root/radiance/ray/doc/man/man1/glrad.1
Revision: 1.3
Committed: Tue Dec 9 15:59:06 2003 UTC (20 years, 6 months ago) by greg
Fixed RCSid specification
1 .\" RCSid "$Id$"
2 .TH GLRAD 1 6/10/98 RADIANCE
3 .SH NAME
4 glrad - render a RADIANCE scene using OpenGL
5 .SH SYNOPSIS
6 .B glrad
7 [
8 .B \-w
9 ][
10 .B \-b
11 ][
12 .B \-s
13 ][
14 .B \-S
15 ][
16 .B "\-v view"
17 ]
18 .B rfile
19 [
20 .B "VAR\=value .."
21 ]
22 .SH DESCRIPTION
23 .I Glrad
24 renders a Radiance scene description in OpenGL.
25 Its syntax and behavior is similar to
26 .I rad(1)
27 with the
28 .I \-o
29 option, where the output device is assumed to be an X11 server
30 with GLX extensions.
31 .PP
32 The
33 .I \-w
34 option turns off warnings.
35 The
36 .I \-s
37 option tells
38 .I glrad
39 to run
40 .I rad
41 silently, not echoing
42 .I oconv(1)
43 command.
44 The
45 .I \-b
46 option turns off back face visibility (i.e., enables back face culling).
47 This is equivalent to the
48 .I \-bv
49 option of
50 .I rpict(1)
51 and
52 .I rview(1).
53 The
54 .I \-S
55 option turns on full-screen stereo for displays that support it.
56 (Be sure to run
57 .I /usr/gfx/setmon(1)
58 or its equivalent to set STR_TOP or STR_BOT, first.)\0
59 The
60 .I \-v
61 option may be used to specify a starting view, either by symbolic name
62 as entered in the
63 .I view
64 assignments in
65 .I rfile,
66 or by a complete view specification, enclosed in quotes.
67 If no view is specified, then the first standard view from
68 .I rfile
69 is used to start.
70 .PP
71 Variables permitted in
72 .I rfile
73 are described in the
74 .I rad
75 manual page.
76 Additional or overriding assignments may be given on the command line
77 following
78 .I rfile.
79 .PP
80 The view is controlled via the mouse and simple one-character commands,
81 listed below:
82 .TP 10n
83 .BR "(mouse)"
84 Modify the current view.
85 The mouse is used to control the current view in the following ways:
86 .sp
87 .nf
88 CONTROL MOUSE ACTION
89 (none) left Move forward towards cursor position
90 (none) right Move backward away from cursor position
91 (none) middle Rotate in place (usually safe)
92 shift left Orbit left around cursor position
93 shift right Orbit right around cursor position
94 shift middle Orbit skyward
95 cntl middle Orbit earthward
96 .fi
97 .sp
98 For all movements but rotating in place, the cursor must be placed over some
99 bit of visible geometry, otherwise the program has no reference point from
100 which to work.
101 It is best to just experiment with these controls until you learn to fly
102 safely in your model.
103 And if you run into trouble, the 'l' command is very useful.
104 (See below.)\0
105 .TP
106 .BR '+'
107 Zoom in on the current cursor position.
108 (Beware of repeating keys that go faster than the display updates.)
109 .TP
110 .BR '-'
111 Zoom out from the current cursor position.
112 .TP
113 .BR 'l'
114 Return to the last saved view.
115 Each time a new command changes the current view, the last view
116 is saved, and may be recalled with this command.
117 Multiple uses of the same command (e.g., rotation, zoom) will
118 save only the view before the first such command.
119 This way, it is easy to get back to where you were before a sequence
120 of view changes.
121 .TP
122 .BR 'h'
123 Fix the head height.
124 All mouse-controlled view motions will be adjusted so that the head height
125 does not change (where vertical is determined by the current
126 view up vector).
127 .TP
128 .BR 'H'
129 Release the head height, allowing it to change again during mouse-controlled
130 movements.
131 .TP
132 .BR 'v'
133 Print the current view parameters to the standard output.
134 This is useful for finding out where you are, or for saving specific
135 views in a keyframe file for animations or returning to later.
136 .TP
137 .BR 'V'
138 Append the current view to the original
139 .I rfile.
140 This view will be unnamed, but can be referred to by number or the
141 user may add a name later with a text editor.
142 The current view number becomes the last standard view.
143 (See the 'n' and 'p' commands, below.)
144 .TP
145 .BR 'n'
146 Go to the next standard view stored in
147 .I rfile.
148 If the last view is currently displayed, then cycle to the first one.
149 .TP
150 .BR 'p'
151 Go to the previous standard view stored in
152 .I rfile.
153 If the first view is currently displayed, then cycle to the last one.
154 .TP
155 .BR 'q'
156 Quit
157 .I glrad.
158 This is the normal way to exit the program.
159 .SH AUTHOR
160 Greg Ward Larson
161 .SH BUGS
162 It would be nice if
163 .I glrad
164 set the appropriate video format for stereo viewing automatically,
165 but the process is different on different systems and there is no
166 single, sure-fire way to do it for all systems.
167 On systems that do not support stereo extensions, the program
168 may be compiled with the -DNOSTEREO option, which will avoid
169 undefined symbol errors.
170 .SH "SEE ALSO"
171 chmod(1), getinfo(1), ls(1), objview(1), oconv(1), ps(1), rad(1),
172 ranimate(1), rhcopy(1), rholo(1), rpict(1), rtrace(1), rview(1), setmon(1)
