1 |
.\" RCSid "$Id: histo.1,v 1.7 2010/07/08 18:54:39 greg Exp $" |
2 |
.TH HISTO 1 9/6/96 RADIANCE |
3 |
.SH NAME |
4 |
histo - compute 1-dimensional histogram of N data columns |
5 |
.SH SYNOPSIS |
6 |
.B "histo [-c][-p] xmin xmax nbins" |
7 |
.br |
8 |
.B "histo [-c][-p] imin imax" |
9 |
.SH DESCRIPTION |
10 |
.I Histo |
11 |
bins columnular data on the standard input between the given minimum |
12 |
and maximum values. |
13 |
If three command line arguments are given, the third is taken as the |
14 |
number of data bins between the first two real numbers. |
15 |
If only two arguments are given, they are both assumed to be integers, |
16 |
and the number of data bins will be equal to their difference plus one. |
17 |
The bins are always of equal size. |
18 |
.PP |
19 |
The output is N+1 columns of data (for N columns input), where the |
20 |
first column is the centroid of each division, and each row |
21 |
corresponds to the frequencies for each column around that value. |
22 |
.PP |
23 |
If the |
24 |
.I \-c |
25 |
option is present, then |
26 |
.I histo |
27 |
computes the cumulative histogram for each column instead of the |
28 |
straight frequencies. |
29 |
The upper value of each bin is printed also instead of the centroid. |
30 |
This may be useful in computing percentiles, for example. |
31 |
Values below the minimum specified are still counted in the cumulative |
32 |
total. |
33 |
.PP |
34 |
The |
35 |
.I \-p |
36 |
option tells |
37 |
.I histo |
38 |
to report the percentage of the total number of input lines rather |
39 |
than the absolute counts. |
40 |
In the case of a cumulative total, this yields the percentile values |
41 |
directly. |
42 |
Values above the maximum are counted as well as values below in |
43 |
this case. |
44 |
.PP |
45 |
All input data is interpreted as real values, and columns must be |
46 |
white-space separated. |
47 |
If any value is less than the minimum or greater than the maximum, |
48 |
it will be ignored unless the |
49 |
.I \-c |
50 |
option is specified. |
51 |
.SH EXAMPLE |
52 |
To count data values between \-1 and 1 in 50 bins: |
53 |
.IP "" .2i |
54 |
histo \-1 1 50 < input.dat |
55 |
.PP |
56 |
To count frequencies of integers between 0 and 255: |
57 |
.IP "" .2i |
58 |
histo 0 255 < input.dat |
59 |
.SH AUTHOR |
60 |
Greg Ward |
61 |
.SH "SEE ALSO" |
62 |
cnt(1), neaten(1), rcalc(1), rcollate(1), rlam(1), tabfunc(1), total(1) |
