1 .\"
2 .TH "LTVIEW" "1" "08/04/14" "RADIANCE" ""
3 .SH "NAME"
4 ltview \- view photometry of a light source
5 .SH "SYNOPSIS"
6 .B ltview
7 [
8 .B \-i
9 ][
10 .B "\-b boxsize"
11 ][
12 .B "\-o device"
13 ]
14 input
15 .SH "DESCRIPTION"
16 .I ltview
17 renders a Radiance luminiare or IES photometry interactively using
18 .I rad(1).
19 .PP
20 .I ltview
21 accepts exactly one Radiance object or IES photometry
22 file as input. No input is taken from STDIN. The
23 .I \-i
24 option tells it that the input file contains
25 IES photometry rather then a Radiance description of a
26 luminiare. In this case, Radiance's
27 .I ies2rad(1)
28 is called with its default settings to convert the IES file into a
29 Radiance object.
30 .PP
31 Unlike
32 .I objpict(1)
33 or
34 .I objview(1),
35 no additional light sources are added to the scene, since it is
36 assumed that the object is a luminaire.
37 .PP
38 .I ltview
39 relies on Radiance's
40 .I rad(1)
41 command to compile an octree using
42 .I oconv(1)
43 and to call
44 .I rvu(1)
45 to display an interactive preview of the luminaire.
46 The luminaire, or output from
47 .I ies2rad(1),
48 is moved so that its center is at world origin.
49 .I ltview
50 then generates an open box around the fitting that is ten times
51 as big as the largest axis\-aligned dimension of the fitting.
52 The \-y face of the box is left open so that
53 the camera can look inside, facing +y.
54 The overall dimensions of the enclosing box may be overwritten with the
55 .I "\-b boxsize"
56 option. Note that both the fitting and the box are always centred at the
57 origin.
58 .PP
59 When
60 .I ltview
61 is run with the
62 .I \-i
63 option, i.e. the file is an IES photometry file,
64 then the dimensions of the luminaire and intesity of its
65 output are determined by
66 .I ies2rad(1)'s
67 default settings. If this is not acceptable, then it is best to run
68 .I ies2rad(1)
69 manually, and to feed
70 .I ltview
71 the hand\-crafted fitting, rather than the IES photometry. In any case,
72 it is likely that the initial exposure within the
73 .I rvu(1)
74 window window needs to be adjusted before the distribution of the fitting
75 can be fully appreciated.
76 .PP
77 The default
78 .I rvu(1)
79 output device is
80 .I x11
81 on all platforms except for Windows, where it is set to
82 .I qt.
83 This may be overwritten with the
84 .I "\-o output"
85 option.
86
87 .SH "EXAMPLES"
88 To query available output devices
89 .IP "" .2i
90 rvu \-devices
91 .PP
92 To visualise an IES file with the qt driver
93 .IP "" .2i
94 ltview \-o qt ABC123.ies
95 .PP
96 To look at a typical fluorescent fitting that is modelled in millimeters
97 .IP "" .2i
98 ltview \-b 5000 XYZ_batten.rad
99 .SH "AUTHOR"
100 Axel Jacobs
101 .SH "SEE ALSO"
102 ltpict(1), ies2rad(1), oconv(1), rad(1), rvu(1)
