root/radiance/ray/doc/man/man1/ltpict.1
Revision: 1.2
Committed: Wed Apr 16 20:32:00 2014 UTC (10 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 1.1: +0 -1 lines
Axel updates to ltview and ltpict
1 .TH "LTPICT" "1" "08/04/14" "RADIANCE" ""
2 .SH "NAME"
3 ltpict \- render a four\-view image of a light source
4 .SH "SYNOPSIS"
5 .B ltpict
6 [
7 .B \-i
8 ][
9 .B "\-d dimensions"
10 ]
11 input
12 .SH "DESCRIPTION"
13 .I ltpict
14 is a script that renders a four\-view HDR image of a Radiance luminaire
15 or IES photometric file. The
16 .I \-i
17 option tells it that the file name given is
18 an IES photometry file rather then a Radiance description of a
19 luminiare. In this case, Radiance's
20 .I ies2rad(1)
21 is called with its default settings to convert the IES file to a
22 Radiance object.
23 .PP
24 The four projections presented are the lower hemisphere
25 (displayed in the upper left quadrant), the upper hemisphere
26 (upper right), the C0\-C180 plane (lower left) and the
27 C90\-C270 plane (lower right).
28 .PP
29 Only one Radiance luminaire description or IES photometry file
30 may be given. No input is accepted on STDIN.
31 .PP
32 The output image in HDR format is produced on STDOUT with
33 the default dimensions of 1024 by 1024 pixels. The dimensions
34 may be overwritten with the
35 .I "\-d dimensions
36 option which takes an integer that is divisible by two.
37 .SH "EXAMPLES"
38 To render a four\-view image of photometry file ABC123.ies
39 and save the result to luminaire.hdr
40 .IP "" .2i
41 ltpict \-i ABC123.ies > luminaire.hdr
42 .PP
43 To render a small four\-view HDR image of the
44 RADIANCE luminaire XYZ456.rad to STDOUT, and display it with ximage
45 .IP "" .2i
46 ltpict \-d 400 XYZ456.rad | ximage
47 .SH "AUTHOR"
48 Axel Jacobs
49 .SH "SEE ALSO"
50 objline(1), objview(1), objpict(1), ies2rad(1), ltview(1)
