root/Development/ray/doc/man/man1/glrad.1
Revision: 1.6
Committed: Thu Apr 28 16:28:20 2016 UTC (9 years, 7 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
Changes since 1.5: +6 -5 lines
Added listening for mouse wheel
# User Rev Content
1 greg 1.6 .\" RCSid "$Id: glrad.1,v 1.5 2007/09/04 17:36:40 greg Exp $"
2 greg 1.2 .TH GLRAD 1 6/10/98 RADIANCE
3 greg 1.1 .SH NAME
4     glrad - render a RADIANCE scene using OpenGL
5     .SH SYNOPSIS
6     .B glrad
7     [
8     .B \-w
9     ][
10     .B \-b
11     ][
12     .B \-s
13     ][
14     .B \-S
15     ][
16     .B "\-v view"
17     ]
18     .B rfile
19     [
20     .B "VAR\=value .."
21     ]
22     .SH DESCRIPTION
23     .I Glrad
24     renders a Radiance scene description in OpenGL.
25     Its syntax and behavior is similar to
26     .I rad(1)
27     with the
28     .I \-o
29     option, where the output device is assumed to be an X11 server
30     with GLX extensions.
31     .PP
32     The
33     .I \-w
34     option turns off warnings.
35     The
36     .I \-s
37     option tells
38     .I glrad
39     to run
40     .I rad
41     silently, not echoing
42     .I oconv(1)
43     command.
44     The
45     .I \-b
46     option turns off back face visibility (i.e., enables back face culling).
47     This is equivalent to the
48     .I \-bv
49     option of
50     .I rpict(1)
51     and
52 greg 1.4 .I rvu(1).
53 greg 1.1 The
54     .I \-S
55     option turns on full-screen stereo for displays that support it.
56     (Be sure to run
57     .I /usr/gfx/setmon(1)
58     or its equivalent to set STR_TOP or STR_BOT, first.)\0
59     The
60     .I \-v
61     option may be used to specify a starting view, either by symbolic name
62     as entered in the
63     .I view
64     assignments in
65     .I rfile,
66     or by a complete view specification, enclosed in quotes.
67     If no view is specified, then the first standard view from
68     .I rfile
69     is used to start.
70     .PP
71     Variables permitted in
72     .I rfile
73     are described in the
74     .I rad
75     manual page.
76     Additional or overriding assignments may be given on the command line
77     following
78     .I rfile.
79     .PP
80     The view is controlled via the mouse and simple one-character commands,
81     listed below:
82     .TP 10n
83     .BR "(mouse)"
84     Modify the current view.
85     The mouse is used to control the current view in the following ways:
86     .sp
87     .nf
88     CONTROL MOUSE ACTION
89 greg 1.6 (none) left Move forward towards cursor position
90 greg 1.1 (none) right Move backward away from cursor position
91     (none) middle Rotate in place (usually safe)
92 greg 1.6 (none) wheel-up Zoom in on current position
93     (non) wheel-dn Zoom out around current position
94     shift left Orbit left around cursor position
95 greg 1.1 shift right Orbit right around cursor position
96     shift middle Orbit skyward
97 greg 1.6 cntl middle Orbit earthward
98 greg 1.1 .fi
99     .sp
100     For all movements but rotating in place, the cursor must be placed over some
101     bit of visible geometry, otherwise the program has no reference point from
102     which to work.
103     It is best to just experiment with these controls until you learn to fly
104     safely in your model.
105     And if you run into trouble, the 'l' command is very useful.
106     (See below.)\0
107     .TP
108     .BR '+'
109     Zoom in on the current cursor position.
110     .TP
111     .BR '-'
112     Zoom out from the current cursor position.
113     .TP
114     .BR 'l'
115     Return to the last saved view.
116     Each time a new command changes the current view, the last view
117     is saved, and may be recalled with this command.
118     Multiple uses of the same command (e.g., rotation, zoom) will
119     save only the view before the first such command.
120     This way, it is easy to get back to where you were before a sequence
121     of view changes.
122     .TP
123     .BR 'h'
124     Fix the head height.
125     All mouse-controlled view motions will be adjusted so that the head height
126     does not change (where vertical is determined by the current
127     view up vector).
128     .TP
129     .BR 'H'
130     Release the head height, allowing it to change again during mouse-controlled
131     movements.
132     .TP
133     .BR 'v'
134     Print the current view parameters to the standard output.
135     This is useful for finding out where you are, or for saving specific
136     views in a keyframe file for animations or returning to later.
137     .TP
138     .BR 'V'
139     Append the current view to the original
140     .I rfile.
141     This view will be unnamed, but can be referred to by number or the
142     user may add a name later with a text editor.
143     The current view number becomes the last standard view.
144     (See the 'n' and 'p' commands, below.)
145     .TP
146     .BR 'n'
147     Go to the next standard view stored in
148     .I rfile.
149     If the last view is currently displayed, then cycle to the first one.
150     .TP
151     .BR 'p'
152     Go to the previous standard view stored in
153     .I rfile.
154     If the first view is currently displayed, then cycle to the last one.
155     .TP
156     .BR 'q'
157     Quit
158     .I glrad.
159     This is the normal way to exit the program.
160     .SH AUTHOR
161     Greg Ward Larson
162     .SH BUGS
163     It would be nice if
164     .I glrad
165     set the appropriate video format for stereo viewing automatically,
166     but the process is different on different systems and there is no
167     single, sure-fire way to do it for all systems.
168     On systems that do not support stereo extensions, the program
169 greg 1.5 may be compiled with the \-DNOSTEREO option, which will avoid
170 greg 1.1 undefined symbol errors.
171     .SH "SEE ALSO"
172     chmod(1), getinfo(1), ls(1), objview(1), oconv(1), ps(1), rad(1),
173 greg 1.4 ranimate(1), rhcopy(1), rholo(1), rpict(1), rtrace(1), rvu(1), setmon(1)
