1 |
.\" RCSid "$Id$" |
2 |
.TH IES2RAD "1" "2021-10-26" "Radiance" "Radiance Manual Pages" |
3 |
.SH "NAME" |
4 |
ies2rad \- convert IES luminaire data to RADIANCE description |
5 |
.SH "SYNOPSIS" |
6 |
\fBies2rad\fP [ \fIoptions\fP ] [ \fIfile file .\|.\|.\&\fP ] |
7 |
.SH "DESCRIPTION" |
8 |
\fIIes2rad\fP converts one or more IES luminaire data files to |
9 |
an equivalent RADIANCE scene description. The light source geometry |
10 |
will always be centered at the origin aimed in the negative Z |
11 |
direction, with the 0 degree plane along the x-axis\(emthe IES |
12 |
photometric horizontal or length. The IES width is oriented along |
13 |
the y axis, and the IES up becomes the RADIANCE z-axis. |
14 |
.PP |
15 |
The IES(NA) LM-63 standard provides a limited range of light |
16 |
source shapes (\(lqluminous openings\(rq), different in each |
17 |
version of the standard. Of these shapes, \fIies2rad\fP supports |
18 |
rectangles, boxes, points (as 1mm spheres), disks (as 1mm high |
19 |
vertical cylinders), vertical cylinders, and spheres. Some versions |
20 |
of the standard also define ellipses, ellipsoids, and horizontal |
21 |
cylinders. \fIIes2rad\fP will approximate near-circular ellipses |
22 |
as disks, near-spherical ellipsoids as spheres, and horizontal |
23 |
cylinders as boxes. |
24 |
.PP |
25 |
The 1995 IES standard once included the materials and geometry |
26 |
format (MGF) which can describe detailed luminaire and light |
27 |
source geometry, but it was never used. \fIIes2rad\fP still supports |
28 |
MGF. |
29 |
.PP |
30 |
\fIIes2rad\fP assigns light source colors based on information |
31 |
in a lamp lookup table. Since most lamps are distinctly colored, |
32 |
it is often desirable to override this lookup procedure and use |
33 |
a neutral value that will produced color-balanced renderings. |
34 |
In general, it is important to consider lamp color when an odd |
35 |
assortment of fixture types is being used to illuminate the same |
36 |
scene, and the rendering can always be balanced by \fBpfilt\fP(1) |
37 |
to a specific white value later. |
38 |
.SH "OPTIONS" |
39 |
.TP |
40 |
.BI "\-l" " libdir" |
41 |
Set the library directory path to \fIlibdir\fP. This is where |
42 |
all relative pathnames will begin for output file names. For |
43 |
light sources that will be used by many people, this should be |
44 |
set to some central location included in the RAYPATH environment |
45 |
variable. The default is the current working directory. |
46 |
.TP |
47 |
.BI "\-p" " prefdir" |
48 |
Set the library subdirectory path to \fIprefdir\fP. This is the |
49 |
subdirectory from the library where all output files will be |
50 |
placed. It is often most convenient to use a subdirectory for |
51 |
the storage of light sources, since there tend to be many files |
52 |
and placing them all in one directory is very messy. The default |
53 |
value is the empty string. |
54 |
.TP |
55 |
.BI "\-o" " outname" |
56 |
Set the output file name root to \fIoutname\fP. This overrides |
57 |
the default output file name root which is the same as the input |
58 |
file. This option may be used for only one input file, and is |
59 |
required when reading data from the standard input. |
60 |
.TP |
61 |
.B "\-s" |
62 |
Send the scene information to the standard output rather than |
63 |
a separate file. This is appropriate when calling \fIies2rad\fP |
64 |
from within a scene description via an inline command. The data |
65 |
file(s) will still be written based on the output file name root, |
66 |
but, since this information is unaffected by command line options, |
