1 |
.\" RCSid "$Id$" |
2 |
.TH IES2RAD 1 6/14/96 RADIANCE |
3 |
.SH NAME |
4 |
ies2rad - convert IES luminaire data to RADIANCE description |
5 |
.SH SYNOPSIS |
6 |
.B ies2rad |
7 |
8 |
.B options |
9 |
10 |
11 |
.B input .. |
12 |
13 |
.SH DESCRIPTION |
14 |
.I Ies2rad |
15 |
converts one or more IES luminaire data files to the equivalent RADIANCE |
16 |
scene description. |
17 |
The light source geometry will always be centered at the origin aimed |
18 |
in the negative z direction, with the 0 degree plane along the x axis. |
19 |
Usually, two output files will be created for every input file, one |
20 |
scene file (with a ".rad" suffix) and one data file (with a ".dat" |
21 |
suffix). |
22 |
If the IES input file includes tilt data, then another data file |
23 |
will be created (with a "+.dat" suffix). |
24 |
If the |
25 |
.I \-s |
26 |
option is used, the scene data will be sent to the standard output |
27 |
instead of being written to a file. |
28 |
Since the data file does not change with other options to |
29 |
.I ies2rad, |
30 |
this is a convenient way to specify different lamp colors and |
31 |
multipliers inline in a scene description. |
32 |
If the |
33 |
.I \-g |
34 |
option is used, then an octree file will be created (with the ".oct" |
35 |
suffix). |
36 |
The root portion of the output file names will be the same as the |
37 |
corresponding input file, unless the |
38 |
.I \-o |
39 |
option is used. |
40 |
The output files will be created in the current directory (no matter |
41 |
which directory the input files came from) unless the |
42 |
.I \-l |
43 |
or |
44 |
.I \-p |
45 |
options are used. |
46 |
.PP |
47 |
.I Ies2rad |
48 |
assigns light source colors based on information in a lamp lookup table. |
49 |
Since most lamps are distinctly colored, |
50 |
it is often desirable to override this lookup procedure and use |
51 |
a neutral value that will produced color-balanced renderings. |
52 |
In general, it is important to consider lamp color when an odd assortment |
53 |
of fixture types is being used to illuminate the same scene, and |
54 |
the rendering can always be balanced by pfilt(1) to a specific white value |
55 |
later. |
56 |
.TP 10n |
57 |
.BI -l \ libdir |
58 |
Set the library directory path to |
59 |
.I libdir. |
60 |
This is where all relative pathnames will begin for output file names. |
61 |
For light sources that will be used by many people, this should be |
62 |
set to some central location included in the RAYPATH environment variable. |
63 |
The default is the current working directory. |
64 |
.TP |
65 |
.BI -p \ prefdir |
66 |
Set the library subdirectory path to |
67 |
.I prefdir. |
68 |
This is the subdirectory from the library where all output files will |
69 |
be placed. |
70 |
It is often most convenient to use a subdirectory for the storage of |
71 |
light sources, since there tend to be many files and placing them all |
72 |
in one directory is very messy. |
73 |
The default value is the empty string. |
74 |
.TP |
75 |
.BI -o \ outname |
76 |
Set the output file name root to |
77 |
.I outname. |
78 |
This overrides the default output file name root which is the same as the |
79 |
input file. |
80 |
This option may be used for only one input file, and is required when |
81 |
reading data from the standard input. |
82 |
.TP |
83 |
.BR -s |
84 |
Send the scene information to the standard output rather than a |
85 |
separate file. |
86 |
This is appropriate when calling |
87 |
.I ies2rad |
88 |
from within a scene description via an inline command. |
89 |
The data file(s) will still be written based on the output file name |
90 |
root, but since this information is unaffected by command line options, |
91 |
it is safe to have multiple invocations of |
92 |
.I ies2rad |
93 |
using the same input file and different output options. |
94 |
The |
95 |
.I \-s |
96 |
option may be used for only one input file. |
97 |
.TP |
98 |
.BI -d units |
99 |
Output dimensions are in |
100 |
.I units, |
101 |
which is one of the letters 'm', 'c', 'f', or 'i' for meters, |
102 |
centimeters, feet or inches, respectively. |
103 |
The letter specification may be followed by a slash ('/') and an |
104 |
optional divisor. |
105 |
For example, |
106 |
.I \-dm/1000 |
107 |
would be millimeters. |
108 |
The default output is in meters, regardless of the original units in |
109 |
the IES input file. |
110 |
Note that there is no space in this option. |
111 |
.TP |
112 |
.BI -i \ rad |
113 |
Ignore the crude geometry given by the IES input file and use instead an illum |
114 |
sphere with radius |
115 |
.I rad. |
116 |
This option may be useful when the user wishes to add a more accurate |
