root/radiance/ray/doc/man/man1/ies2rad.1
Revision: 1.5
Committed: Mon Nov 29 16:07:36 2021 UTC (3 years, 6 months ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 1.4: +206 -200 lines
feat(ies2rad): changes and enhancements to ies2rad by Randolph Fritz
1 .\" RCSid "$Id$"
2 .TH IES2RAD "1" "2021-10-26" "Radiance" "Radiance Manual Pages"
3 .SH "NAME"
4 ies2rad \- convert IES luminaire data to RADIANCE description
5 .SH "SYNOPSIS"
6 \fBies2rad\fP [ \fIoptions\fP ] [ \fIfile file .\|.\|.\&\fP ]
7 .SH "DESCRIPTION"
8 \fIIes2rad\fP converts one or more IES luminaire data files to
9 an equivalent RADIANCE scene description. The light source geometry
10 will always be centered at the origin aimed in the negative Z
11 direction, with the 0 degree plane along the x-axis\(emthe IES
12 photometric horizontal or length. The IES width is oriented along
13 the y axis, and the IES up becomes the RADIANCE z-axis.
14 .PP
15 The IES(NA) LM-63 standard provides a limited range of light
16 source shapes (\(lqluminous openings\(rq), different in each
17 version of the standard. Of these shapes, \fIies2rad\fP supports
18 rectangles, boxes, points (as 1mm spheres), disks (as 1mm high
19 vertical cylinders), vertical cylinders, and spheres. Some versions
20 of the standard also define ellipses, ellipsoids, and horizontal
21 cylinders. \fIIes2rad\fP will approximate near-circular ellipses
22 as disks, near-spherical ellipsoids as spheres, and horizontal
23 cylinders as boxes.
24 .PP
25 The 1995 IES standard once included the materials and geometry
26 format (MGF) which can describe detailed luminaire and light
27 source geometry, but it was never used. \fIIes2rad\fP still supports
28 MGF.
29 .PP
30 \fIIes2rad\fP assigns light source colors based on information
31 in a lamp lookup table. Since most lamps are distinctly colored,
32 it is often desirable to override this lookup procedure and use
33 a neutral value that will produced color-balanced renderings.
34 In general, it is important to consider lamp color when an odd
35 assortment of fixture types is being used to illuminate the same
36 scene, and the rendering can always be balanced by \fBpfilt\fP(1)
37 to a specific white value later.
38 .SH "OPTIONS"
39 .TP
40 .BI "\-l" " libdir"
41 Set the library directory path to \fIlibdir\fP. This is where
42 all relative pathnames will begin for output file names. For
43 light sources that will be used by many people, this should be
44 set to some central location included in the RAYPATH environment
45 variable. The default is the current working directory.
46 .TP
47 .BI "\-p" " prefdir"
48 Set the library subdirectory path to \fIprefdir\fP. This is the
49 subdirectory from the library where all output files will be
50 placed. It is often most convenient to use a subdirectory for
51 the storage of light sources, since there tend to be many files
52 and placing them all in one directory is very messy. The default
53 value is the empty string.
54 .TP
55 .BI "\-o" " outname"
56 Set the output file name root to \fIoutname\fP. This overrides
57 the default output file name root which is the same as the input
58 file. This option may be used for only one input file, and is
59 required when reading data from the standard input.
60 .TP
61 .B "\-s"
62 Send the scene information to the standard output rather than
63 a separate file. This is appropriate when calling \fIies2rad\fP
64 from within a scene description via an inline command. The data
65 file(s) will still be written based on the output file name root,
66 but, since this information is unaffected by command line options,
67 it is safe to have multiple invocations of \fIies2rad\fP using
68 the same input file and different output options. The \fI\-s\fP
69 option may be used for only one input file.
70 .TP
71 .BI "\-d" " units"
72 Output dimensions are in \fIunits\fP, which is one of the letters
73 'm', 'c', 'f', or 'i' for meters, centimeters, feet or inches,
74 respectively. The letter specification may be followed by a slash
75 ('/') and an optional divisor. For example, \fI\-dm/1000\fP would
76 be millimeters. The default output is in meters, regardless of
77 the original units in the IES input file. Note that there is
78 no space in this option.
79 .TP
80 .BI "\-i" " rad"
81 Ignore the crude geometry given by the IES input file and use
82 instead an illum sphere with radius \fIrad\fP. This option may
83 be useful when the user wishes to add a more accurate geometric
84 description to the light source model, though this need is obviated
85 by the recent LM-63-1995 specification, which uses MGF detail
86 geometry. (See \fI\-g\fP option below.)
87 .TP
88 .B "\-g"
89 If the IES file contains MGF detail geometry, compile this geometry
90 into a separate octree and create a single instance referencing
91 it instead of including the converted geometry directly in the
92 Radiance output file. This can result in a considerable memory
93 savings for luminaires which are later duplicated many times
94 in a scene, though the appearance may suffer for certain luminaires
95 since the enclosed glow sources will not light the local geometry
96 as they would otherwise.
97 .TP
98 .BI "\-f" " lampdat"
99 Use \fIlampdat\fP instead of the default lamp lookup table (lamp.tab)
100 to map lamp names to xy chromaticity and lumen depreciation data.
101 It is often helpful to have customized lookup tables for specific
102 manufacturers and applications.
