root/radiance/ray/doc/man/man1/histo.1
Revision: 1.5
Committed: Thu Jul 12 14:58:52 2007 UTC (17 years, 11 months ago) by greg
Decreased default -n setting in obj2mesh from 15 to 9
1 .\" RCSid "$Id: histo.1,v 1.4 2004/01/01 19:31:45 greg Exp $"
2 .TH HISTO 1 9/6/96 RADIANCE
3 .SH NAME
4 histo - compute 1-dimensional histogram of N data columns
5 .SH SYNOPSIS
6 .B "histo [-c][-p] xmin xmax nbins"
7 .br
8 .B "histo [-c][-p] imin imax"
9 .SH DESCRIPTION
10 .I Histo
11 bins columnular data on the standard input between the given minimum
12 and maximum values.
13 If three command line arguments are given, the third is taken as the
14 number of data bins between the first two real numbers.
15 If only two arguments are given, they are both assumed to be integers,
16 and the number of data bins will be equal to their difference plus one.
17 The bins are always of equal size.
18 .PP
19 The output is N+1 columns of data (for N columns input), where the
20 first column is the centroid of each division, and each row
21 corresponds to the frequencies for each column around that value.
22 .PP
23 If the
24 .I \-c
25 option is present, then
26 .I histo
27 computes the cumulative histogram for each column instead of the
28 straight frequencies.
29 The upper value of each bin is printed also instead of the centroid.
30 This may be useful in computing percentiles, for example.
31 Values below the minimum specified are still counted in the cumulative
32 total.
33 .PP
34 The
35 .I \-p
36 option tells
37 .I histo
38 to report the percentage of the total number of input lines rather
39 than the absolute counts.
40 In the case of a cumulative total, this yeilds the percentile values
41 directly.
42 Values above the maximum are counted as well as values below in
43 this case.
44 .PP
45 All input data is interpreted as real values, and columns must be
46 white-space separated.
47 If any value is less than the minimum or greater than the maximum,
48 it will be ignored unless the
49 .I \-c
50 option is specified.
51 .SH EXAMPLE
52 To count data values between -1 and 1 in 50 bins:
53 .IP "" .2i
54 histo -1 1 50 < input.dat
55 .PP
56 To count frequencies of integers between 0 and 255:
57 .IP "" .2i
58 histo 0 255 < input.dat
59 .SH AUTHOR
60 Greg Ward
61 .SH "SEE ALSO"
62 cnt(1), neaten(1), rcalc(1), rlam(1), tabfunc(1), total(1)
