root/radiance/ray/doc/man/man1/ies2rad.1
Revision: 1.4
Committed: Thu Jan 24 23:15:46 2008 UTC (17 years, 6 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad4R2P2
Changes since 1.3: +4 -2 lines
1 .\" RCSid "$Id: ies2rad.1,v 1.3 2007/09/04 17:36:40 greg Exp $"
2 .TH IES2RAD 1 6/14/96 RADIANCE
3 .SH NAME
4 ies2rad - convert IES luminaire data to RADIANCE description
5 .SH SYNOPSIS
6 .B ies2rad
7 [
8 .B options
9 ]
10 [
11 .B input ..
12 ]
13 .SH DESCRIPTION
14 .I Ies2rad
15 converts one or more IES luminaire data files to the equivalent RADIANCE
16 scene description.
17 The light source geometry will always be centered at the origin aimed
18 in the negative Z direction, with the 0 degree plane along the X axis.
19 (Note, this means that the IES "width" is actually along the Y axis,
20 while "length" corresponds to the X axis.)\0
21 Usually, two output files will be created for every input file, one
22 scene file (with a ".rad" suffix) and one data file (with a ".dat"
23 suffix).
24 If the IES input file includes tilt data, then another data file
25 will be created (with a "+.dat" suffix).
26 If the
27 .I \-s
28 option is used, the scene data will be sent to the standard output
29 instead of being written to a file.
30 Since the data file does not change with other options to
31 .I ies2rad,
32 this is a convenient way to specify different lamp colors and
33 multipliers inline in a scene description.
34 If the
35 .I \-g
36 option is used, then an octree file will be created (with the ".oct"
37 suffix).
38 The root portion of the output file names will be the same as the
39 corresponding input file, unless the
40 .I \-o
41 option is used.
42 The output files will be created in the current directory (no matter
43 which directory the input files came from) unless the
44 .I \-l
45 or
46 .I \-p
47 options are used.
48 .PP
49 .I Ies2rad
50 assigns light source colors based on information in a lamp lookup table.
51 Since most lamps are distinctly colored,
52 it is often desirable to override this lookup procedure and use
53 a neutral value that will produced color-balanced renderings.
54 In general, it is important to consider lamp color when an odd assortment
55 of fixture types is being used to illuminate the same scene, and
56 the rendering can always be balanced by pfilt(1) to a specific white value
57 later.
58 .TP 10n
59 .BI -l \ libdir
60 Set the library directory path to
61 .I libdir.
62 This is where all relative pathnames will begin for output file names.
63 For light sources that will be used by many people, this should be
64 set to some central location included in the RAYPATH environment variable.
65 The default is the current working directory.
66 .TP
67 .BI -p \ prefdir
68 Set the library subdirectory path to
69 .I prefdir.
70 This is the subdirectory from the library where all output files will
71 be placed.
72 It is often most convenient to use a subdirectory for the storage of
73 light sources, since there tend to be many files and placing them all
74 in one directory is very messy.
75 The default value is the empty string.
76 .TP
77 .BI -o \ outname
78 Set the output file name root to
79 .I outname.
80 This overrides the default output file name root which is the same as the
81 input file.
82 This option may be used for only one input file, and is required when
83 reading data from the standard input.
84 .TP
85 .BR -s
86 Send the scene information to the standard output rather than a
87 separate file.
88 This is appropriate when calling
89 .I ies2rad
90 from within a scene description via an inline command.
91 The data file(s) will still be written based on the output file name
92 root, but since this information is unaffected by command line options,
93 it is safe to have multiple invocations of
94 .I ies2rad
95 using the same input file and different output options.
96 The
97 .I \-s
98 option may be used for only one input file.
99 .TP
100 .BI -d units
101 Output dimensions are in
102 .I units,
103 which is one of the letters 'm', 'c', 'f', or 'i' for meters,
104 centimeters, feet or inches, respectively.
105 The letter specification may be followed by a slash ('/') and an
106 optional divisor.
107 For example,
108 .I \-dm/1000
109 would be millimeters.
110 The default output is in meters, regardless of the original units in
111 the IES input file.
112 Note that there is no space in this option.
113 .TP
114 .BI -i \ rad
115 Ignore the crude geometry given by the IES input file and use instead an illum
116 sphere with radius
117 .I rad.