103 .TP
104 .BI "\-t" " lamp"
105 Use the given lamp type for all input files. Normally, \fIies2rad\fP
106 looks at the header lines of the IES file to try and determine
107 what lamp is being used in the fixture. If any of the lines is
108 matched by a pattern in the lamp lookup table (see the \fB\-f\fP
109 option above), that color and depreciation factor will be used
110 instead of the default (see the \fB\-c\fP and \fB\-u\fP options).
111 The \fIlamp\fP specification is also looked up in the lamp table
112 unless it is set to \(lqdefault\(rq, in which case the default
113 color is used instead.
114 .TP
115 .BI "\-c" " red grn blu"
116 Use the given color if the type of the lamp is unknown or the
117 \fB\-t\fP option is set to \(lqdefault\(rq. If unspecified, the
118 default color will be white.
119 .TP
120 .BI "\-u" " lamp"
121 Set the default lamp color according to the entry for \fIlamp\fP
122 in the lookup table (see the \fB\-f\fP option). This is the color
123 that will be used if the input specification does not match any
124 lamp type patterns. This option is used instead of the \fB\-c\fP
125 option.
126 .TP
127 .BI "\-m" " factor"
128 Multiply all output quantities by \fIfactor\fP. This is the best
129 way to scale fixture brightness for different lamps, but care
130 should be taken when this option is applied to multiple files.
131 .SH "EXIT STATUS"
132 0 if successful, 1 if not.
133 .SH "ENVIRONMENT"
134 .TP
135 RAYPATH
136 Colon-separated list of directories to search for lamp lookup
137 table
138 .SH "FILES"
139 The output files will be created in the current directory (no
140 matter which directory the input files came from) unless the
141 \fI\-l\fP or \fI\-p\fP options are used.
142 .TP
143 .RI "<" "luminaire" ">.ies"
144 The IES LM-63 input file. May also be from the standard input.
145 If the standard input is the source, the \fB-o\fP option must
146 be specified, to provide a filename.
147 .TP
148 .RI "<" "luminaire" ">.rad"
149 The RADIANCE scene description. May also be sent to the standard
150 output.
151 .TP
152 .RI "<" "luminaire" ">.dat"
153 The IES candela values.
154 .TP
155 .RI "<" "luminaire" ">+.dat"
156 The IES tilt data. If tilt data is not provided (it is mostly
157 needed for luminaires which use metal halide lamps), this file
158 is not generated.
159 .TP
160 .RI "<" "luminaire" ">.oct"
161 If the \fB-g\fP option is given, the compiled MGF geometry is
162 placed in this octree file.
163 .TP
164 .RI "<" "RAYPATH" ">/lamp.tab"
165 lamp table
166 .SH "EXAMPLES"
167 To convert a single IES data file in inches with color balanced
168 output and 15% lumen depreciation, creating the files \(lqfluor01.rad\(rq
169 and \(lqfluor01.dat\(rq in the current directory:
170 .RS 2n
171 .sp 0.25
172 ies2rad -di -t default -m .85 fluor01.ies
173 .sp 0.25
174 .RE
175 .PP
176 To convert three IES files of various types to tenths of a foot
177 and put them in the library \(lq/usr/local/lib/ray\(rq subdirectory
178 \(lqsource/ies\(rq:
179 .RS 2n
180 .sp 0.25
181 ies2rad -df/10 -l /usr/local/lib/ray -p source/ies ies01 ies02 ies03
182 .sp 0.25
183 .RE
184 .PP
185 To convert a single file and give the output a different name:
186 .RS 2n
187 .sp 0.25
188 ies2rad -o fluorescent ies03
189 .sp 0.25
190 .RE
191 .SH "REFERENCES"
192 .TP
193 LM-63-86, LM-63-91, LM-63-95, LM-63-02, LM-63-19
194 \fIIES Standard File Format for the Electronic Transfer of Photometric
195 Data and Related Information\fP. IESNA - Lighting Measurement
196 and Testing. Illuminating Engineering Society, 1986, 1991, 1995,
197 2002, 2019.
198 .TP
199 LM-75-01
200 \fIGoniophotometer Types and Photometric Coordinates\fP. New
201 York: Illuminating Engineering Society of North America, 2001.
202 .TP
203 The Materials and Geometry Format
204 Greg Ward. \fIThe Materials and Geometry Format\fP <https://floyd.lbl.gov/mgf/mgfdoc.pdf>.
205 Lawrence Berkeley Laboratory, 1996.
206 .SH "AUTHOR"
207 Greg Ward
208 .SH "BUGS"
209 In pre-1991 standard IES files, all header lines will be examined
210 for a lamp table string match. In post-1991 standard files, only
211 those lamps with the [LAMP] or [LAMPCAT] keywords will be searched.
212 The first match found in the file is always the one used. This
213 method of assigning colors to fixtures is less than perfect,
214 and the IES would do well to include explicit spectral information
215 somehow in their specification.
216 .PP
217 Not all luminous openings defined in the IES standard are supported.
218 So far, however, we have yet to find IES files which use the
219 unsupported shapes.
220 .SH "SEE ALSO"
221 \fBlamp.tab\fP(5), \fBmgf2rad\fP(1), \fBoconv\fP(1), \fBpfilt\fP(1),
222 \fBrad2mgf\fP(1), \fBrpict\fP(1), \fBxform\fP(1)
