root/radiance/ray/doc/man/man1/ies2rad.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 2 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH IES2RAD 1 6/14/96 RADIANCE
3 .SH NAME
4 ies2rad - convert IES luminaire data to RADIANCE description
5 .SH SYNOPSIS
6 .B ies2rad
7 [
8 .B options
9 ]
10 [
11 .B input ..
12 ]
13 .SH DESCRIPTION
14 .I Ies2rad
15 converts one or more IES luminaire data files to the equivalent RADIANCE
16 scene description.
17 The light source geometry will always be centered at the origin aimed
18 in the negative z direction, with the 0 degree plane along the x axis.
19 Usually, two output files will be created for every input file, one
20 scene file (with a ".rad" suffix) and one data file (with a ".dat"
21 suffix).
22 If the IES input file includes tilt data, then another data file
23 will be created (with a "+.dat" suffix).
24 If the
25 .I \-s
26 option is used, the scene data will be sent to the standard output
27 instead of being written to a file.
28 Since the data file does not change with other options to
29 .I ies2rad,
30 this is a convenient way to specify different lamp colors and
31 multipliers inline in a scene description.
32 If the
33 .I \-g
34 option is used, then an octree file will be created (with the ".oct"
35 suffix).
36 The root portion of the output file names will be the same as the
37 corresponding input file, unless the
38 .I \-o
39 option is used.
40 The output files will be created in the current directory (no matter
41 which directory the input files came from) unless the
42 .I \-l
43 or
44 .I \-p
45 options are used.
46 .PP
47 .I Ies2rad
48 assigns light source colors based on information in a lamp lookup table.
49 Since most lamps are distinctly colored,
50 it is often desirable to override this lookup procedure and use
51 a neutral value that will produced color-balanced renderings.
52 In general, it is important to consider lamp color when an odd assortment
53 of fixture types is being used to illuminate the same scene, and
54 the rendering can always be balanced by pfilt(1) to a specific white value
55 later.
56 .TP 10n
57 .BI -l \ libdir
58 Set the library directory path to
59 .I libdir.
60 This is where all relative pathnames will begin for output file names.
61 For light sources that will be used by many people, this should be
62 set to some central location included in the RAYPATH environment variable.
63 The default is the current working directory.
64 .TP
65 .BI -p \ prefdir
66 Set the library subdirectory path to
67 .I prefdir.
68 This is the subdirectory from the library where all output files will
69 be placed.
70 It is often most convenient to use a subdirectory for the storage of
71 light sources, since there tend to be many files and placing them all
72 in one directory is very messy.
73 The default value is the empty string.
74 .TP
75 .BI -o \ outname
76 Set the output file name root to
77 .I outname.
78 This overrides the default output file name root which is the same as the
79 input file.
80 This option may be used for only one input file, and is required when
81 reading data from the standard input.
82 .TP
83 .BR -s
84 Send the scene information to the standard output rather than a
85 separate file.
86 This is appropriate when calling
87 .I ies2rad
88 from within a scene description via an inline command.
89 The data file(s) will still be written based on the output file name
90 root, but since this information is unaffected by command line options,
91 it is safe to have multiple invocations of
92 .I ies2rad
93 using the same input file and different output options.
94 The
95 .I \-s
96 option may be used for only one input file.
97 .TP
98 .BI -d units
99 Output dimensions are in
100 .I units,
101 which is one of the letters 'm', 'c', 'f', or 'i' for meters,
102 centimeters, feet or inches, respectively.
103 The letter specification may be followed by a slash ('/') and an
104 optional divisor.
105 For example,
106 .I \-dm/1000
107 would be millimeters.
108 The default output is in meters, regardless of the original units in
109 the IES input file.
110 Note that there is no space in this option.
111 .TP
112 .BI -i \ rad
113 Ignore the crude geometry given by the IES input file and use instead an illum
114 sphere with radius
115 .I rad.
116 This option may be useful when the user wishes to add a more accurate
117 geometric description to the light source model, though this need
118 is obviated by the recent LM-63-1995 specification, which uses MGF
119 detail geometry.