118 This option may be useful when the user wishes to add a more accurate
119 geometric description to the light source model, though this need
120 is obviated by the recent LM-63-1995 specification, which uses MGF
121 detail geometry.
122 (See
123 .I \-g
124 option below.)\0
125 .TP
126 .BR -g
127 If the IES file contains MGF detail geometry, compile this geometry into
128 a separate octree and create a single instance referencing it
129 instead of including the converted geometry directly in the Radiance
130 output file.
131 This can result in a considerable memory savings for luminaires
132 which are later duplicated many times in a scene, though the
133 appearance may suffer for certain luminaires since the enclosed glow
134 sources will not light the local geometry as they would otherwise.
135 .TP
136 .BI -f \ lampdat
137 Use
138 .I lampdat
139 instead of the default lamp lookup table (lamp.tab) to map lamp
140 names to xy chromaticity and lumen depreciation data.
141 It is often helpful to have customized lookup tables for specific
142 manufacturers and applications.
143 .TP
144 .BI -t \ lamp
145 Use the given lamp type for all input files.
146 Normally,
147 .I ies2rad
148 looks at the header lines of the IES file to try and determine
149 what lamp is being used in the fixture.
150 If any of the lines is matched by a pattern in the lamp lookup
151 table (see the \-f option above), that color and depreciation factor will
152 be used instead of the default (see the \-c and \-u options).
153 The
154 .I lamp
155 specification is also looked up in the lamp table unless it is
156 set to "default", in which case the default color is used instead.
157 .TP
158 .BI \-c " red grn blu"
159 Use the given color if the type of the lamp is unknown or
160 the \-t option is set to "default".
161 If unspecified, the default color will be white.
162 .TP
163 .BI \-u \ lamp
164 Set the default lamp color according to the entry for
165 .I lamp
166 in the lookup table (see the \-f option).
167 This is the color that will be used if the input specification
168 does not match any lamp type patterns.
169 This option is used instead of the \-c option.
170 .TP
171 .BI \-m \ factor
172 Multiply all output quantities by
173 .I factor.
174 This is the best way to scale fixture brightness for different lamps, but care
175 should be taken when this option is applied to multiple files.
176 .SH EXAMPLE
177 To convert a single IES data file in inches with color balanced output
178 and 15% lumen depreciation,
179 creating the files "fluor01.rad" and "fluor01.dat" in the current directory:
180 .IP "" .2i
181 ies2rad \-di \-t default \-m .85 fluor01.ies
182 .PP
183 To convert three IES files of various types to tenths of a foot and put
184 them in the library "/usr/local/lib/ray" subdirectory "source/ies":
185 .IP "" .2i
186 ies2rad \-df/10 \-l /usr/local/lib/ray \-p source/ies ies01 ies02 ies03
187 .PP
188 To convert a single file and give the output a different name:
189 .IP "" .2i
190 ies2rad \-o fluorescent ies03
191 .SH ENVIRONMENT
192 RAYPATH directories to search for lamp lookup table
193 .SH AUTHOR
194 Greg Ward
195 .SH BUGS
196 In pre\-1991 standard IES files, all header lines will be examined
197 for a lamp table string match.
198 In post\-1991 standard files, only those lamps with the [LAMP] or
199 [LAMPCAT] keywords will be searched.
200 The first match found in the file is always the one used.
201 This method of assigning colors to fixtures is less than perfect,
202 and the IES would do well to include explicit spectral information
203 somehow in their specification.
204 .PP
205 The IESNA LM\-63 specification prior to 1995 provided three basic source
206 shapes, rectangular, round, and elliptical.
207 The details of these shapes is vague at best.
208 Rectangular sources will always be rectangular, but ies2rad will
209 approximate round sources as spherical if the height is close to
210 or greater than the width and length, and as a ring otherwise.
211 Elliptical sources are treated the same as round sources.
212 The 1995 standard rectifies this problem by including detailed
213 luminaire geometry as MGF data, though nothing in the standard
214 requires manufacturers to provide this information.
215 .SH "SEE ALSO"
216 mgf2rad(1), oconv(1), pfilt(1), rad2mgf(1), rpict(1), xform(1)