117 |
geometric description to the light source model, though this need |
118 |
is obviated by the recent LM-63-1995 specification, which uses MGF |
119 |
detail geometry. |
120 |
(See |
121 |
.I \-g |
122 |
option below.)\0 |
123 |
.TP |
124 |
.BR -g |
125 |
If the IES file contains MGF detail geometry, compile this geometry into |
126 |
a separate octree and create a single instance referencing it |
127 |
instead of including the converted geometry directly in the Radiance |
128 |
output file. |
129 |
This can result in a considerable memory savings for luminaires |
130 |
which are later duplicated many times in a scene, though the |
131 |
appearance may suffer for certain luminaires since the enclosed glow |
132 |
sources will not light the local geometry as they would otherwise. |
133 |
.TP |
134 |
.BI -f \ lampdat |
135 |
Use |
136 |
.I lampdat |
137 |
instead of the default lamp lookup table (lamp.tab) to map lamp |
138 |
names to xy chromaticity and lumen depreciation data. |
139 |
It is often helpful to have customized lookup tables for specific |
140 |
manufacturers and applications. |
141 |
.TP |
142 |
.BI -t \ lamp |
143 |
Use the given lamp type for all input files. |
144 |
Normally, |
145 |
.I ies2rad |
146 |
looks at the header lines of the IES file to try and determine |
147 |
what lamp is being used in the fixture. |
148 |
If any of the lines is matched by a pattern in the lamp lookup |
149 |
table (see the -f option above), that color and depreciation factor will |
150 |
be used instead of the default (see the -c and -u options). |
151 |
The |
152 |
.I lamp |
153 |
specification is also looked up in the lamp table unless it is |
154 |
set to "default", in which case the default color is used instead. |
155 |
.TP |
156 |
.BI -c " red grn blu" |
157 |
Use the given color if the type of the lamp is unknown or |
158 |
the -t option is set to "default". |
159 |
If unspecified, the default color will be white. |
160 |
.TP |
161 |
.BI -u \ lamp |
162 |
Set the default lamp color according to the entry for |
163 |
.I lamp |
164 |
in the lookup table (see the -f option). |
165 |
This is the color that will be used if the input specification |
166 |
does not match any lamp type patterns. |
167 |
This option is used instead of the -c option. |
168 |
.TP |
169 |
.BI -m \ factor |
170 |
Multiply all output quantities by |
171 |
.I factor. |
172 |
This is the best way to scale fixture brightness for different lamps, but care |
173 |
should be taken when this option is applied to multiple files. |
174 |
.SH EXAMPLE |
175 |
To convert a single IES data file in inches with color balanced output |
176 |
and 15% lumen depreciation, |
177 |
creating the files "fluor01.rad" and "fluor01.dat" in the current directory: |
178 |
.IP "" .2i |
179 |
ies2rad -di -t default -m .85 fluor01.ies |
180 |
.PP |
181 |
To convert three IES files of various types to tenths of a foot and put |
182 |
them in the library "/usr/local/lib/ray" subdirectory "source/ies": |
183 |
.IP "" .2i |
184 |
ies2rad -df/10 -l /usr/local/lib/ray -p source/ies ies01 ies02 ies03 |
185 |
.PP |
186 |
To convert a single file and give the output a different name: |
187 |
.IP "" .2i |
188 |
ies2rad -o fluorescent ies03 |
189 |
.SH ENVIRONMENT |
190 |
RAYPATH directories to search for lamp lookup table |
191 |
.SH AUTHOR |
192 |
Greg Ward |
193 |
.SH BUGS |
194 |
In pre-1991 standard IES files, all header lines will be examined |
195 |
for a lamp table string match. |
196 |
In post-1991 standard files, only those lamps with the [LAMP] or |
197 |
[LAMPCAT] keywords will be searched. |
198 |
The first match found in the file is always the one used. |
199 |
This method of assigning colors to fixtures is less than perfect, |
200 |
and the IES would do well to include explicit spectral information |
201 |
somehow in their specification. |
202 |
.PP |
203 |
The IESNA LM-63 specification prior to 1995 provided three basic source |
204 |
shapes, rectangular, round, and elliptical. |
205 |
The details of these shapes is vague at best. |
206 |
Rectangular sources will always be rectangular, but ies2rad will |
207 |
approximate round sources as spherical if the height is close to |
208 |
or greater than the width and length, and as a ring otherwise. |
209 |
Elliptical sources are treated the same as round sources. |
210 |
The 1995 standard rectifies this problem by including detailed |
211 |
luminaire geometry as MGF data, though nothing in the standard |
212 |
requires manufacturers to provide this information. |
213 |
.SH "SEE ALSO" |
214 |
mgf2rad(1), oconv(1), pfilt(1), rad2mgf(1), rpict(1), xform(1) |