120 (See
121 .I \-g
122 option below.)\0
123 .TP
124 .BR -g
125 If the IES file contains MGF detail geometry, compile this geometry into
126 a separate octree and create a single instance referencing it
127 instead of including the converted geometry directly in the Radiance
128 output file.
129 This can result in a considerable memory savings for luminaires
130 which are later duplicated many times in a scene, though the
131 appearance may suffer for certain luminaires since the enclosed glow
132 sources will not light the local geometry as they would otherwise.
133 .TP
134 .BI -f \ lampdat
135 Use
136 .I lampdat
137 instead of the default lamp lookup table (lamp.tab) to map lamp
138 names to xy chromaticity and lumen depreciation data.
139 It is often helpful to have customized lookup tables for specific
140 manufacturers and applications.
141 .TP
142 .BI -t \ lamp
143 Use the given lamp type for all input files.
144 Normally,
145 .I ies2rad
146 looks at the header lines of the IES file to try and determine
147 what lamp is being used in the fixture.
148 If any of the lines is matched by a pattern in the lamp lookup
149 table (see the -f option above), that color and depreciation factor will
150 be used instead of the default (see the -c and -u options).
151 The
152 .I lamp
153 specification is also looked up in the lamp table unless it is
154 set to "default", in which case the default color is used instead.
155 .TP
156 .BI -c " red grn blu"
157 Use the given color if the type of the lamp is unknown or
158 the -t option is set to "default".
159 If unspecified, the default color will be white.
160 .TP
161 .BI -u \ lamp
162 Set the default lamp color according to the entry for
163 .I lamp
164 in the lookup table (see the -f option).
165 This is the color that will be used if the input specification
166 does not match any lamp type patterns.
167 This option is used instead of the -c option.
168 .TP
169 .BI -m \ factor
170 Multiply all output quantities by
171 .I factor.
172 This is the best way to scale fixture brightness for different lamps, but care
173 should be taken when this option is applied to multiple files.
174 .SH EXAMPLE
175 To convert a single IES data file in inches with color balanced output
176 and 15% lumen depreciation,
177 creating the files "fluor01.rad" and "fluor01.dat" in the current directory:
178 .IP "" .2i
179 ies2rad -di -t default -m .85 fluor01.ies
180 .PP
181 To convert three IES files of various types to tenths of a foot and put
182 them in the library "/usr/local/lib/ray" subdirectory "source/ies":
183 .IP "" .2i
184 ies2rad -df/10 -l /usr/local/lib/ray -p source/ies ies01 ies02 ies03
185 .PP
186 To convert a single file and give the output a different name:
187 .IP "" .2i
188 ies2rad -o fluorescent ies03
189 .SH ENVIRONMENT
190 RAYPATH directories to search for lamp lookup table
191 .SH AUTHOR
192 Greg Ward
193 .SH BUGS
194 In pre-1991 standard IES files, all header lines will be examined
195 for a lamp table string match.
196 In post-1991 standard files, only those lamps with the [LAMP] or
197 [LAMPCAT] keywords will be searched.
198 The first match found in the file is always the one used.
199 This method of assigning colors to fixtures is less than perfect,
200 and the IES would do well to include explicit spectral information
201 somehow in their specification.
202 .PP
203 The IESNA LM-63 specification prior to 1995 provided three basic source
204 shapes, rectangular, round, and elliptical.
205 The details of these shapes is vague at best.
206 Rectangular sources will always be rectangular, but ies2rad will
207 approximate round sources as spherical if the height is close to
208 or greater than the width and length, and as a ring otherwise.
209 Elliptical sources are treated the same as round sources.
210 The 1995 standard rectifies this problem by including detailed
211 luminaire geometry as MGF data, though nothing in the standard
212 requires manufacturers to provide this information.
213 .SH "SEE ALSO"
214 mgf2rad(1), oconv(1), pfilt(1), rad2mgf(1), rpict(1), xform(1)
