root/radiance/ray/doc/man/man1/lam.1
Revision: 1.3
Committed: Thu Jan 1 19:31:45 2004 UTC (21 years, 4 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: lam.1,v 1.2 2003/12/09 15:59:06 greg Exp $"
2 greg 1.1 .TH LAM 1 7/8/97 RADIANCE
3     .SH NAME
4     lam - laminate lines of multiple files
5     .SH SYNOPSIS
6     .B lam
7     [
8     .B \-tC
9     ]
10     input1 input2 ..
11     .SH DESCRIPTION
12     .I Lam
13     simply joins lines from multiple inputs, separating them with
14     the given tab character (TAB by default).
15     An input is either a stream or a command.
16     Commands are given in quotes, and begin with an exclamantion point ('!').
17     If the inputs do not have the same number of lines, then
18     shorter files will stop contributing to the output as they
19     run out.
20     .PP
21     A hyphen ('-') by itself can be used to indicate the standard
22     input.
23     .SH EXAMPLE
24     To join files output1 and output2, separated by a comma:
25     .IP "" .2i
26     lam -t, output1 output2
27     .PP
28     To join a file with line numbers (starting at 0) and its reverse:
29     .IP "" .2i
30     cnt `wc -l < lam.c` | lam - -t: lam.c -t\| '\!tail -r lam.c'
31     .SH AUTHOR
32     Greg Ward
33     .SH "SEE ALSO"
34     cnt(1), neat(1), rcalc(1), tabfunc(1), total(1)