67 |
it is safe to have multiple invocations of \fIies2rad\fP using |
68 |
the same input file and different output options. The \fI\-s\fP |
69 |
option may be used for only one input file. |
70 |
.TP |
71 |
.BI "\-d" " units" |
72 |
Output dimensions are in \fIunits\fP, which is one of the letters |
73 |
'm', 'c', 'f', or 'i' for meters, centimeters, feet or inches, |
74 |
respectively. The letter specification may be followed by a slash |
75 |
('/') and an optional divisor. For example, \fI\-dm/1000\fP would |
76 |
be millimeters. The default output is in meters, regardless of |
77 |
the original units in the IES input file. Note that there is |
78 |
no space in this option. |
79 |
.TP |
80 |
.BI "\-i" " rad" |
81 |
Ignore the crude geometry given by the IES input file and use |
82 |
instead an illum sphere with radius \fIrad\fP. This option may |
83 |
be useful when the user wishes to add a more accurate geometric |
84 |
description to the light source model, though this need is obviated |
85 |
by the recent LM-63-1995 specification, which uses MGF detail |
86 |
geometry. (See \fI\-g\fP option below.) |
87 |
.TP |
88 |
.B "\-g" |
89 |
If the IES file contains MGF detail geometry, compile this geometry |
90 |
into a separate octree and create a single instance referencing |
91 |
it instead of including the converted geometry directly in the |
92 |
Radiance output file. This can result in a considerable memory |
93 |
savings for luminaires which are later duplicated many times |
94 |
in a scene, though the appearance may suffer for certain luminaires |
95 |
since the enclosed glow sources will not light the local geometry |
96 |
as they would otherwise. |
97 |
.TP |
98 |
.BI "\-f" " lampdat" |
99 |
Use \fIlampdat\fP instead of the default lamp lookup table (lamp.tab) |
100 |
to map lamp names to xy chromaticity and lumen depreciation data. |
101 |
It is often helpful to have customized lookup tables for specific |
102 |
manufacturers and applications. |
103 |
.TP |
104 |
.BI "\-t" " lamp" |
105 |
Use the given lamp type for all input files. Normally, \fIies2rad\fP |
106 |
looks at the header lines of the IES file to try and determine |
107 |
what lamp is being used in the fixture. If any of the lines is |
108 |
matched by a pattern in the lamp lookup table (see the \fB\-f\fP |
109 |
option above), that color and depreciation factor will be used |
110 |
instead of the default (see the \fB\-c\fP and \fB\-u\fP options). |
111 |
The \fIlamp\fP specification is also looked up in the lamp table |
112 |
unless it is set to \(lqdefault\(rq, in which case the default |
113 |
color is used instead. |
114 |
.TP |
115 |
.BI "\-c" " red grn blu" |
116 |
Use the given color if the type of the lamp is unknown or the |
117 |
\fB\-t\fP option is set to \(lqdefault\(rq. If unspecified, the |
118 |
default color will be white. |
119 |
.TP |
120 |
.BI "\-u" " lamp" |
121 |
Set the default lamp color according to the entry for \fIlamp\fP |
122 |
in the lookup table (see the \fB\-f\fP option). This is the color |
123 |
that will be used if the input specification does not match any |
124 |
lamp type patterns. This option is used instead of the \fB\-c\fP |
125 |
option. |
126 |
.TP |
127 |
.BI "\-m" " factor" |
128 |
Multiply all output quantities by \fIfactor\fP. This is the best |
129 |
way to scale fixture brightness for different lamps, but care |
130 |
should be taken when this option is applied to multiple files. |
131 |
.SH "EXIT STATUS" |
132 |
0 if successful, 1 if not. |
133 |
.SH "ENVIRONMENT" |
134 |
.TP |
135 |
RAYPATH |
136 |
