root/radiance/ray/doc/man/man1/ltpict.1
Revision: 1.1
Committed: Tue Apr 15 22:36:25 2014 UTC (11 years ago) by greg
1 .\" RCSid $Id$
2 .TH "LTPICT" "1" "08/04/14" "RADIANCE" ""
3 .SH "NAME"
4 ltpict \- render a four\-view image of a light source
5 .SH "SYNOPSIS"
6 .B ltpict
7 [
8 .B \-i
9 ][
10 .B "\-d dimensions"
11 ]
12 input
13 .SH "DESCRIPTION"
14 .I ltpict
15 is a script that renders a four\-view HDR image of a Radiance luminaire
16 or IES photometric file. The
17 .I \-i
18 option tells it that the file name given is
19 an IES photometry file rather then a Radiance description of a
20 luminiare. In this case, Radiance's
21 .I ies2rad(1)
22 is called with its default settings to convert the IES file to a
23 Radiance object.
24 .PP
25 The four projections presented are the lower hemisphere
26 (displayed in the upper left quadrant), the upper hemisphere
27 (upper right), the C0\-C180 plane (lower left) and the
28 C90\-C270 plane (lower right).
29 .PP
30 Only one Radiance luminaire description or IES photometry file
31 may be given. No input is accepted on STDIN.
32 .PP
33 The output image in HDR format is produced on STDOUT with
34 the default dimensions of 1024 by 1024 pixels. The dimensions
35 may be overwritten with the
36 .I "\-d dimensions
37 option which takes an integer that is divisible by two.
38 .SH "EXAMPLES"
39 To render a four\-view image of photometry file ABC123.ies
40 and save the result to luminaire.hdr
41 .IP "" .2i
42 ltpict \-i ABC123.ies > luminaire.hdr
43 .PP
44 To render a small four\-view HDR image of the
45 RADIANCE luminaire XYZ456.rad to STDOUT, and display it with ximage
46 .IP "" .2i
47 ltpict \-d 400 XYZ456.rad | ximage
48 .SH "AUTHOR"
49 Axel Jacobs
50 .SH "SEE ALSO"
51 objline(1), objview(1), objpict(1), ies2rad(1), ltview(1)