Colon-separated list of directories to search for lamp lookup |
137 |
table |
138 |
.SH "FILES" |
139 |
The output files will be created in the current directory (no |
140 |
matter which directory the input files came from) unless the |
141 |
\fI\-l\fP or \fI\-p\fP options are used. |
142 |
.TP |
143 |
.RI "<" "luminaire" ">.ies" |
144 |
The IES LM-63 input file. May also be from the standard input. |
145 |
If the standard input is the source, the \fB-o\fP option must |
146 |
be specified, to provide a filename. |
147 |
.TP |
148 |
.RI "<" "luminaire" ">.rad" |
149 |
The RADIANCE scene description. May also be sent to the standard |
150 |
output. |
151 |
.TP |
152 |
.RI "<" "luminaire" ">.dat" |
153 |
The IES candela values. |
154 |
.TP |
155 |
.RI "<" "luminaire" ">+.dat" |
156 |
The IES tilt data. If tilt data is not provided (it is mostly |
157 |
needed for luminaires which use metal halide lamps), this file |
158 |
is not generated. |
159 |
.TP |
160 |
.RI "<" "luminaire" ">.oct" |
161 |
If the \fB-g\fP option is given, the compiled MGF geometry is |
162 |
placed in this octree file. |
163 |
.TP |
164 |
.RI "<" "RAYPATH" ">/lamp.tab" |
165 |
lamp table |
166 |
.SH "EXAMPLES" |
167 |
To convert a single IES data file in inches with color balanced |
168 |
output and 15% lumen depreciation, creating the files \(lqfluor01.rad\(rq |
169 |
and \(lqfluor01.dat\(rq in the current directory: |
170 |
.RS 2n |
171 |
.sp 0.25 |
172 |
ies2rad -di -t default -m .85 fluor01.ies |
173 |
.sp 0.25 |
174 |
.RE |
175 |
.PP |
176 |
To convert three IES files of various types to tenths of a foot |
177 |
and put them in the library \(lq/usr/local/lib/ray\(rq subdirectory |
178 |
\(lqsource/ies\(rq: |
179 |
.RS 2n |
180 |
.sp 0.25 |
181 |
ies2rad -df/10 -l /usr/local/lib/ray -p source/ies ies01 ies02 ies03 |
182 |
.sp 0.25 |
183 |
.RE |
184 |
.PP |
185 |
To convert a single file and give the output a different name: |
186 |
.RS 2n |
187 |
.sp 0.25 |
188 |
ies2rad -o fluorescent ies03 |
189 |
.sp 0.25 |
190 |
.RE |
191 |
.SH "REFERENCES" |
192 |
.TP |
193 |
LM-63-86, LM-63-91, LM-63-95, LM-63-02, LM-63-19 |
194 |
\fIIES Standard File Format for the Electronic Transfer of Photometric |
195 |
Data and Related Information\fP. IESNA - Lighting Measurement |
196 |
and Testing. Illuminating Engineering Society, 1986, 1991, 1995, |
197 |
2002, 2019. |
198 |
.TP |
199 |
LM-75-01 |
200 |
\fIGoniophotometer Types and Photometric Coordinates\fP. New |
201 |
York: Illuminating Engineering Society of North America, 2001. |
202 |
.TP |
203 |
The Materials and Geometry Format |
204 |
Greg Ward. \fIThe Materials and Geometry Format\fP <https://floyd.lbl.gov/mgf/mgfdoc.pdf>. |
205 |
Lawrence Berkeley Laboratory, 1996. |
206 |
.SH "AUTHOR" |
207 |
Greg Ward |
208 |
.SH "BUGS" |
209 |
In pre-1991 standard IES files, all header lines will be examined |
210 |
for a lamp table string match. In post-1991 standard files, only |
211 |
those lamps with the [LAMP] or [LAMPCAT] keywords will be searched. |
212 |
The first match found in the file is always the one used. This |
213 |
method of assigning colors to fixtures is less than perfect, |
214 |
and the IES would do well to include explicit spectral information |
215 |
somehow in their specification. |
216 |
.PP |
217 |
Not all luminous openings defined in the IES standard are supported. |
218 |
So far, however, we have yet to find IES files which use the |
219 |
unsupported shapes. |
220 |
.SH "SEE ALSO" |
221 |
\fBlamp.tab\fP(5), \fBmgf2rad\fP(1), \fBoconv\fP(1), \fBpfilt\fP(1), |
222 |
\fBrad2mgf\fP(1), \fBrpict\fP(1), \fBxform\fP(1) |
